Lg 42lc7d
  • InstrumentTech
    • Jun 2013
    • 8
    Lg 42lc7d
    I have a LG 42LC7D tv that I picked up. When I first got it, It had trouble turning on. take a few times switching on and off before it would actually stay on. After some research, I bought a power supply repair kit off ebay and I replaced the caps.
    Now when I turn the tv on, it comes on, but it cycles on and off every few seconds. Say 2 seconds on, then 2 seconds off.
    Any ideas of what could cause these?
    Thanks for any info.
  • signup
    • May 2013
    • 189
    Re: Lg 42lc7d
    Marty Parish has put a pdf up for this fault
    https://www.badcaps.net/forum/showth...ight=LG+42LC7D
    • InstrumentTech
      • Jun 2013
      • 8
      Re: Lg 42lc7d
      Thanks, appreciated.
      I see that is more for the green light flicking on and off. My problem is that the picture itself is cycling on and off, same type of problem?
      • signup
        • May 2013
        • 189
        Re: Lg 42lc7d
        Have you checked the coils to make sure they are the correct ones or removed and jumped the dodgey coils, I know the initial fault on the thread listed is flashing green led but the bulletin does state shut down and restart
        I am sure it is worth the rework to rule them out
        • martyparish
          • Dec 2012
          • 313
          Re: Lg 42lc7d
          I'd say it's a good chance it's those coils. The symptoms were erratic for me. Couldn't get it to power on first and replaced the coil that's directly on the power feed and that was fixed. Then other odd problems commenced. In the end, I jumped more of the coils and the TV was fixed. I can't remember, but I believe I jumped all mentioned coils from the PDF.
          You should be able to test them by checking continuity from the small pins on the side of the component to the main pins on either end.
          • ksandbergfl
            • Aug 2015
            • 3
            Re: Lg 42lc7d
            Hi, I have a LG 42LC7D that is exhibiting the OP's problem -- the backlight cycles on/off every 2-3 seconds. Otherwise the TV appears to be working properly.
            I looked at the PDF, and for the 42LC7D it reads "Remove the coils with ref# L729, L741, L742, L743, and L744 and install jumper wires". Is there a schematic somewhere that shows the positions of these coils? Also -- can I use standard jumper wires or do I need a certain gauge of wire?
            Thanks for any help/advice!
            ---- Keith
            • ksandbergfl
              • Aug 2015
              • 3
              Re: Lg 42lc7d
              ---- Keith
              I read the PDF again... since I have the 42LC7D, I need to look for L4010,L4011, L4012, L4203, and L4206. Still can't find 'em
              • ksandbergfl
                • Aug 2015
                • 3
                Re: Lg 42lc7d
                I found them! Cripes, you need a big magnifying glass to see them! On my TV, someone has already jumpered L4010, L4011, L4012, and L4203. Looks well done, like a factory repair. I will commence jumpering L4206 and L4204, as the PDF suggests, and let you know how it turns out.
                • jimmler
                  • Jan 2012
                  • 4
                  Re: Lg 42lc7d
                  I hate to sound like an idiot, but which board are those coils on? I have the same set with the same problem.
                  Thanks!
                  -Jim
                  • jimmler
                    • Jan 2012
                    • 4
                    Re: Lg 42lc7d
                    Disregard my request. My set was built in 2008 and is not affected by those coils. Stay tuned for another post for assistance.
                    -Jim
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      Re: Lg 42lc7d
                      these are on the main board but maybe really small parts
                      • PTCrew
                        A1465 820-3435-B Fan spins on and off
                        by PTCrew
                        So I'm quite new to board level Macbook repairs, done a few backlight fixes however I'm tackling my first "Does not boot" issue, kind of feel like I've jumped in the deep end with this one.
                        This board has no real signs of liquid damage apart from a few brown test points.
                        All that happens is the fan will spin for about 1 second, and then stop and will continue to cycle like this indefinitely.
                        Here are all my current readings:
                        PPBUS_G3H - 8.6v
                        PPBUS_S5_HS_COMPUTING_ISNS - 8.6v
                        PPBUS_S5_HS_OTHER_ISNS -
                        02-27-2020, 08:24 AM
                      • twonk9098
                        Lenovo Legion 5 high fan spin turns off after 34 seconds
                        by twonk9098
                        I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                        I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                        I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                        I have tried a few new bios but exactly...
                        07-14-2024, 11:19 AM
                      • applejuice95
                        MacBook - 2021 A2485 - 16 inch - 820-02100-A - No Boot / No Power
                        by applejuice95
                        Hi there, currently working on 820-02100-A logic board - No boot Chime, no Power on. - Very Minor Liquid Exposure - All cleaned with IPA , did a partial ultrasonic as well . Clean and dry.
                        MagSafe - Orange light cycles off then back on every 5-7 seconds
                        USB-C Ports - All 3 get to 19.9V/20V - .5A then Cycle ever 5 seconds.
                        All 4 CD3218 Chips have been checked at their LCD-CORE 3V5 and 1V5 lines at the local Capacitor, all are getting 1.5 and 3.5V But each have a different Voltage drop when the board cycles.. See below
                        (PP1V5_UPC_LDO_CORE) - AT EACH CD321...
                        02-13-2025, 09:45 AM
                      • liquidzorch
                        Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                        by liquidzorch
                        Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                        10-18-2024, 05:19 PM
                      • Rick_1234
                        LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                        by Rick_1234
                        Good evening, gentlemen.
                        I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                        To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                        https://drive.google.com/file/d/1L6S...ew?usp=sharing
                        Things I tried
                        - Bought a new AC adapter thinking that was the problem but the problem...
                        06-22-2024, 04:44 PM
