14 blinks TC-P50ST30
  • tw2005
    • Oct 2011
    • 6458
    Re: 14 blinks TC-P50ST30
    Originally posted by nwflight
    Sc board on its way from shop jimmy. 80$ approx includes 30$shipping.
    Too late now, but did you open all those links?, SJ has a price match policy for identical item and wty in which case Rivervalley would fit those terms.
    Beat by 10%,maybe ring them back and you may get a price adjustment but you're obviously happy with your choice.
    There should be a buffer board test in the training manual.
    Also if you're keen, with the short transistors, are they marked 30F131?
    Read this post.
    http://www.austech.info/electronics/...u30a-help.html
    • tw2005
      • Oct 2011
      • 6458
      TNPA5336AB, TNPA5337AB are the buffers
      • tw2005
        • Oct 2011
        • 6458
        Same post as before, http://www.austech.info/electronics/...u30a-help.html
        It's 2 guys with similar issues, one got his old board going with 3 new 30F131 IGBTs, the other looks like buffer boards
        First one removed 3 dead ones and the one left fired the TV up! Risky move but a stroke of luck I say.
        Is there a section in that training manual for buffers tests? Slide 71
        Or in that post I give some pins to measure for the second guy, measure those resistances and post up readings.
        • nwflight
          • Aug 2013
          • 56
          6- 30f131. 3 test to ground 3 look ok.
          also have RFN20 and RFN10 And RF1501
          this is the number on the top legs toward you , there is another number under that number. Is this the number to use when trying to locate another transistor or ic?ounce you gave me the number then I could see it. Have not had luck sourcing these transistors yet. Had to go nap.
          Going out to get a magnifying glass for these 61 year old eyes. Ordered soldering iron from Amazon. Thank you for the help.
          • nwflight
            • Aug 2013
            • 56
            Could not read short circuit as per slide 71.
            • nwflight
              • Aug 2013
              • 56
              unsolder-ed and bent up the legs of Q401 and Q402 and short is gone from Sc2 pin 1-3. Looks like it is both of them , put the first one back and problem returned.
              Is the entire backside of the 30f131 soldered to the board.? IF so How does one get enough heat to get that fet off.? Time for a break.
              • tw2005
                • Oct 2011
                • 6458
                I used a 40W iron and good sized tip. Reflow some standard leaded solder first onto the metal tab backing. then heat up , you'll see it starting to heat and buble around the edges but since you've already lifted the other 2 legs that'll make it easy, so a pair of tweezers to grab it and heat until it comes free, don't use force it'll just slide when it's ready.
                Plenty of hits in EBAY for 30F131, I've used UTSOURCE in china but very slow delivery with std post.
                Could try direct from panasonic but more expensive or maybe a sub but I'd have to have a look and see what it's specs are.
                • tw2005
                  • Oct 2011
                  • 6458
                  Have you heard of this company?
                  http://richtechparts.com/i-4968-30F131.html
                  $2.49 USD
                  Item #:30F131 SMD
                  Item Name:30F131 SMD TRANSISTOR
                  Transistor SMD
                  Rich-Tech Electronics Components Ltd.
                  140-3757 Jacombs Road,
                  Richmond, B.C. Canada, V6V 2R3
                  Tel: 604-805-8392 or 604-272-4198 Fax: 604-272-4568
                  Email: sales@richtechparts.com
                  • tw2005
                    • Oct 2011
                    • 6458
                    ROHM RF,RFN are fast recovery high speed switching diodes. The numbers underneath are also part of the part number.
                    I find it hard to locate those exactly but you have
                    RFN20NS3W = 350V (Vr)20A single diode
                    RF1501NS3S = 350(Vrm)300v (Vr) 20A single
                    RFN10NS3S = 350V (Vr) 10A single
                    DG302 = DG3C302 Panasonic IGBT, VCES 330(V), IC 45 (A) , ICP(A) 250A, VCE(sat) 1.3v, tf 240 ns
                    R5007ANJ N MOSFET
                    Q661,600 I can't make out with the photo I have
                    • nwflight
                      • Aug 2013
                      • 56
                      Remarkable to wake up to this information, thank you.
                      I have fets coming from eBay from In British Columbia but do not know where.
                      8$ each but included shipping express.
                      I will leave the old ones on until parts arrive.
                      on my board: Q600 = C08N25
                      N
                      Q661 = RJP63G4
                      O M2P
                      026
                      • tw2005
                        • Oct 2011
                        • 6458
                        Well shame already puchased at that price, nevermind. RJP63G4 will be the SMD equivalent from RENESAS. 630V 40A N channel IGBT to the RJP63F3A TO220FN which I have on my boards.
                        C08N25 will be ROHM , RCD08N25 250V 8A N type MOSFET
                        So originally you said 3 shorted, was that Q401,402,403?
                        If you wait until the new board arrives, you could use that as a template to resistance check other areas of your faulty board, may help to repair it just in case other SMD components are also failed.
                        Otherwise when that short is removed the shutdown cct won't trigger straight away and apply power and blow a lot more which will make it very difficult to figure out .
                        • nwflight
                          • Aug 2013
                          • 56
                          Q402 and Q403 removed the short from vsus pins. There was nothing at Q401 position. I can read to ground on the other transistors some on both legs so I agree your suggestion to test with new board unless I can educate myself on what I should be getting from these other devices.
                          I removed the Q402 and Q403 without further damage but nervous about putting the new ones back on . Wondering why not one at Q401.
                          I see none at Q401 on the picture posted back a bit so I will put it out of my mind.
                          • tw2005
                            • Oct 2011
                            • 6458
                            Sorry, I opened up the wrong schematic, don't have exact one for the ST30, picture clearly shows No Q401. Trying work out the third transistor shorted when you said 6 30F131, 3 good, 3 short to gnd.
                            Just trying to get a picture of where in the cct they've shorted.
                            • nwflight
                              • Aug 2013
                              • 56
                              I think when I removed the second one the ground on the other one in question went away. I then put back the legs of the first one but it was still grounded.
                              So these two for sure ground the VSUS pins when in the circuit and test shorted out of the circuit.
                              What bothers me is that with my black lead on ground on the board and multimeter on ohms some of the other legs on the FET looking devices read no resistance to ground. I could see one leg but on a couple it is both legs even though the VSUS pins are ok. Unless it is just the circuit design and it will read that way. Sorry for rambling.
                              • nwflight
                                • Aug 2013
                                • 56
                                Board is in Chicago IL. On the way.
                                Is there a recommended power conditioning unit or UPS that one should use to protect one's TV investment.? I am thinking isolation xfer.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  I would think any UPS should help and or a surge board. I had my TV on an UPS when we literally had a lightning strike very close to the house.
                                  Don't know if the UPS helped but I never had the antenna connection protected.
                                  Antenna was connected to TV via the PVR.
                                  It took out the HDMI port on the PVR which also took out the HDMI on the TV main board. Luckily just the port connected blew, the others and Tv survived thank god.
                                  Lost about 3 lights, a fan, TV antenna and booster, and the Earth Leakage protection ELCBs no longer worked either.
                                  scared the hell out of us.
                                  • nwflight
                                    • Aug 2013
                                    • 56
                                    When my tv went off I was watching it and could hear the static from strikes on an aviation radi0 that I have on most of the time. The storms were 30 miles away and have had closer storms without any trouble. If I get this one going or get another I have to put some kind of protection on. Is putting protection on very common on this forum?
                                    Been in two stores today in Smithers BC. Most tv units are LED , almost all.
                                    Small town however, wondering if this is the trend? They look sharp and bright compared to my plasma that I miss so bad.Kids are still making payments on it.
                                    Hope you don't have any dogs with a lightning strike that close , mine goes nuts. Guy was just hit in Prince George BC watching a baseball game.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      No idea, but when I moved to my current location this year I knew I'd have to look into it.
                                      Basically we have 2 seasons this far north in Australia. Wet & dry, pretty warm year round.
                                      In the wet which would be your winter, storms and lightening are a regular event. It's a real lightning show.
                                      We're on higher ground and volcanic with high iron content, makes for heaps of strikes.
                                      • nwflight
                                        • Aug 2013
                                        • 56
                                        What is the neon light on the P board bottom left indicate?
                                        Just staring at the back while I wait for parts wondering how a spike could get through the P board to the SC to do damage.
                                          That is a surge suppressor, it will try to shunt away the high voltage.
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
                                          • Nairolf
                                            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                            by Nairolf
                                            I have a Samsung DM32D display.
                                            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                            Here’s what I have tried so far:
                                            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                            From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                            08-24-2025, 03:47 AM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            11-20-2024, 08:52 PM
                                          • Taurus12
                                            Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                                            by Taurus12
                                            Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                                            I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                                            i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                                            Any recommendation on what I have to do next? Thanks in advance
                                            06-10-2025, 05:05 PM
                                          • jchon
                                            Sony A1e 5-blinks help
                                            by jchon
                                            Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                            I found the service manual, which was critical to know where to probe.
                                            https://www.manualslib.com/manual/20...1e-Series.html
                                            With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                            Unfortunately the 5-blinks...
                                            06-28-2023, 11:52 AM
