Vizio XVT3D554SV Flashing logo, intermittent backlight, no sound or image
  • Thunder88
    • Nov 2012
    • 6
    • United states
    long time lurker, first time posting a thread.
    I picked up a dead Vizio XVT3D554SV 55" 3d tv last night for about $100. The man I purchased it from said it just off one day and he got frustrated and just bought another one without bothering to have this one looked at. The TV itself looks beautiful, not a scratch, ding, mark or anything.. looks like it just came out of the box.
    Here are the symptoms:
    When first plugging in, system does the normal orange/white flashing logo for about a minute, then it goes solid orange. Pushing power button on remote causes logo to go white, and sometimes the backlight turns on. Last night when I got it home I did the 30 second reset and upon turning it on I briefly saw the vizio splash screen and then it went away, followed by the backlight flickering and turning off. I tried resetting it a couple more times and I never saw the logo again, though the backlight turned on a couple times, and flickered and kicked off a couple times.
    Today, I pulled the back off and did a full inspection of caps and chips. I saw no obvious heat damage, bulged or leaking caps, poor connections, etc. the first couple times I tried to fire it up I did get the backlight and could turn it on and off with the remote, but after a few times the backlight no longer comes on and the remote no longer can turn it off. After the initial plugging in and turning on with the remote the unit now does a constant cycle of trying to turn on (white logo for 90 seconds), then turning off and doing the orange/white flashing logo thing.
    Diagnosing:
    I am seeing correct (I assume) voltage at both sides of the fuses on all boards. The following readings were taken during the white logo part of the cycle, during the orange/white flashing part the only voltage that holds is the 5.1v circuits. During the "on" part of the cycle the inverter board LEDs are on (LED1 constant, LED2 flashing).
    The T-com board has 5.1v (f4), 11.98v(f5), and 11.98v(F6) at its 3 fuses.
    The main board has 11.98v, 18v, and 5.1v at its 3 fuses.
    The inverter board has 28.5v at its 2 fuses. disconnecting the t-com board, the inverter board, or both at the same time doesn't change the on-off cycling.
    Any suggestions or test voltage information would be greatly appreciated.
    Thank you for your assistance.
    Jason
  • kevinm34232
    • May 2012
    • 1884
    Re: Vizio XVT3D554SV Flashing logo, intermittent backlight, no sound or image
    Had a Vizio SV370XVT with similar issue. Replacing main board fixed. I assumed but not sure that it was a corrupted eeprom.
    • Thunder88
      • Nov 2012
      • 6
      • United states
      damn.. I already bought a t-comm board on ebay. saw a few cases similar to mine and they solved it with t-comm boards. well, guess I can just resell it myself.
      • Thunder88
        • Nov 2012
        • 6
        • United states
        Tcomm board will be delivered today, but I suspect it won't solve the issue. Is there any way to re-flash the eeprom or acquire and solder one in myself? I've been doing quite a bit of searching and there doesn't seem to be much repair info on this tv.
        • Thunder88
          • Nov 2012
          • 6
          • United states
          Well, turns out it was the t-comm board! Swapped it in and it fired right up, no problems. Figured anyone else who has a similar issue to mine might find the solution helpful.
          • Cryhavoc
            • Jul 2013
            Thunder,
            I have the 47" version of this TV that has the same problems you describe. Just out of curiosity, with your old board out of the TV, did you ohm/continuity check the fuses?
            My problem started yesterday when the image on the screen went wacky. Rainbow colored vertical strips vertically through the video. The video itself was sorta negative image looking. It had done this once in the past but turning it off and back on again fixed it. This time I got a dark screen and the visio logo would cycle orange/white. I had to unplug it to tun it off.
            Now, all I get is the visio logo is orange when I plug the TV back in. I can turn it on with the remote but the only thing that happens is the logo turns white. After a while it will flash orange/white. If do nothing, it go white again and repeat the cycle. I can't turn it off with the remote.
            From all I've been reading (your description is the closest to mine) I'm pretty sure my T-con board is the problem. When I retrieve my meter from work I'm going to see if I can find the problem with it.
            • Thunder88
              • Nov 2012
              • 6
              • United states
              No, though I had already done that during all the diagnostic tests I performed trying to figure this out. Fuses are good on the tcomm board, voltages were clean, etc.
              I'll pop the covers off that board and see if there is any obvious damage. Have you had any luck finding test points or any other diagnostic documentation for these boards? I would love to be able to repair this board so I have a spare in the future.
              • CarlosR
                • Aug 2013
                Originally posted by Cryhavoc
                Thunder,
                Cryhavoc,
                I am hoping on good news.
                Any luck? Did you get to replace T-Con board. This started with me yesterday.
                If I shut down and force reset it will come back. But it is staying up for shorter sessions now 20~ minutes.
                • viziojunkie
                  • Jul 2015
                  I also am having issues with my XVT3D554SV. A few days ago we came home and began watch tv. Suddenly our sound went out. We worked on it for hours. Hard resets, unplugging EVERYTHING, we even left it powered down and completely unhooked from everything for an entire day. Still no sound. The picture however is still flawless. I tried every input on the tv and could not get sound through any of it. I checked through the menu to make sure all the settings were right, turned off and on TruVolumn and so forth, we got nothing. I even paired it with a Bluetooth sound bar and still NO sound via Bluetooth. We are currently bypassing the TV's audio through an optical out to a sound bar from out Apple TV. We took the back off of the tv and everything looks great, no burnt smell, nothing swollen. The TV is wall mounted and in October of 2014 a burglar attempted to pull if off the wall but had no luck. What could be the cause?
                  • Super360
                    Vizio E701i-A3 Vizio logo flashing then turns off
                    by Super360
                    Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                    07-25-2024, 07:06 PM
                  • Bob1394
                    Vizio M65-C1 | Logo appears for 10 seconds then off
                    by Bob1394
                    I have used the search, and am stumped.
                    My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
                    I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
                    https://www.badcaps.net/forum/showthread.php?t=81088
                    https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
                    Observations
                    1) [Interaction] Power turned on via TV button (or remote)...
                    02-08-2023, 01:03 PM
                  • x_orange90_x
                    Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                    by x_orange90_x
                    I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                    12-28-2023, 06:26 AM
                  • JaquesPratt
                    Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                    by JaquesPratt
                    I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                    This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                    07-16-2024, 01:04 AM
                  • STKR123
                    Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                    by STKR123
                    As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                    I wonder if re-flashing the BIOS might be of any use here.
                    As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                    There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                    11-03-2024, 06:58 AM
