Sharp LC-52LE830U Lightning Strike No Standby
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Sharp LC-52LE830U Lightning Strike No Standby
    My fault, if pin 5 is the lone pin on that side then I was mistaken on the pin labels on that side of the chip.
    Pin 1 = 166V
    Pin 5 = 0V
    Pin 7 = 166V
    Pin 8 = 166V
      It's still dead, Jim(John). Replace it and any resistor connected to pin 7/8 as it looks like they may have failed open too.
      • johnboy1313
        • Nov 2012
        • 1959
        will do
        • johnboy1313
          • Nov 2012
          • 1959
          Found a PSU on eBay for $45. I figured it was worth it to not have to spend the time fixing the old one. Looks like I didn't need the main board after all.
            The IC was only a few bucks but it depends on how many other components were damaged, good job fixing it. How's the picture on this LED-LCD compare to a good plasma? Sharp LED-LCD are supposed to be the market leaders.
            • johnboy1313
              • Nov 2012
              • 1959
              That was my concern. There's a chance that not many other comonents got zapped, but there's a chance that several other components, including those tiny little surface mount ones, got zapped. There's also a chance that something else would go out shortly after getting the old one working again. I figured for the money, it was worth it to not have to deal with it.
              I've only played one movie through it via the Netflix app but it seems to be pretty nice.
              • johnboy1313
                • Nov 2012
                • 1959
                Well, I held onto this one, not sure if I should keep it or sell it. I made the mistake of never checking the HDMI inputs. I had it in the basement and watched several movies via Netflix, A/V, and USB. I finally listed it for sale and sold it Sunday, just to have it come back yesterday because none of the four HDMI inputs worked. It looks like I need to replace the main board but I'm open to any other suggestions.
                  That would seem likely to me. Surge damage is nasty. If you can source the HDMI multiplexer, you may be able to get away with replacing only that, though it is not an easy job.
                  • johnboy1313
                    • Nov 2012
                    • 1959
                    http://www.partsimple.com/vhisii9387-1q-004-n-4.html
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      Tom, I bought another main board and it didn't work. 1-1, lamp error code. The seller refunded my money and let me keep the board. Do you think it's possible to remove the HDMI chip(s) and swap them?
                        Yes, but it will be a very difficult job. There -must- be a way to reset lamp error. Have you tried locating eeproms? Those are a lot easier to swap between boards, little 8 pin SMD things. 24Cxxx (xxx=16,256,etc...) marking typically. They probably hold the "there is a lamp error" fault.
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          I'll have a look. Thanks.
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            Here are the IC specs from the SM. Do I want the one that stores user settings or CPU settings?
                              You may as well do both.
                              Just make SURE not to get them the wrong way around.
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                IC8455 is an 8 pin EEPROM I swapped it and still have the 1-1 code.
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  The other is a 48 pin. I'm not really sure I have the skill to do a 48 pin IC
                                    That's a flash memory, probably won't be storing the 1-1 code. No other 8 pin EEPROMs?
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      I found another. IC2005, I swapped it. It powered on! I've gotta connect something to it to verify that the HDMI is working. Fingers crossed.
                                      • johnboy1313
                                        • Nov 2012
                                        • 1959
                                        IT WORKS! Tom you are amazing. Thank you!
                                          Fantastic, enjoy!
                                          It may be a good idea to invest in an EEPROM programmer for other repairs. I built one myself using a PICKit2 from Microchip.
                                          • Bardou Kari
                                            HP EliteBook 840 G6 – no power after lightning strike
                                            by Bardou Kari
                                            I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
                                            – Charger is OK and 19V is present at the motherboard.
                                            – No charging LED, no fan, no reaction.
                                            – I don’t see any 3.3V or 5V near the coils.
                                            – Battery is unplugged.
                                            – I’m new to board repair but can use a multimeter.
                                            I added a clear photo of the board.
                                            Any idea where to start or what to check next?
                                            Thanks a lot for your help!...
                                            07-01-2025, 10:45 AM
                                          • SluggerB
                                            Panasonic TH-50PX80 killed by lightning strike, help me save her!
                                            by SluggerB
                                            Yes it's a 17 year old Panasonic plasma!
                                            I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
                                            06-04-2025, 07:02 PM
                                          • SJX1290
                                            Sharp 50BL2AE stays on standby
                                            by SJX1290
                                            Hi,have Sharp 50BL2AE which is not powering, stays on stand by, White control led is permanently on, signal from remote is coming on board as well from power -mutifunctional button on back side. All power voltages seems to be ok. Backlight checked, working..
                                            Any ideas?
                                            12-10-2024, 01:17 AM
                                          • karthur
                                            Samsung UN60EH6000 wont come on after lightning strike.
                                            by karthur
                                            We had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
                                            I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
                                            When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
                                            Here is what I have checked.
                                            On the power supply board, 14pin connector:
                                            1 :12.7 Vdc
                                            3 :12.7
                                            5 :12.7
                                            7 :12.7
                                            9 :0
                                            11 :5.
                                            13 :5....
                                            11-01-2023, 06:18 PM
                                          • pbig
                                            advices for repairing Sony Bravia 32EX600 after lightning strike
                                            by pbig
                                            hi everyone,
                                            my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
                                            On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
                                            - the 450V/150uF capacitor voltage when plugged is normal at 394V
                                            - from connector CN6150 (15 poles)
                                            STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
                                            06-28-2023, 02:43 AM
