14 blinks TC-P50ST30
  • nwflight
    • Aug 2013
    • 56
    Re: 14 blinks TC-P50ST30
    Ok , replaced Q402 and Q403 with new 30F131 and am too chicken to plug it in. Big lightning storm approaching VHF radio indicating strikes every few minutes.
    New SC board is clearing customs somewhere in Canada .
    Repaired board not short circuited on vsus pins any more and cannot find continuity from ribbon connectors to ground on SU ( buffer?) boards. Might give it another week. Would feel so good to have fixed this TV. I have 4 extra 30F131 if I end up not needing them.
    • nwflight
      • Aug 2013
      • 56
      I have 10 ohms to ground on SV46 connector to buffer board. The other 2 connectors are clear , SV46 rings the continuity buzzer on my multimeter.
      • tw2005
        • Oct 2011
        • 6458
        I don't understand, You need to be more specific. SC46, SD46 ? What pins?
        What do you get on pins 2,6,8 SU41 to gnd plate on buffer.
        pin 6,2,1 SD42 to gnd plate on buffer.
        • nwflight
          • Aug 2013
          • 56
          Sorry for being such a noob. Should I put the repaired SC card in the circuit for these tests? I cannot get any continuity to ground any where on the SD ad SU cards. I am using the screw on the top right as you face the SU card it is the only place that I can see the card to chassis connects.
          Hope the new SC card is here this week.
          • tw2005
            • Oct 2011
            • 6458
            No, just need to be sure there's no shorts on the buffer boards. Where was the 10 ohm reading coming from?
            • nwflight
              • Aug 2013
              • 56
              On SC46 5 ohms pin 1,3,5,7 to gnd .
              Don't know what I was talking about with 10 ohms and SV connector , sorry.
              • tw2005
                • Oct 2011
                • 6458
                1,3,5,7 are gnd
                • nwflight
                  • Aug 2013
                  • 56
                  I have an 18 inch alligator clip on my black lead so maybe that is the reading.
                  I think it is fixed. but the other card should be here soon . thank you for your help. I think I will keep my eye out for discarded plat screens.
                  • nwflight
                    • Aug 2013
                    • 56
                    Should the meter be on M ohms to test for shorted circuits?
                    I was just reading another thread repair got me thinking.
                    I have been using ohm scale.
                      Usually you'll have it in the lowest ohm range for short testing.
                      • nwflight
                        • Aug 2013
                        • 56
                        Thank you, I remember doing exercises in school measuring the output of meters so as not to damage stuff and can only remember enough to be afraid.
                        My new card should be here by Friday then I can compare readings.
                        • nwflight
                          • Aug 2013
                          • 56
                          Checked new SC card against repaired card and found some components that were shorted when compared to new card, so marked them and installed new card.
                          Still no screen illumination. Goes on and off with the remote now and it did not with original problem. Unplugged and checked for short at vsus SC and OK.
                          • nwflight
                            • Aug 2013
                            • 56
                            Wait ! I got something! Going to put the cover on and try it. So excited I wet myself!
                            • nwflight
                              • Aug 2013
                              • 56
                              Thank you , thank you , thank you, It works.
                              Had the brightness set to 100% should I lower this for longer life?
                              The fix was 59usd SC card plus 30usd shipping.
                              Prefer this picture to televisions in store.
                              Noticed the tv really puts static into the VHF at 123.2 HZ .
                              Now to find another project.
                              thank you for advising not to plug in repaired card , I think it still needs work.
                              • tw2005
                                • Oct 2011
                                • 6458
                                so what wrong, earth screws?
                                • nwflight
                                  • Aug 2013
                                  • 56
                                  I really didn't do any thing . Shut it down to read the manual then checked the ribbon cable and the wire type ribbon cables and tried it again and got the Vierra ribbon on the bottom of the screen. First time anything has been visible since the start. Putting the cover on now and have a spare SC Card and some 30 F131 .
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    maybe poorly seated ribbon, I've given myself a scare a couple of time at the SC board like that ripping those boards in and out on mine.
                                    what other bit were short on the old board? Some of those boards for sale were cheap, at $8 a pop for the transistors if this was my TV I'd still invest in a spare board, you could still try repairing yours but without a good one to compare too it may be tricky.
                                    Anyway, a happy ending,
                                    • nwflight
                                      • Aug 2013
                                      • 56
                                      I was testing from gnd to the legs on the pins and these were different when compared to the new card but then I had a component on the new card that was to gnd on both legs so I said to heck with it and put it in before I wrecked something.
                                      D642,D481,Q422,Q441 were either one leg to gnd or both as compared to the new card.
                                      Tv good now and bringing the 20 inch back to the dump but I am a bit nervous about my plasma now. Any recommended UPS ?
                                        A UPS will not prevent failure.
                                        One of the best things to do is install any firmware updates available for your TV.
                                        http://shop.panasonic.com/shop/model...s&support#tabs
                                        This may prevent future failures.
                                        Also, check all fans are clean. Make sure the TV has adequate airflow, especially if it is wall mounted.
                                        Turn TV mode from Dynamic into Cinema or Normal, and turn the brightness down a few notches.
                                        • nwflight
                                          • Aug 2013
                                          • 56
                                          Off to get sd card. my version is 2030 and it looks like if under 2222 should be upgraded. It is working . Hope I don't screw it up Thank you for the help.
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                            11-20-2024, 08:52 PM
                                          • Taurus12
                                            Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                                            by Taurus12
                                            Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                                            I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                                            i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                                            Any recommendation on what I have to do next? Thanks in advance
                                            06-10-2025, 05:05 PM
                                          • jchon
                                            Sony A1e 5-blinks help
                                            by jchon
                                            Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                            I found the service manual, which was critical to know where to probe.
                                            https://www.manualslib.com/manual/20...1e-Series.html
                                            With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                            Unfortunately the 5-blinks...
                                            06-28-2023, 11:52 AM
                                          • mmischni
                                            Panasonic Viera Plasma TH-42PX75U 7 Blinks/8 Blinks/burned P board?
                                            by mmischni
                                            Greetings friends,
                                            I have a Panasonic TH-42PX75U manufactured in 2007. It has been trouble-free until recently. One evening I turned it on and it then powered back off and gave 7 blinks.
                                            First a question about the blinks. Everyone only speaks of a single number of blinks. I noticed on my TV, it blinks one fewer times for the first group of blinks, then blinks the full number repeatedly. So for my first code in question, the TV switches off, blinks 6, then blinks 7 repeatedly. When I disconnected the SC board, the TV switches off, blinks 7, then blinks 8 repeatedly....
                                            09-06-2017, 08:52 PM
