palsonic tftv815hd lcd inverter transformer!
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    just wondering if anyone can point me in the direction of this inverter transformer!
    board number- dac-24to42 rev-2c
    transformer number- 2874015400
    lcd parts don't have a comparable transformer and shopjimmy and ebay don't have the boards!
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
  • tw2005
    • Oct 2011
    • 6458
    Re: palsonic tftv815hd lcd inverter transformer!
    Try searching by LCD Panel model Number:
    CLAA320WF01U
    http://www.shopjimmy.com/dac-24t042d...t-inverter.htm
    The SJ photo is good enough to identify each component, maybe compare your board. Could be close.
    Sanyo LCD model LCD-32XR8DA may also have the same board/panel too.
    There may be a number of variants which may fit and do the same job.
    The transformer on the SJ board looks to be a different model but could be same size and pins. The PCB layout and components look much the same but check for yourself.
    http://www.ebay.com.au/itm/Inverter-...item3a6d29ee7f
    http://www.lcd-chip.com/ViewDetails10857.aspx
    If you look at this, shows same board as yours fitted to Dynex dx-lcd32-09. look at SJ and that link above also fitted to same model. Boards look the same different transformers used.
    http://www.usefulparts.com/tv-parts/...cd32-09-lcd-tv
    other models
    ELEMENT
    32LE30Q
    INSIGNIA
    NS-LCD32
    http://www.ebay.com.au/itm/DYNEX-DX-...item1c34c3779f
    http://www.ebay.com/itm/DYNEX-DX-LCD...item5654cbf224
    http://www.ebay.com/itm/DYNEX-DX-LCD...item5658e52641
    • attainteddragon
      • Apr 2013
      • 764
      • australia
      thanks tw, you have done it again!
      lcd-chip have the transformer! woo hoo!
      now i can finally finish another one that is laying around!
      fyi, the sony one wouldn't work, almost double the resistance, but i do enjoy the researching!
      thanks again!
      • learnmore
        Help choosing replacement transformer for Levoit 600S SMPS
        by learnmore
        Hello Community,
        I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
        Peace
        LM...
        11-04-2025, 09:35 AM
      • eccerr0r
        inverter H tree driver imbalance in an AC inverter
        by eccerr0r
        My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
        11-16-2025, 12:34 PM
      • ohren
        Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
        by ohren
        Hello!
        I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
        Measured voltages with no load:
        After rectifier diodes
        12V: 6.17 V
        5V: 5.67 V
        Secondary transformer pins AC measurement (really don't know if this says anything)
        12V: 2-2.5 V
        5V: 1.04 V
        I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
        03-18-2023, 10:33 AM
      • mikey5791
        Is it possible for transformer substitution?
        by mikey5791
        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
        My questions are
        1. How do i test to see if the transformer is in good working condition?
        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
        Hope you guys understand what i was asking. My intention is...
        11-03-2022, 02:11 AM
      • x_orange90_x
        by x_orange90_x
        01-29-2025, 09:24 PM
