Vizio e470va tv white logo then bright white logo nothing on scren
  • Altonwaldon
    • Aug 2013
    • 16
    • usa
    I have a vizio E470VA LCD TV when I got it it was already broken the screen looks ok not cracked when plugged in vizio logo turns white with light when attempting to start the set with remote or surface power button the logo gets brighter but the set does not start just gets stuck there. has any body experienced this with a vizio 47 ? should I start with the power supply or the main board with regard to testing . also vizio vt470m and vizio e470va any compatible parts in common, I have one of those with a cracked screen
    Re: Vizio e470va tv white logo then bright white logo nothing on scren
    Main board -- likely EEPROM/flash mem is corrupted -- it can be fixed by replacing the EEPROM/flash mem or main board.
    • Altonwaldon
      • Aug 2013
      • 16
      • usa
      purchased mainboard on ebay installed it today still the tv does not start in fact behaves the same as with other board (old one) installed checked voltages at psu output rails and got readings within range or higher on 5v contacts and almost nothing on 24v contacts and 12v contacts also you can see the toslink port on mainboard light up red after a few seconds turned on anyone have experienced these conditions also main ceramic fuse is good
        Check the PSON or REMOTE voltage. If it is changing when the set turns on but 12V/24V are low, the PSU is faulty, otherwise, the main board you received is also defective.
        • Altonwaldon
          • Aug 2013
          • 16
          • usa
          What readings should i be looking for at pson and remote am i looking to read something like 3v volts ?
          • Altonwaldon
            • Aug 2013
            • 16
            • usa
            i GOT THE READING FROM PSON AND REMOTE THEY ARE 4.76 WHEN ON MINIMAL WHEN OFF COULD CHANGING CAPS FIX THIS OR THIS SOUNDS LIKE SOME OTHER COMPONENT FAILURE
              I'd consider looking at this video.
              Different cause probably, but should give you some ideas
              http://www.youtube.com/watch?v=mWbrFcfazOA
              • aaronwt6
                • Apr 2013
                • 855
                • US
                Just thought I'd throw in my 2 cents here. I had this same TV a few months ago. There are several different main board / tcon / panel configurations. Make sure the main you are buying has exactly the same numbers on it. It took me 3 tries to get it right. Tried eeprom first and no dice then 2 separate main boards. Lost money on the set but it was a good learning experience. I've been through about 10 Vizio sets and all but one were main board issues.
                https://www.badcaps.net/forum/showth...t=28197&page=2
                • aaronwt6
                  • Apr 2013
                  • 855
                  • US
                  I saw a post you made yesterday Tom about the Vizio TVs and completely agree. The controls on them are crap. Picture, PS, everything else is top notch. In fact I believe some of the nicest pictures I've seen on both LCD and LED backlit sets have been from Vizio sets.
                  • n3lka
                    • Jan 2014
                    • 84
                    I just picked one up, same issue, and it looks like the inverter board is bad. No 24 or 12 V, pulled the cable from the inverter board, voltages came back. Found a shorted device, Q5 on the board. Trying to find a replacement.
                    Anyone have schematics for the inverter board? I'm trying to find information on it. The
                    device is AK45BP or AK458P. Looks like maybe from fairchild. Nothing on google anywhere.
                      Picture of this device? Maybe Alpha-Omega semiconductor.
                      • n3lka
                        • Jan 2014
                        • 84
                        My phone camera is only so good, so I posted two. One of the whole board and one of the bad transistor Q5. The board is a PPW-EE47NF-0.
                        Star Wars Marathon on here. Perfect background for working on TV's.
                          Could it be FDD8447L?
                          • n3lka
                            • Jan 2014
                            • 84
                            You nailed it!...Stupid me, I thought it was a date code....lol. I have another inverter board here from a samsung, going to see if there's a compatible mosfet on that one.
                            • n3lka
                              • Jan 2014
                              • 84
                              Nope, have to order the mosfet from ebay. 4 Pcs for 5 bucks and free shipping. Thanks for your help!
                              • n3lka
                                • Jan 2014
                                • 84
                                Ordered the mosfets, blew out again. I'm thinking a bad transformer, so I replaced the inverter board and it worked fine. Nice picture.
                                • jimfixit
                                  jimfixit
                                  • Sep 2014
                                  • 8
                                  I just picked up a E470VA on CL. Same issue. Inverter short would turn off the power supply. I replaced all 8 of FDD8447L. Now works great except a random reset. Next task, updating firmware.
                                  • symergy
                                    • Nov 2014
                                    • 12
                                    I also have a E470VA.
                                    Should I start another thread or use this one?
                                    Mine appears to have a burnt component near the bottom-of-the-board connector.
                                    • symergy
                                      • Nov 2014
                                      • 12
                                      Argh... I meant to say the bottom connector on the board at the center-top of the unit (marked 715G4226-T02-000-005F)
                                      • Daveleone
                                        Vizio VO42L, white logo, no backlight, no picture
                                        by Daveleone
                                        Hi all! I've got a Vizio VO42L. Plug it in, and logo flashes orange/white for a bit, then solid orange. Press power, and logo changes to white. There is no backlight.
                                        From reading some of the posts here I thought the inverter could have been the problem, but I've replaced it and still have the same issue. I noted that shining a flashlight on the screen shows nothing, so now I'm thinking main board?
                                        I took the following readings with the TV powered on. I also tried taking the readings with the CFL connectors unplugged - no change.
                                        Main board:
                                        Continuity across...
                                        02-20-2021, 04:52 PM
                                      • Super360
                                        Vizio E701i-A3 Vizio logo flashing then turns off
                                        by Super360
                                        Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                        07-25-2024, 07:06 PM
                                      • x_orange90_x
                                        Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                        by x_orange90_x
                                        I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                        12-28-2023, 06:26 AM
                                      • JaquesPratt
                                        Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                        by JaquesPratt
                                        I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                        This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                        07-16-2024, 01:04 AM
                                        MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                                        This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        09-06-2024, 07:46 AM
