Any place to buy the cheap YSUS replacement board for Plasma TV?
  • lovecd
    • Jun 2013
    • 31
    My current 720P plasma TV from Zenith/LG got some problems, won't show pictures, kind of dard screen or funny images. Audio and tuner are all working fine. So I guess the y-sus board needs to be replaced. Considering this is a used 720P TV, I will probably won't change it if the price for Y-SUS is over $100. Can any one give some advise where I can find the relatively cheap Y-SUS board? I don't mind if it is a used one, as long as it is working.
    Thank you!
    Re: Any place to buy the cheap YSUS replacement board for Plasma TV?
    What is the EAX/EBR/ or similar part number on the board? And model of the TV? Sure it is Y-sus?
    More likely to be Z-sus.
    Picture of fault?
    • lovecd
      • Jun 2013
      • 31
      TV is Zenith Z50PX2D 50-Inch Plasma. By the way, how to check the EAX/EBR number?
      I will try to take some pictures and post them here.
      Many thanks!
      • lovecd
        • Jun 2013
        • 31
        Here are some pictures I took. Any ideas it is Y-sus or Z-sus?
        • capkid
          • Oct 2010
          • 1339
          Have you verified that you're getting the proper panel voltage outputs from the power supply (see label on back of panel)?
          LG Plasma Mal-Discharge Correction Service
          • lovecd
            • Jun 2013
            • 31
            Assuming if all outputs are correct, what could be the cause of the issue?
            Thanks!
            • capkid
              • Oct 2010
              • 1339
              Thanks!
              I'd look at the Y and Z sustains if you don't find issues with the power supply, but make sure you thoroughly investigate the power supply outputs.
                It is looking a lot like a Z-sustain issue to me.
                • lovecd
                  • Jun 2013
                  • 31
                  Thank you guys! I will do some checkings and let you know what I found. By the way, do you have any link for tutorial on how to use DMM to check the output voltage and fuse, etc.?
                    Fuses are tested with power off and meter on ohms across the fuse; readings less than 3.0 ohms are generally good.
                    • lovecd
                      • Jun 2013
                      • 31
                      Hi All,
                      After a while, I decided to replace all y drive, y-sus and z-sus boards, got a good deal from ebay. However, after the boards are all replaced, the problem is not resolved. The symtom looks different now. I posted some pictures with the replacement boards installed. Any ideas whatelse could be wrong? Thanks!
                      • H34TO
                        ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                        by H34TO
                        Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                        06-17-2025, 07:17 AM
                      • boosti45
                        Macbook pro logic board replacement parts quesion
                        by boosti45
                        i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                        08-21-2024, 05:23 AM
                      • tuner2000i
                        Philips 65PUS8518/12 distorted image after main board replacement
                        by tuner2000i
                        hello everyone,
                        I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                        The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                        07-15-2025, 01:15 PM
                      • Cooperr
                        Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                        by Cooperr
                        I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                        The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                        10-21-2025, 01:11 PM
