Vizio SV420XVT Distorted Picture Issue
  • Timebomb606
    • Aug 2013
    • 8
    Hey guys,
    I got this TV from a friends parents who thought it was broken. When i got it home, i did a channel search and all was well. Well when i unhooked the coax from RF Input, the connector broke off and was on the end of the cable...no longer attached to the TV.
    So i got a new main board for this and installed it all. Exact same serial, and product code as the old one. Turn the TV on and nothing at all, no backlight, no sound, no vizio logo light up...nothing.
    So i have put the old board back in and im going to return the new one. Well now when i put the old one back in...its working fine, just the picture is all distorted as if something isnt connected right. All connections are fine as far as i can tell. There was a piece of "aluminum tape" id assume is what it is, prob for grounding purposes that isnt connected. It went from power supply board to chasis that covers the main board.
    Can that cause problems? No blown caps i can see, nothing else was touched at all.
    Any help would be appreciated.
  • Timebomb606
    • Aug 2013
    • 8
    Re: Vizio SV420XVT Distorted Picture Issue
    Anyone?
    • Mrx3750
      • Jul 2013
      • 311
      Either the new board is defective, or has the wrong software (programmed for a different LCD panel) Not sure what on your old board would cause a distorted image, except possible programming issues. Can you post a pic of the distorted image?
      • aaronwt6
        • Apr 2013
        • 855
        • US
        Pictures of the boards and whatever the TV is doing would be very helpful in getting you an accurate response. My first hunch though on the original board is that it is in working condition and that you have a tab bond issue on the screen resulting in a distorted picture. If you are getting a motion blur effect with ghosting of images then that's most likely the culprit. You probably were just lucky the first time and the tabs had reconnected briefly from moving it around.
        • aaronwt6
          • Apr 2013
          • 855
          • US
          You may have also just not reseated a cable well or have a tcon issue. Here's an example of one I got with a tab bond problem.
          https://www.badcaps.net/forum/showthread.php?t=28659
          • Timebomb606
            • Aug 2013
            • 8
            I have nothing like those pictures.
            Heres a few screenshots of the picture and the boards. There used to be a piece of tape from the yellow power supply to the cover over the main board. That wouldnt cause that image issue, right?
            Thanks again for your replies so far.
            • Mrx3750
              • Jul 2013
              • 311
              That is a strange one. You seem to have the correct colors, just the image rendering is off. I'm wondering if electro static discharge might be to blame? Maybe when you removed the old board, you just set it aside, or maybe even threw it in the trash? Then when you realized the new board was faulty, you rescued the old board.
              I don't think missing grounding tape would cause such a weird issue.
              • aaronwt6
                • Apr 2013
                • 855
                • US
                This is certainly something I haven't seen before. You'll have to wait for someone else to chime in on this.
                • Timebomb606
                  • Aug 2013
                  • 8
                  Alright, yeah when i removed the old board to install the new one. I just set the old one aside and then switched them back. Any idea if static discharge is an issue, is fixable?
                  • Mrx3750
                    • Jul 2013
                    • 311
                    Electro static discharge can do all kinds of crazy things to motherboards, which is essentially what your chassis board is, a specialized motherboard. Things I've seen are a frozen BIOS clock, and yes, weird video errors. Not quite like yours, but you get the idea.
                    Now as to how fixable it is, easiest solution for you I think is to send your new board back for a replacement. I'd wait until someone more knowledgeable sees this thread, but it's likely not easily fixed.
                    Then again, if you could find the firmware and do a firmware update, who knows?
                    • Timebomb606
                      • Aug 2013
                      • 8
                      Its just so frustrating that it was working perfectly fine. Didnt change anything and now its not working.
                      Doesnt seem like it anything related to power, both boards i have power on. New board doesnt show a picture, only backlight comes on, nothing else. Cant use the power button to turn off either. Have to unplug it.
                      Old board allows TV to be turned on, shows that messed up picture though.
                      • Timebomb606
                        • Aug 2013
                        • 8
                        So does anyone have a picture/diagram of what voltages the LDO's would have on this TV?
                        • Timebomb606
                          • Aug 2013
                          • 8
                          Anyone have any other ideas what to check to diagnose this issue?
                            The voltages are written on the regulator for example LM1117-33 or LM1117-18 indicate 3.3V and 1.8V respectively. Or, if it is not labelled, the output is not directly known, but you can check the regulator function: the voltage between pins 1 and 2 should be approx 1.25V (+/-0.05V)
                            • CyberPhoenix
                              Issue with picture quality of Sony bravia TV
                              by CyberPhoenix
                              Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                              01-22-2024, 02:08 AM
                            • gavric
                              Vizio M70-C3 Half picture is bad, main board on its last leg?
                              by gavric
                              Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                              When tv powers on vizio V logo shows nice on whole screen. picture 1
                              When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                              When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                              When i click video to start playing picture goes black(like when you change...
                              09-02-2021, 08:55 PM
                            • EazyBone
                              Vizio P759-G1, Tcon issue?
                              by EazyBone
                              Got this TV free. Guy said it tries to turn on and doesn't. I haven't seen this specific issue before but shown in video. Any way to test the screen to rule it out on these Vizio? Or anyone seen this issue before?
                              Any help appreciated
                              https://youtu.be/tPeV2Q7TXIQ?feature=shared
                              03-22-2024, 03:25 PM
                            • Tr0ll
                              by Tr0ll
                              Original T-con:
                              First replacement T-con:
                              10-07-2023, 07:48 PM
                            • ggil44
                              Vizio M65-E0 No Picture, No Sound
                              by ggil44
                              Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                              09-03-2024, 08:30 PM
