Samsung UN46D6420 Horizontal lines, now No Picture
  • tibimakai
    • Jan 2012
    • 3680
    Re: Samsung UN46D6420 Horizontal lines, now No Picture
    If I place the LVDS cable in it's "normal" place, I have only backlight on, no image at all.
      That's probably not the right place then...
      • tibimakai
        • Jan 2012
        • 3680
        This is what I don't understand, the connector/cable could have a bad connection?
          Due to how the LVDS is transmitted over that cable that is unlikely.
          • tibimakai
            • Jan 2012
            • 3680
            So, I should I try a T-con? That is cheaper.
            • tibimakai
              • Jan 2012
              • 3680
              I have ordered one. I will let you know how it goes.
              • tibimakai
                • Jan 2012
                • 3680
                This one looks almost(if not the same) as my problem and it looks like a T-con fixed it.
                https://www.badcaps.net/forum/showth...rizontal+lines
                • BluDuk
                  • Mar 2014
                  • 10
                  I have my un46d6420ufxza disassembled. What do I have to do to view the tab edge connectors on the led screen? Do i need to remove the black tape around the edge of the screen? What else after that?
                  • turbodude983
                    • Jun 2014
                    I have LA40D550 with same issue as OP, horizontal lines/ghosting is flickering in top 2/3 of screen only. Replace T-CON, issue persists. Caps look and measure capacitance fine. Next step is to check ripple on PSU rails with CRO, possibly check ESR of caps (if I can find/build ESR meter) or more likely check bonding of tabs like https://www.badcaps.net/forum/showth...LN52A530P1FXZA
                    • truwarrior22
                      • Nov 2014
                      Any luck? I have the same issue with Vizio M501D and will be replacing the T-Con later this week.
                      • noisykid
                        Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                        by noisykid
                        5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                        12-30-2024, 07:15 PM
                      • Ihandyrepair
                        Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                        by Ihandyrepair
                        Hi guys
                        I just started fixing 4k TV few months ago. so I am still learning a lot
                        I got this tv from friend complaint is ghosting or horizontal lines on image.
                        never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                        then it started to show the ghosting white image.
                        I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                        it has 3 thin small boards at the bottom of the...
                        12-05-2022, 04:18 PM
                      • x_orange90_x
                        Samsung UN46C8000XFXZA Horizontal lines
                        by x_orange90_x
                        I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                        I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                        07-15-2023, 05:06 AM
                      • porfyriadhs
                        Tv Samsung UE50TU Horizontal lines
                        by porfyriadhs
                        Hello to everyone. I tried the tape method to by pass the on and off problem for the Samsung tv I mentioned. But unfortunately lines starts to appear. My question is if someone knows how to fix the lines problem...
                        05-16-2024, 02:44 AM
                      • Runlinc
                        Samsung QE50Q60TAU - Horizontal screen lines
                        by Runlinc
                        Hi everyone, the tv was in a continuous reboot cycle. To get the best screen image i can I taped the VGH and VSS pins on the left side buffer board joining ribbon.
                        I am left with a good image apart from the black horizontal lines that I cannot get rid of.
                        I cannot find anything on the buffer boards that has shorted.
                        Do you think there is anything i can do to eliminate the lines, or are they caused by an internal panel short and the image cannot be impoved.
                        Many thanks for your assistance
                        05-14-2024, 07:40 AM
