Samsung HP-S4253 - 5 seconds to black
  • atoledo
    • Aug 2013
    • 4
    After searching for over an hour on this forum, I discovered a member with the exact same problem as me.
    https://www.badcaps.net/forum/showth...light=hp-s4253
    I also learned that fixing the problem is far beyond my knowledge, so I almost decided not to post. However, here it is...
    A while back I had a no-picture/clicking problem with a Samsung HPT4254 that I pulled out the power board, sent it to a guy in Washington, and one week and $65 dollars later I had a working set again.
    Now my friend's Samsung HP-S4253 goes on for about 5 seconds, then fades to black. I've read the other thread with the same problem, but the guy never fully discovered what the problem was or how to fix it. I was hoping the problem was as widespread as the one on my Samsung HPT4254 whereby everyone knew the trouble lay in the power board.
    Interestingly enough, if I turn the set on and immediately start cycling through all the inputs, the screen does not fade to black until I stop.
    If anyone has any idea on this, please share. I would be very grateful.
    Thank You
    Re: Samsung HP-S4253 - 5 seconds to black
    If you go to a "no signal" screen, does it ever fade out? Or only on scenes with actual pictures on them?
    • capkid
      • Oct 2010
      • 1339
      There are a couple repair kits for this TV that address the symptoms you describe. You'll have to determine through testing which kit, if any, is useful:
      http://www.amazon.com/Repair-Samsung.../dp/B00897A3KS
      http://www.ebay.com/itm/SAMSUNG-Plas...item20d013a5a0
      LG Plasma Mal-Discharge Correction Service
      • adriancel
        • May 2011
        • 27
        Please post a picture with the power supply board.
        • atoledo
          • Aug 2013
          • 4
          It fades out no matter what input is selected, whether there is a signal or not.
            By fade out, do you mean a sudden loss of picture, or does it visibly reduce in brightness as it goes?
            • atoledo
              • Aug 2013
              • 4
              First of all, sorry for such a late response. I've been super busy lately.
              By fade out, I mean that the image does NOT just switch off, but rather it takes about half a second from full image to completely black. There is still audio, but not image at all.
              In order to narrow it down to just the tv set, I disconnected all other components (cable box, game box, dvd, antenna, etc.) and switched the set on. I quickly brought up the setup menu and it showed for about one second before it quickly faded to black as well.
              Attached are images of the boards inside. I don't know which one is the power supply board.
                09-07-2024, 05:50 AM
              • eigma
                Samsung UN40H5003 boot loop every ~8 seconds
                by eigma
                Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                Main board: BN94-07592P / BN97-08922R...
                11-20-2024, 10:31 PM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
                09-06-2024, 11:40 PM
