Phillips 42PFL3704D/F7 Dead
  • landyboy
    • Apr 2013
    • 443
    Re: Phillips 42PFL3704D/F7 Dead
    Suspect Q1602?
      Should download the service manual:
      Chassis FL9.2?
      • landyboy
        • Apr 2013
        • 443
        Ok got it downloaded but not very good at reading circuits yet.
        • landyboy
          • Apr 2013
          • 443
          Tested Q1203 per manual
          3.3m 2.1ohm 6.1k
            Remove from circuit to confirm.... looks dodgy.
            • landyboy
              • Apr 2013
              • 443
              269k 2.1 ohm 110k out of circuit
              • landyboy
                • Apr 2013
                • 443
                would that indicate a gate to drain short?
                • landyboy
                  • Apr 2013
                  • 443
                  http://pdf1.alldatasheet.com/datashe...SK3757_09.html
                  • landyboy
                    • Apr 2013
                    • 443
                    Do you think the 2.1 ohm is a problem? I tested the other exact same fet and it did not show a 2.1 ohm short.
                      Yes, it's bad.
                      • landyboy
                        • Apr 2013
                        • 443
                        Replaced the Fet still no change. What should the input/output voltage be on the Bridge Rectifier? When I test Ac voltage from the neutral to the center pins I have 0 VAC Its almost as if the voltage is not getting to the Bridge Rectifier
                          Because the relay isn't kicking in, the relay only kicks in if 5VSB is up (check 5V standby output) and main board turns it on.
                          • landyboy
                            • Apr 2013
                            • 443
                            No standby voltage is present.
                            • landyboy
                              • Apr 2013
                              • 443
                              Ok I tested all diodes on the PSU. All are around .537 on direction and OL the other. There is one Diode D1101 that tests 0.79 one way and 1.5 the other direction. Meter set to Diode test setting.
                                OK, it is one of those 2-transistor switching power supply that when it goes out, lots of components are damaged (check all those parts real well in the red box I marked). Check the fusible resistor I circled, and check the DC voltage right at the two legs of the cap I circled.
                                • double_DD
                                  How can I be sure that my EC chip is dead?
                                  by double_DD
                                  As the title suggests, how can I be sure that my EC chip is really dead?
                                  I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                  Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                  03-12-2025, 07:47 AM
                                • disorder
                                  ps5 edm-033 dead after hdmi/usb ports destroyed
                                  by disorder
                                  hello guys,
                                  i need help to repair a edm-033 ps2
                                  history : as always hdmi port and usb ports destroyed after unplugged
                                  after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                  so i changed it
                                  now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                  but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                  i don't see any projection of liquid metal on pcb.
                                  01-14-2025, 12:48 PM
                                • Beton
                                  Finding a dead short component
                                  by Beton
                                  Hi guys!
                                  I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                  So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                  I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                  I have a bench PSU and if I try to inject voltage the voltage...
                                  12-10-2021, 01:05 PM
                                • zunasthegreat
                                  Chieftec GPS-450-AA with dead 20N60C3
                                  by zunasthegreat
                                  Hello everyone hope all doing well!
                                  I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                  09-01-2024, 07:12 PM
                                • FiguringITout
                                  MSI Raider GE75 - Not posting, probable dead CPU
                                  by FiguringITout
                                  Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                  Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                  07-25-2024, 07:27 AM
