Vizio V042L No Picture has backlights.
  • philliesfan30m
    • Aug 2013
    • 542
    Re: Vizio V042L No Picture has backlights.
    those readings were with the black lead of the dmm on the back of the regulator and each pin reading afterwards all 3 pins including the pin which does not touch the board! am i doing something wrong? if so a reply to bust my butt isn't needed! i noted exactly what i did!
      Black lead of multimeter goes on chassis, red lead goes on each pin, one after the other.
      • philliesfan30m
        • Aug 2013
        • 542
        ok will check again my bad.
        • philliesfan30m
          • Aug 2013
          • 542
          ok now here are the proper readings
          u15 2.08 3.33 5.03
          u16 11.03 0 5.05
          u17 2.07 3.31 5.03
          u19 1.25 2.49 5.04
          u20 .55 1.8 3.29
          u21 0 1.24 2.49
          u22 2.06 3.3 5.08
          u44 8.35 9.62 11.03
            The regulators look good to me.
            • philliesfan30m
              • Aug 2013
              • 542
              i checked the 4 mosfets on the inverter board and they read this way with the dmm on 2000k ohms
              q7 0,0,0
              q8 0,0,0
              q9 climbs up,0,climbs up
              q10 10,climbs up,0
              what else could i check?
              • philliesfan30m
                • Aug 2013
                • 542
                on q7 and q8 from pin 1 to 3 i get 0 and on q9 and q10 from pin 1 to 3 i get 10k are they bad and will they cause the problem i am having?
                  Those MOSFETs are bad, is the fuse on the inverter board good?
                  • philliesfan30m
                    • Aug 2013
                    • 542
                    yes fuse f1 is good. so all i have to replace are those mosfets?
                      With the inverter connected, do you have any 24V?
                      • philliesfan30m
                        • Aug 2013
                        • 542
                        no i don't have 24v on the inverter board with it connected only 3 pins showed any voltage 1 was 5.0 volts the other was 4.8 volts and the last was .2 volts i think they are the a-b-c pins from the psu
                        • philliesfan30m
                          • Aug 2013
                          • 542
                          1 is the 5volt standby and the other 2 are the a+b pins
                            With inverter power disconnected you do have 24V? Have you jumpered PS-ON yet?
                            • philliesfan30m
                              • Aug 2013
                              • 542
                              no i don't have 24v with inverter connected disconnected. i did jump 5 volt to ps-on with a 1k resistor before should i do it again?
                                Jump PSON to 5V with the 1k and disconnect the inverter(s). Do you get 12V&24V?
                                • philliesfan30m
                                  • Aug 2013
                                  • 542
                                  i get 24volts if i jumper 5volt to ps-on on the connector for the inverter power
                                  • philliesfan30m
                                    • Aug 2013
                                    • 542
                                    and i get 11.9volts on the connector that goes to the main video board
                                      And if you connect the inverter, I'm guessing it drops out. Only make the connection after disconnecting the power cord from the plug.
                                      • philliesfan30m
                                        • Aug 2013
                                        • 542
                                        yeah i don't have 24volts at the inverter board and now the orange light isn't on either with it hooked up with the jumper
                                          Well you won't have orange light if you disconnected power from main board.
                                          I'd suggest you replace those MOSFETs and look carefully at the controller chip on the inverter for signs of burning.
                                            LCD LED TV Service Menu Codes
                                            ALL LCD LED TV SERVICE MENU CODES
                                            Service Menu Code with Board Name
                                            China Universal Board / Jumper Board Service Menu Code
                                            Changhong Ruba Service Menu Code
                                            Ecostar LED TV Service Menu Code
                                            Orient LED TV Service Menu Code
                                            Haier LED TV Service Menu Code
                                            TCL LED TV Service Menu Code
                                            Samsung LED TV Service Menu Code
                                            LG LED TV Service Menu Code
                                            Videocon LED TV Service Menu Code
                                            Supra LED TV Service Menu Code
                                            Toshiba LED TV Service Menu Code
                                            Symphony LED TV Service Menu Code
                                            Veste/ LED TV Service Menu Code...
                                            10-31-2024, 03:58 AM
                                          • Ierwin
                                            Philips 58PUS7805 Menu working but no/weird picture from video sources
                                            by Ierwin
                                            I got a 58pus7805 that shows some weird behavior.
                                            The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                                            However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                                            I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                                            I managed to install the latest official firmware by holding the control button while plugging...
                                            03-10-2024, 12:50 PM
                                          • gavric
                                            Vizio M70-C3 Half picture is bad, main board on its last leg?
                                            by gavric
                                            Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                            When tv powers on vizio V logo shows nice on whole screen. picture 1
                                            When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                            When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                            When i click video to start playing picture goes black(like when you change...
                                            09-02-2021, 08:55 PM
                                          • csmith
                                            Vizio-D50u-D1 Pulsating Backlights
                                            by csmith
                                            This Vizio came in the shop with no backlights. Replaced all the strips with replacement from Shop Jimmy. Set now has backlights but lights pulsate on left side. Half the screen brightens up then goes to normal then repeats.
                                            Am I looking at a defective strip? Thanks in advance.
                                            11-07-2024, 02:56 PM
                                          • tusiime
                                            How to access Vizio m652i-b2 service menu
                                            by tusiime
                                            The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
                                            So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
                                            Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
                                            09-15-2023, 09:57 AM
