Sharp Aquos LC-46A77M Power Problem
  • DjKrish
    • Oct 2012
    • 354
    • SG
    This tv is having some power problem that's seriously a bit weird. It turns on when plug in power cable, from red turns to green then after few seconds, the relay cuts off and nothing there after. When led was green, the picture was ok and sound was ok for few seconds till the relay clicks off and nothing at all form there. Have to unplug and plug it in after 10 to 20 minutes and it repeats the same process.
    Any kind human able to help me on this? Anyone has the service diagram? Already re-solder all the cold joints with flux. Still no luck. Any help will be highly appreciated.
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Re: Sharp Aquos LC-46A77M Power Problem
    Somehow i think the 5v standby is failing as it comes and then it dies off.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Check for any out of spec capacitors in the 5v standby circuit then
      Muh-soggy-knee
      • DjKrish
        • Oct 2012
        • 354
        • SG
        Already replaced the bad caps Still no go. I think the switching IC could be the culprit though.
        • DjKrish
          • Oct 2012
          • 354
          • SG
          Manage to replace the tny264pn IC, power came back, from red turn to green but no picture, and then red and green started changing lights and a few relay clicks and then no power again as usual. Looks like the IC is blown again. Replaced the caps around and still no go. Any idea anyone can help?
            The power relay which is turn on by the main board, so if you monitor the 5V STBY, is it always there and steady when the relay clicking?
            I cannot read the labeling around the connectors to see what they are, can you provide close up pictures?
            • DjKrish
              • Oct 2012
              • 354
              • SG
              I'm sorry I do not have a service manual for this model so I couldn't trace where to measure the 5v. I used my multimeter and measure the switching ic legs and it only showing 2v.
                Then we will need good closed up pictures of the board, whole both sides, then in small section so we can see the traces and able to read the component designators and any labeling of the connectors.
                For example:
                http://s807.photobucket.com/user/bud...?sort=3&page=1
                • DjKrish
                  • Oct 2012
                  • 354
                  • SG
                  • DjKrish
                    • Oct 2012
                    • 354
                    • SG
                    For example:
                    Have attached the pictures, pls have a look
                    • DjKrish
                      • Oct 2012
                      • 354
                      • SG
                      Updates, 470VAC present at the big caps
                      • DjKrish
                        • Oct 2012
                        • 354
                        • SG
                        Kept the unit cool for many hours then turned it on, it works fine with the picture and sound which only lasted for like 15 seconds then the relay clicks off and everything blackout there after. Cant turn on, cant switch on, nothing. Does this means that the power board is faulty? All caps replaced brand new, check all resistors, re solder all cold joints. Still no go. Can anyone help?
                        • DjKrish
                          • Oct 2012
                          • 354
                          • SG
                          Theres 4 units of K3569 Field Effect Transistor Silicon N Channel MOS Type and 1 unit of PQ30RV31 Variable Output Low Power-Loss Voltage Regulator on this board. Checked the k3569 for fault and all 4 of them reads perfectly fine on my meter. Unable to check the PQ30RV31 regulator though.
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            We still haven't checked the 5v standby smps circuit yet!
                            What is the part number of IC7905? It is the chip by that small transformer. This will be the 5v standby control chip. Once you tell me the part number, I can direct you to which pins you should test.
                            Muh-soggy-knee
                            • DjKrish
                              • Oct 2012
                              • 354
                              • SG
                              The part number is TNY264PN
                              Enhanced, Energy Efficient, Low Power Off-line Switcher
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                What is the voltage across pins 1 and 2?
                                Muh-soggy-knee
                                • DjKrish
                                  • Oct 2012
                                  • 354
                                  • SG
                                  It measures 6v ac across pin 1 and 2 after turning on the power. Pls note i measured this without plugging any of the sockets to the tv. Just the board only with power and the best part, the relay clicks on immediately upon turning on power without even being plugged to the tv. It clicks off when turn off power. I put the black probe on pin 2 and red probe on pin 1.
                                    See the STBY power supply output as indicated, monitor that Voltage and report the reading when the TV acts up and when it is working.
                                    • DjKrish
                                      • Oct 2012
                                      • 354
                                      • SG
                                      When the relay clicks, 4.86v present.
                                        How about when the TV is turn off (since this is STBY power supply, it is always running the minute you plug the TV into the AC outet)?
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • Duranitron
                                          Asus x512dk rev 2.1 power on problem
                                          by Duranitron
                                          When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                                          Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                                          11-26-2024, 10:22 PM
                                        • j120975
                                          Sharp aquos lc-40le820e power on problem
                                          by j120975
                                          Good afternoon to all of you. First of all sorrybfor my bad English. I have a sharp aquos tv ,and i m dealing this problem. If i leave the power cord disconnected,then it starts normally for one minute approximately. After that the tv restarts and only the touch panel lights working for about 10 seconds and only 1-2 seconds lights up the led panel. After that loop again. No signal lights in center. I think probably is a power supply problem . I can see 5 v ,13.3v in 4 pins . I m a mobile technician and i can follow your instructions if you yave some suggestions. Thank you in advance.
                                          04-09-2021, 09:51 AM
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          by sam_sam_sam
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
                                        • EazyBone
                                          LG OLED55C9PUA power problem
                                          by EazyBone
                                          Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                                          Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                                          I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                                          The power supply to t con is different story.
                                          This...
                                          06-23-2023, 07:43 AM
