Need schematic of Hisense LCD26V79 TVC
  • Ahakim
    • Apr 2013
    • 64
    I'm looking for the schematic of a 26" LCD TVC:
    Model: LCD2679V Hisense Technology
    100-240VAC 65W
    No HV from Inverter board (therefore no backlight). 5VS, 5VM, 12V all present from SMPS (which is by the way on same board with inverter). No 12V on primary of any of the 2 HV transformers. I find this normal since there is no direct contact between any of the pins of these 2 transformers primaries and the Vcc, i.e. the 12VDC. These pins are connected to The MOSFETs via 5 SMD caps in parallel. Is this a typical configuration?? There are 2 secondaries in each tranformer (supposed to deliver 1300V/7mA to CCFLs, as indicated on board i.e.4 lamps). I'd be grateful If someone could show me a similar inverter cicuit for any LCD TV, just to understand how this type of cicuitry works.
    Question: Do all inverter cicuit boards necessarily HAVE a fuse somewhere, in which case I have to loooooooooooooooooooook for it, & must find it? In fact I couldn't find any SMD fuse on this board.
    ANY HELP!
  • eccerr0r
    inverter H tree driver imbalance in an AC inverter
    by eccerr0r
    My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
    11-16-2025, 12:34 PM
  • x_orange90_x
    Vizio E55-E1 bad backlights or bad inverter?
    by x_orange90_x
    I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
    I don't know how exactly to test the inverter itself. Is it...
    01-29-2025, 09:24 PM
  • tomketcz
    schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ
    by tomketcz
    Does anybody have schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ ??
    10-01-2025, 03:13 AM
  • Coolgoodman
    Faulty Hisense 85Q6NAU TV
    by Coolgoodman
    85” Hisense TV
    Greetings,
    Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
    Dear TV technicians of forum, I hope this message finds you well.
    I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
    I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
    07-24-2025, 03:02 AM
  • Gentian
    APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
    by Gentian
    I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
    It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
    03-06-2023, 07:07 AM
