Vizio VO47L
  • mrdj204
    • Jul 2013
    Vizio VO47L
    I am looking at a TV for a friend of mine. I can usually find and replace bad caps, but as far as I can tell, there arn't any bad caps.
    When I plug the TV in, the organge vizio light glows orange. Pressing the power button doesn't change anything. It just stays in this standby position.
    Beyound replacing caps, I'm a tad clueless with TV repairs, any help would be great =)
    I also have an imgur album with a few pics from the two boards.
    http://imgur.com/a/s2uoj/#0
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: Vizio VO47L
    Sounds like you have 5V on the standby at least. Based on my Vizio experience the last few months I'm pretty certain its going to be the main board. To test this, you can unplug the wires going from the power supply to the main. Carefully jump a wire from the 5V standby pin on the supply to the PS-ON and BL-ON pins. Plug it in and see if the power supply starts up and illuminates the backlight. If so, I'd say you've pretty much narrowed it down to the main for sure.
    • fharris1977
      Vizio D50u-D1 Dead Set No Standby
      by fharris1977
      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
      12-28-2023, 10:25 AM
    • p-top
      Vizio, E60u-D3, no standby light, no ps_on
      by p-top
      Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
      main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
      PS voltages
      1 VSNS -2mV
      2-5 LED-OUT -2mV
      6-10 GND -2mV
      11 +16VS 16.29V
      12 AC-DET 3.929V
      13PS-ON -3mV
      14 +16VS 16.29V
      15 +16VS 16.29V...
      11-27-2023, 10:44 AM
    • x_orange90_x
      Vizio E550i-A0 no power, no standby light
      by x_orange90_x
      I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
      11-20-2023, 09:49 AM
    • shelby5041
      vizio d40f-j09 no pic no sound standby always clear
      by shelby5041
      hi
      anybody have experience with this model tv
      07-19-2025, 06:58 AM
    • SS454
      vizio e650i-a2 backlight flashes then turns off
      by SS454
      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
      panel: au optronics T650HVN05.4
      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
      https://www.shopjimmy.com/vizio-56-0...-power-supply/
      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
      08-20-2020, 03:57 PM
