Screen flashes for half sec and shuts down
  • chevy56
    • Oct 2011
    • 17
    LG 50PK750
    The screen only flashes for half sec and shuts down.Checked alot of diodes on power supply and checked good and no bulged caps.If I just knew what board to order.
  • capkid
    • Oct 2010
    • 1339
    Re: Screen flashes for half sec and shuts down
    This might help: https://www.badcaps.net/forum/showthread.php?t=17809
    LG Plasma Mal-Discharge Correction Service
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
    • JunkmanJimbo
      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
      by JunkmanJimbo
      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
      No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
      Please help. Thanks in advance!
      08-12-2025, 11:45 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • valvashon
      LG 55UH6150- trouble powering up, then half lit screen (pictures!)
      by valvashon
      The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
      Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
      11-24-2024, 12:08 PM
    • Raulnn
      TD Systems K50DLG12US half black and half white screen
      by Raulnn
      good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
      By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
      01-20-2024, 04:49 PM
