VIZIO VX37L will not scan Digital channels or respond to up/dn channel changes
  • pinballpuk
    • Jun 2013
    • 9
    I recently acquired the subject TV at the swap meet for $20. It would turn on and then off. After reading similar posts & threads I checked out the PS and its working as advertized. I then read about the possibility of the TV being turned of last while using the PC input. I connected my laptop to the TV and then turned it on and it worked. I then changed the input to cable and attempted to perform a channel scan. The analogue channels scanned ok and when it finished I expected it the digital channels next.
    However, the digital channel scan would not start.
    I also noticed that the channels would not change when using the up / down buttons on the remote or on the tv side panel.
    I could change the channels by pressing the number pad on the remote.
    I tried to perform the factory reset steps but I wasn't successful. I didn't see an "F" on the menu screen.
    These are the clues I've noticed so far.
    Any help would be appreciated,
    Best regards,
  • pinballpuk
    • Jun 2013
    • 9
    Re: VIZIO VX37L will not scan Digital channels or respond to up/dn channel changes
    When I was trying to scan the channels the TV was connected to my TW Digital Cable.
      A regulator, 1.2V, on the main board can sometimes fail causing this.
        "VIZIO VX37L" Does this one has two antenna input connections? one for cable and one for Over the Air Digital signal.
        • pinballpuk
          • Jun 2013
          • 9
          Budm,
          This TV has only one F connector and it is used for both the Analogue and Digital signals.
          tom66,
          Thanks for the input, would you be able to provide your best guess where a potentially faulty 1.2V regulator on the main board might be?
          Thanks for your help guys,
          • aaronwt6
            • Apr 2013
            • 855
            • US
            Tom,
            This is the same TV I was working on a couple weeks ago. Unless I overlooked one, I don't recall any 1.2V regulators on the main board.
            https://www.badcaps.net/forum/showth...ighlight=vx37l
            Again, I could have overlooked one.
            • aaronwt6
              • Apr 2013
              • 855
              • US
              There were however a few 1.8v regulators
                Originally posted by aaronwt6
                Tom,
                I think I'm getting confused with another model norcal715 recently repaired.
                • aaronwt6
                  • Apr 2013
                  • 855
                  • US
                  Gotcha. Just didn't want any confusion. I certainly have no idea on the actual issue though. Certainly sounds like a main board issue but I wouldn't know where to start.
                  • pinballpuk
                    • Jun 2013
                    • 9
                    Hello aaronwt6,
                    Were you able to accquire a schematic for the main board of the VX37L while you were repairing one not too long ago?
                    Best regards,
                    • pinballpuk
                      • Jun 2013
                      • 9
                      I've removed the mainboard and I'm looking for an obvious problem and haven't see one yet. Perhaps I can get my hands on a known good mainboard P/N: 3637-0012-0150(3c), and install it to see if the problem goes away. I've been reading various post and there are some with similar issues of not being able to scan digital channels.
                      • Tvbob
                        tvbob
                        • 204
                        firmware problem.
                        • aaronwt6
                          • Apr 2013
                          • 855
                          • US
                          Never looked for a schematic pinballbuk. I just found that it had no 12V/24V output on the power supply and changed it. I was going to attempt a repair but found the board so cheap I just bought the whole thing.
                            Pictures of this main board and the list of the voltage regulators readings?
                            • ecking767
                              • Oct 2009
                              • 492
                              Originally posted by Tvbob
                              firmware problem.
                              I totally agree, I had an Vizio GV42LHDTV with the same problem. I replaced the mainboard. Also you may want to make sure your replacement board is at the latest revision before buying.
                              • pinballpuk
                                • Jun 2013
                                • 9
                                I can supply a picture of the mainboard later this evening.
                                Is there a list of the regulators by reference designator for the devices on the Mainboard?
                                • pinballpuk
                                  • Jun 2013
                                  • 9
                                  Here are the pics and the data. I noted on the LDS table when there was a resistor near the Adj pin on the regulator. I also noted on U10 where the Adj voltage was Zero on this main board and others I saw had a value of .33 for example.
                                  I appreciate the help,
                                  Best regards,
                                  http://s1289.photobucket.com/user/pi...3ba7b.jpg.html
                                  Last edited by pinballpuk; 06-22-2013, 11:59 PM. Reason: trying to fgure out how to add pictures
                                  • pinballpuk
                                    • Jun 2013
                                    • 9
                                    Is anyone else able to see the pictures and LDO readings?
                                    • gdblanford
                                      • Nov 2016
                                      Wondering if this was resolved or found a fix. I have the same problem with the scanner. Here are my readings, I have no other issues with the TV just doesn't get any channels. Won't find any analog either in fact.
                                      Readings with TV on
                                      Name Reg Type IN OUT Ground Exp Specs/Tolerance
                                      DU2 33L 5 3.28 0 3.27
                                      DU3 25L 5 2.5 0 2.48
                                      DU4 AMC1117 adj 3.34 1.24 0 1.25
                                      U10 18L 3.28 1.8 0 1.78
                                      U16 25L 5.02 2.49 0 2.48
                                      U18 AMC1117 adj 3.27 1.49 0.25 1.50
                                      U4 33L 5.05 3.27 0 3.27
                                      U5 AMC1117 adj 3.27 1.95 0.7 1.95
                                      U6 33L 5.05 3.27 0 3.27
                                      U7 18L 3.27 1.8 0 1.78
                                      U8 33L 5.02 3.28 0 3.27
                                      U9 18L 3.28 1.8 0 1.78
                                      I've done the Hard tuner reset and the RGP input attempt with no avail.
                                      • Eagle72
                                        • Dec 2016
                                        Same problem on mine
                                        does everything except scan/display digital channels
                                        • dicky96
                                          Hitachi V19B01922 Channel Tune problem
                                          by dicky96
                                          Hi Guys
                                          I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                          He also has an LG TV, so three screens in the bar
                                          I installed three Satlink ST-6503 DVB-T Modulators
                                          This model https://www.aliexpress.com/item/32916553905.html
                                          These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                          02-09-2023, 09:20 AM
                                        • rustinjust
                                          Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
                                          by rustinjust
                                          My tv will work for a while and change channels with the remote as it should but then it will stick on one channel only and work ok but it won't change channels. I have tried unplugging it for hours and whilst unplugged pressing the power button on the tv to reset it.
                                          The volume button on the remote still works but it just won't change channels once it decides to stick on one channel
                                          It has built in basic freeview tv here in the uk, I've tried doing an automatic search to reset the tv but nothing works.
                                          I have to turn the tv off and then on again with...
                                          09-28-2023, 12:23 PM
                                        • BOSCHNJAK
                                          by BOSCHNJAK
                                          ABOUT ME INTRODUCTION FILE
                                          2
                                          024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                                          2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                                          2022 BEV, PROJECT ?
                                          2021 BEV, PROJECT ?
                                          2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                                          2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                                          12-28-2023, 02:09 PM
                                        • dicky96
                                          I need to block a UHF channel but not sure how to do it
                                          by dicky96
                                          Hi guys
                                          I couldn't really find a section on the forum for this question so I guess I will put it here
                                          I do a lot of work in one of the local apartment hotels (an apart-hotel they call them here)
                                          Mostly I am maintaining the equipment in the 'TV' room or at the pool bar
                                          Anyway, I have a problem with the system in the TV room - most of this was a system I 'inherited' off the previous technician who no longer lives on the island
                                          Basically they have (see pic it probably explains it better) the following system. The UHF cabling is daisy chained...
                                          01-31-2022, 05:24 AM
                                        • sima112
                                          Marantz pm 6005 right channel not worknig
                                          by sima112
                                          Hi guys,
                                          I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
                                          01-30-2023, 12:11 PM
