I need to block a UHF channel but not sure how to do it
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    I couldn't really find a section on the forum for this question so I guess I will put it here
    I do a lot of work in one of the local apartment hotels (an apart-hotel they call them here)
    Mostly I am maintaining the equipment in the 'TV' room or at the pool bar
    Anyway, I have a problem with the system in the TV room - most of this was a system I 'inherited' off the previous technician who no longer lives on the island
    Basically they have (see pic it probably explains it better) the following system. The UHF cabling is daisy chained through all the modulators/transmodulators adding more DVB-T MUXes to the incoming Aerial Signal like so:
    *Incoming DVB-T (Spanish TV) from TV Aerial (numerous MUXes)
    * UHF Antenna Mast Head Amplifier
    *Incoming UK TV from satellite 27.5W + 19.2E, 4 receivers connected to quad input DVB-T modulator outputs 1x DVBT Mux
    * Incoming UK TV (19.2E), plus 3x IPTV (Sweden, Norway, Finland) connected to quad input DVB-T modulator outputs 1x DVBT Mux
    * Dual Transmodulator German satellite TV 19.2E, outputs 2x DVB-T Mux
    * Dual Transmodulator French satellite TV 19.2E, outputs 2x DVB-T Mux
    * Quad Transmodulator German satellite TC 19.2E + Italy satellite TV 13E, outputs 4x DVB-T Mux
    * UHF Power Amplifer outputs all MUXes combined (approx 75 TV Channels to 120 apartments over 5 floors plus communal areas/restaurant/pool bar, via 'Cab boxes' on each floor
    So all this was working fine..... until it seems there is a new terrestrial TV service on the same frequency (or adjacent frequency) as one of the MUXes on the Quad Transmodulator, causing four German TV channels to continually glitch/break up. I can prove this by disconnecting the TV aerial and the German channels are all OK then but obviously I have no Spanish TV.
    So I can see two ways of fixing this - but both have their disadvantages
    1: Retune the affected MUX to another channel frequency. The problem with this is that someone then has to go to all 120 apartments and re-scan the TVs. This means waiting for the apartments to be free so as not to disturb guests. Also this would most likely cause more channels to be added from the Spanish TV Aerial (assuming a new transmission caused the problem) which affects the channel order / channel numbers which then means having to reprint all the TV channel lists that go in a welcome folder in each apartment. Assuming it takes 15 minutes to visit each apartment, turn on the TV, re-tune it, change the channel listings in the folder, turn off the TV - then it is going to take 30 hours or more to complete the job. That's wages and time.
    2. Fit a blocker or filter between the Aerial and the first DVBT Modulator (before or after the UHF Mast Head Amp) that removes the signal on that RF channel. This should work fine but I tried to google for such an item but the problem is I can't seem to find what I need, possibly due to not knowing exactly what to search for. Preferably something I can choose to select and block 1 UHF channel (channels 22-69)
    3. Some other good idea I didn't think of?
    Hopefully the attached pic shows better how this all works
    Cheers
    Rich
    Follow me on YouTube
    Learn Electronics Repair
    • 31316
    Re: I need to block a UHF channel but not sure how to do it
    a notch filter may do it,
    but frankly all that crap is unreal.
    i would have just used a pair of dishes and a bank of 16way distribution units
    put a sat reciever in each room.
    the only downside is each room needs it's own feeder from the switch
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      @stj
      What you say does not make a whole lot of sense because:
      The Spanish channels are terrestrial (yes could also be received on satellite at 19E or 30W but would then require even more DVB-S -> DVB-T transmodulators and they are expensive.)
      Three of the UK channels are on a satellite at 27.5W (needs special BISS decoders to unscramble them) and a 1.8m dish to reliably receive the signal
      The other two UK channels are on 28.2E (Sky TV pay channels requiring two official receivers and subscription cards) plus a 3m dish
      German, Italian, French are all FTA but needs two dishes, one on 19.2E (80cm) with quatro LNB and the other on 13E (1.5m) with single LNB
      Norway, Denmark, Finland TV are impossible to receive here on any size dish so required an IPTV solution
      So what you say just wouldn't work I guess you just didn't appreciate the complexities involved
      Having said that where can I buy a suitable notch filter to get rid of the troublesome terrestrial interference? Ifound this o nAmazon but it does not seem to be available
      https://www.amazon.com/Tunable-Filte.../dp/B072K6BNP1
        • 31316
        i have no idea, you need to know the exact center frequency, and how wide you have to block without clipping surrounding muxes.
          • Jul 2011
          • 6070
          Take a look at this website link page
          https://fado168.com/us/merchant/B07H...-f-connectors/
          I would try to get in touch with them and see if they can help you to getting one
          support@fado168.com
          • eccerr0r
            old X58 triple channel board... memtest86 memory speed?
            by eccerr0r
            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
            06-28-2025, 09:06 AM
          • spleenharvester
            Reverse engineering of 18650 4-channel tester
            by spleenharvester
            Hi friends
            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
            05-04-2025, 02:43 AM
          • mikey5791
            Help on car amplifier only one channel works
            by mikey5791
            Hi all forum members,
            Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
            My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
            08-06-2025, 10:36 PM
          • dicky96
            American Audio VLP1500 Distorting on one channel
            by dicky96
            Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
            Protection and Clip LED are off
            There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
            I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
            The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
            07-13-2022, 05:25 AM
          • sima112
            Marantz pm 6005 right channel not worknig
            by sima112
            Hi guys,
            I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
            01-30-2023, 12:11 PM
