Samsung LE26R88BD Strange Fault (Main Board??)
  • signup
    • May 2013
    • 189
    Hi
    Got this Sammy and it is doing a strange fault.
    When cold the tv works fine then after 10 minutes the TV shuts down, when shutting down the backlights flash and it gives the impression the screen tabs need reseating...The TV will then turn itself back on and work for approx 1 minute and the whole process will start again, where it will shut down and give the impression of tab bonding fault
    The strange bit is that if I turn on blue screen the tv will sit and work fine...been running for 1 hour now no problems
    If I turn blue screen off and just put analogue channel and go mad watching static the tv will not fault
    If I plug in a hdmi connection with moving images the tv faults, when it is on DTV from cold it will work fine, once the fault starts the DTV will never come back on just a blank flickering screen...let it go cold again DTV works fine for 10minutes
    I have unplugged the T con and Inverter and the fault still persists, I also spotted that RM801 had little black specs on, looking through other posts this is a common fault, changed that to be on the save side.
    So to put it short the tv is only shutting down when it is processing moving images on the screen..if that makes sense
    The main board is BN41--00813
    Thanks in advance
    Re: Samsung LE26R88BD Strange Fault (Main Board??)
    These boards do have quite a few problems with bad caps. Have you ruled them out?
    • signup
      • May 2013
      • 189
      Cheers Tom, sorry did you mean the caps in the psu?
        Yep.
        • signup
          • May 2013
          • 189
          Right OK I will start with the ones they sell in the repair kits CM860, CM851, CM852
            Or you could check the power supply voltages and see if they are OK. If they are OK, they are not the fault. Just because I said they may be at fault doesn't mean they are actually the cause.
            • signup
              • May 2013
              • 189
              Hi, I have changed the caps and still the same, here is a video of what the tv is doing...it has now started doing it on blue screen now too
              http://www.youtube.com/watch?v=XiNjhDXOCHE
              The only voltage that dips when the fault occurs is the 5.3v line which drops to 3v and then instantly stabilises at 5.3v
              What is the best way to confirm/rule out the main on this set
              Cheers
                A 5.3V line dropping even temporarily to 3V is indicative of a fault, likely on the power board though potentially a bad main board with intermittent short could cause this -- try tapping/heating etc see if problem comes back faster.
                • signup
                  • May 2013
                  • 189
                  Cheers tom the question is what is making it dip to 3v..PSU or main
                  on/off pin of the psu stays constant at 5.1v when the fault is happening
                  I have also noticed a couple of the IC's on the main are getting very hot after around 30 seconds of the tv being on
                    I haven't the slightest clue. But I'd take a gander that you might have a power supply which cannot power the main board or a main board drawing more power than the power supply is nominally rated for.
                    • signup
                      • May 2013
                      • 189
                      Errrmmm so sorry, I need to pay more attention, and look more closely at the boards when checking, I have just spotted a nice rust patches and what looks like water/fluid damage on the main. All under the metal sheilding that looks like a pain in the arse to get off...A new main it is I am not chasing tails to resolve this one
                      Thanks again Tom
                      • signup
                        • May 2013
                        • 189
                        Re: Samsung LE26R88BD Strange Fault FIXED
                        Decided to stop being a wuss when it comes to main boards and did a little more investigation, checked the voltages on the VR's on the underside of the board and found 2 giving funny readings when the fault was happening, against when the TV was working
                        Board PN= BN41-00813B-MP
                        IC positions IC1107 & IC1106
                        Both Voltage regulators were labelled 1117 07152L
                        Replaced and the TV has been playing for 5 hours now and not a hiccup
                          That's nice to hear. Thanks for the feedback.
                          • signup
                            • May 2013
                            • 189
                            No problems, hope it help someone else who has the problem...why has your name turned green tom
                              Anyone over 100 posts gets a green name.
                              • beavisthelizard
                                • Oct 2013
                                • Wales
                                Hey nice to know there's an answer to this one...
                                I tried resetting the eeprom, changes caps...
                                Was looking at ordering a new main board (35pound) but where did you manage to track down the IC's from?
                                I've run a few search's on different sites but If you could speed things up that would be great.
                                I've got a Samsung LE23R88BD when it feels like it...(warmed up) Screen freezes, pix-elates goes white, black-off and starts again.
                                • jpalmeida
                                  • May 2008
                                  • 11
                                  Hi signup!
                                  Thanks for your share.
                                  I have the same board BN41-00813B but in other SAMSUNG, with the same problem.
                                  I'll see if it works for me too.
                                  Thanks in advance.
                                  Joao Almeida
                                  Portugal
                                  • jpalmeida
                                    • May 2008
                                    • 11
                                    Signup, I can't find those IC's.
                                    Where are them located in the board?
                                    I only see two SMD IC's IC1109 and IC1109 both 17-33 06524L, that seemed to be the same regualtors of 3,3V.
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      I believe there are more than one version of this board.
                                      You need to post good clear pictures of YOUR board in your other thread then we might be able to help
                                      • jpalmeida
                                        • May 2008
                                        • 11
                                        This is the Samsung I am talking about:
                                        LE40M87BDX/XEC
                                        Yesterday it was more than 5 hours running well (no back cover). Well, even with cover, here it never showed the problem. I saw the problem at the client's home.
                                        Hope Signup can tell me where IC positions IC1107 & IC1106 are.
                                        Wish you all a very Happy New Year 2014.
                                        Best regards.
                                        Joao Almeida
                                        • Asraf Atb
                                          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                          by Asraf Atb
                                          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                          01-27-2025, 05:02 PM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • Lee M.
                                          Samsung UN75RU8000FXZA bad main board?
                                          by Lee M.
                                          When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                                          11-08-2023, 07:46 PM
                                        • JDC
                                          by JDC
                                          ONN 100012588
                                          Long answer:
                                          07-15-2022, 07:39 AM
