Vestel 17MB62 Chassis
    • 31293
    Re: Vestel 17MB62 Chassis
    u.k. is mpeg2
    mpeg4 is only on the usb on u.k. tv's - you may get it working with an mpeg4 cam module.
    in future, dont buy u.k. tv's - specially HD tv's because the way the stream is ilegally encrypted to lmiit the equipment that can be used.
    in europe they wont tune any channels.
    • Smartec82
      • May 2015
      • 25
      • Portugal
      So with an mpeg4 cam module, the channels on tv are working in mpeg4 mode? It's the only solution? Thank you very much
      • iuliantv
        • Aug 2009
        • 36
        • Romania
        For those interested, I found mb62 tuner software for LG, but the display is 32 "go and DVB-C channels only mpeg2, success
        https://www.xfile.ro/download/cd80c2...15cbed8b2.html
        • pjp4
          • Nov 2015
          • Ireland
          Re: Vestel 17MB62 Chassis - How to enable HDMI 2 in service menu ?
          Hi Julian,
          Would you know how to enable HDMI 2 port ? It is called HDMI_0 in the schematics.
          The issue is the read only service menu entry. Is there a way around it? Perhaps you know the SPI Flash feature map config?
          Cheers,
          Peter
          • catalin004
            • Jan 2015
            • 35
            • Romania
            Hello all, I have a problem with the same chassis, 17MB62-1 of Vestel, the st-by LED is flashing at 1sec beat, the source is ok, I've tried to make an update of firmware and now the LED is dead....It is presently 5V, 3V3 an 12V but still not working.
            Please an ideea.
            The TV is LCD Tucson TL2201 B12
            • stevespeed5
              • Dec 2015
              #26
              hi I have a Toshiba 22dl704b that has the 17mb62-2.5 chassis, I tried to update with the Toshiba latest firmware but now only flashes green/red, does anyone know where I can get older Toshiba firmware for this set?
              • Als_2014
                • Jun 2014
                • 7
                • Italy
                #27
                Hi I am from Italy, i just already fixed a Telefunken 22" Model TE22914 B19 LED Slim with Panel 22LG, which use same MB 17MB62, later i will extract the Software from the Tv and i will post it here, in hope can be of help..
                Alfio.
                • Als_2014
                  • Jun 2014
                  • 7
                  • Italy
                  #28
                  here is the file...
                  • kisspachyousee
                    • Feb 2016
                    • 7
                    • Italia
                    #29
                    Originally posted by Als_2014
                    here is the file...
                    hello, could you explain how did you update the firmware? can you do it even if you do not see anything on the screen? I have a Vestel TV that I think has the corrupted firmware!
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      #30
                      what make and model is you tv it maybe advisable too check all the voltages on the psu are correct and also if this is a led set too check the led voltages as if failed you wont get backlight
                      • kisspachyousee
                        • Feb 2016
                        • 7
                        • Italia
                        #31
                        my problem is that the standby LED always blinks and does not turn on the TV, I changed the power, I think it is the corrupted firmware
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #32
                          maybe a faulty eeprom ic try freezing it and see if the set starts up
                          • kisspachyousee
                            • Feb 2016
                            • 7
                            • Italia
                            #33
                            basically freezing the EEPROM is done a factory reset ?? It is brilliant! but where do I find them in my main card? I have 17mb62-2.6
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              #34
                              please ignore i posted wrong information
                              • kisspachyousee
                                • Feb 2016
                                • 7
                                • Italia
                                #35
                                This is my main board
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  #36
                                  Edit ! i see your set set uses a different mainboard 17mb62 that video i deleted is for the 17mb82 totally different board
                                  my guess its the one ic u158 i think it is hopefully a more experienced member will advise us but freezing that ic still may work if it dosent you may have too remove the eeprom and re programme or replace it
                                  what is the the tv you have what is the lcd panel number used in this tv (usually on a white sticker on the metal tv chassis) as we maybe able too find the exact firmware
                                  • kisspachyousee
                                    • Feb 2016
                                    • 7
                                    • Italia
                                    #37
                                    I tried to freeze the chip but did not get lucky... the led when i turn on flashing.
                                    panel is LG lc260wxn
                                    main is 17mb62-2.6
                                    tv is SABA model lw26a200
                                    • kisspachyousee
                                      • Feb 2016
                                      • 7
                                      • Italia
                                      #38
                                      I can not find the correct firmware for my TV, if I knew that there was one compatible, I could try to buy a windbond programmer. would you help me?
                                      ----------edit
                                      I seem to have realized that TX and RX for Winb25Q80 serial connection are pin 10 and 12 of the scart socket, is it correct?
                                      • kisspachyousee
                                        • Feb 2016
                                        • 7
                                        • Italia
                                        #39
                                        ok, serial console work!!
                                        Code:
                                        UART_115200
                                        LP_snPD
                                        Hello U-Boot
                                        [LGPS]: u16LongPulseThr = 07D0
                                        [INTG]: u16IntegrationThr = 0052
                                        [WDOG]: u8WatchDogCount = 0024
                                        U-Boot 1.1.6 (Oct 13 2011 - 21:23:42)
                                        Board: MSTAR TITANIA4 (CPU Speed 312 MHz)
                                        DRAM: 128 MBytes
                                        U-Boot is running at DRAM 0x87600000
                                        Module: USB FAT NAND UBI UBIFS SPI JFFS2
                                        MBOOT UNFD T4-----------------------------------------------------------20110728 21:23:41
                                        NAND ID 20 76
                                        nand_unfd_init ECC_TYPE_4BIT
                                        >>>pagesize = 512
                                        NAND: 64 MBytes
                                        In:  serial
                                        Out:  serial
                                        Err:  serial
                                        Skipping flash_init
                                        MSVC00B000100100208768TH0000000T
                                        1Ghz
                                         keypad_pressed is [0]
                                        Flash is detected (0x0707, 0xEF, 0x40, 0x14)
                                        no OAD Flag
                                        no need start factory usb download
                                         #* NAND is already programmed (not Empty) ***
                                        Wait for PM51 standby...........
                                        PM51 run ok...........
                                        Hit any key to stop autoboot: 0
                                        NAND read: device 0 offset 0x0, size 0x320000
                                        Reading data from 0x0 -- 100% complete.
                                         3276800 bytes read: OK, time=00000000
                                        ## Booting image at 81000000 ...
                                          Image Name:  Linux-2.6.28.10-mstar
                                          Created:   2012-03-14 13:29:22 UTC
                                          Image Type:  MIPS Linux Kernel Image (uncompressed)
                                          Data Size:  3017080 Bytes = 2.9 MB
                                          Load Address: 80200000
                                          Entry Point: 80204150
                                        OK
                                        Starting kernel ...
                                        L2 enabled
                                        Linux version 2.6.28.10 (root@localhost.localdomain) (gcc version 4.3.2 (Sourcery G++ Lite 4.3-51) ) #32 PREEMPT Wed Mar 14 21:29:11 CST 2012
                                        LINUX started...
                                        boot_command_line: console=ttyS0,115200 ubi.mtd=1 ubi.mtd=2,512 root=ubi1:RFS rootfstype=ubifs rw LX_MEM=0x3400000 EMAC_MEM=0 DRAM_LEN=0x8000000 mtdparts=edb64M-nand:3200k(KL),11392k(CONF),22m(UBIA),25m(UBIB),-(NA) MBOOT_VER=1.1.6-161M62 SPI
                                        LX_MEM = 0x200000, 0x27C0000
                                        LX_MEM2 = 0x0, 0x0
                                        CPHYSADDR(PFN_ALIGN(&_end))= 0x51B000
                                        EMAC_LEN= 0x0
                                        DRAM_LEN= 0x8000000
                                        console [early0] enabled
                                        CPU revision is: 00019555 (MIPS 34Kc)
                                        Begin Mstar_Chip_setup
                                        Determined physical RAM map:
                                         memory: 027c0000 @ 00200000 (usable)
                                        Wasting 16384 bytes for tracking 512 unused pages
                                        Zone PFN ranges:
                                         DMA   0x00000200 -> 0x000029c0
                                         Normal  0x000029c0 -> 0x000029c0
                                         HighMem 0x000029c0 -> 0x000029c0
                                        Movable zone start PFN for each node
                                        early_node_map[1] active PFN ranges
                                          0: 0x00000200 -> 0x000029c0
                                        Built 1 zonelists in Zone order, mobility grouping on. Total pages: 10096
                                        Kernel command line: console=ttyS0,115200 ubi.mtd=1 ubi.mtd=2,512 root=ubi1:RFS rootfstype=ubifs rw LX_MEM=0x3400000 EMAC_MEM=0 DRAM_LEN=0x8000000 mtdparts=edb64M-nand:3200k(KL),11392k(CONF),22m(UBIA),25m(UBIB),-(NA) MBOOT_VER=1.1.6-161M62 SPI
                                        alloc ebase: 81059000
                                        Primary instruction cache 8kB, VIPT, 4-way, linesize 32 bytes.
                                        Primary data cache 8kB, 4-way, VIPT, no aliases, linesize 32 bytes
                                        Writing ErrCtl register=00062736
                                        Readback ErrCtl register=00062736
                                        PID hash table entries: 256 (order: 8, 1024 bytes)
                                        CPU freq count = 156000000
                                        CPU frequency 312.00 MHz
                                        console handover: boot [early0] -> real [ttyS0]
                                        Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
                                        Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
                                        Memory: 37068k/40704k available (2214k kernel code, 3616k reserved, 607k data, 124k init, 0k highmem)
                                        SLUB: Genslabs=6, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
                                        Calibrating delay loop... 205.31 BogoMIPS (lpj=102656)
                                        Mount-cache hash table entries: 512
                                        net_namespace: 288 bytes
                                        NET: Registered protocol family 16
                                        SCSI subsystem initialized
                                        usbcore: registered new interface driver usbfs
                                        usbcore: registered new interface driver hub
                                        usbcore: registered new device driver usb
                                        msgmni has been set to 72
                                        io scheduler noop registered
                                        io scheduler anticipatory registered
                                        io scheduler deadline registered
                                        io scheduler cfq registered (default)
                                        Serial: 8250/16550 driver4 ports, IRQ sharing disabled
                                        serial8250: ttyS0 at I/O 0xbf201300 (irq = 8) is a 16550
                                        brd: module loaded
                                        loop: module loaded
                                        Driver 'sd' needs updating - please use bus_type methods
                                        Driver 'sr' needs updating - please use bus_type methods
                                        usbmon: debugfs is not available
                                        NAND device: Manufacturer ID: 0x20, Chip ID: 0x76 (ST Micro NAND 64MiB 3,3V 8-bit)
                                        Creating 5 MTD partitions on "NAND 64MiB 3,3V 8-bit":
                                        0x00000000-0x00320000 : "KL"
                                        mtd: Giving out device 0 to KL
                                        0x00320000-0x00e40000 : "CONF"
                                        mtd: Giving out device 1 to CONF
                                        0x00e40000-0x02440000 : "UBIA"
                                        mtd: Giving out device 2 to UBIA
                                        0x02440000-0x03d40000 : "UBIB"
                                        mtd: Giving out device 3 to UBIB
                                        0x03d40000-0x04000000 : "NA"
                                        mtd: Giving out device 4 to NA
                                        parse_cmdline_partitions: add_mtd_partitions
                                        NET: Registered protocol family 17
                                        VFS: Mounted root (ubifs filesystem).
                                        init started: BusyBox v1.14.1 (2010-06-23 18:41:22 CST)
                                        starting pid 179, tty '': '/etc/init.d/rcS'
                                        Mounting conf
                                        Mounting vendor
                                        ******Application Started*****
                                        pthread_mutex_init
                                        CHIP_InitISR
                                        mem_type: 0, phy_addr = 0x75c1000, start_addr = 0x42082000, size = 6291456
                                        mem_type: 1, phy_addr = 0x7bc1000, start_addr = 0x32682000, size = 0
                                        ******* ICE_LoadProfileData - Enter
                                        Load profile /conf/mb62_hwprofile.bin
                                        ******* ICE_LoadProfileData - Exit
                                        Load profile /conf/mb62_swprofile.bin
                                        PM Bank mapping success. Base=[4b306000], Size=[225600]
                                        NonPM Bank mapping success. Base=[4b52c000], Size=[25600]
                                        Flash Bank0 mapping success. Base=[4b552000], Size=[4000000]
                                        **** ICE_HardwareInit ****
                                        FROST_DebugStartConsole !
                                        Terminal: vt102
                                        terminal ready
                                        Load profile /conf/mb62_langprofile.bin
                                        #*### Console Started ###
                                        Load tune file
                                        Try loading bin panel file
                                        Read : 15084 target: 15084
                                        TUNER : LG18273   EXTENSION :
                                        Load country file
                                        ---> DDFSPAN = 0x29a (666)
                                        --------->MBX DRIVER OPEN
                                        _MDrv_MBXIO_FASYNC is invoked
                                        ICE_LowPowerModeForceStandby(): exit_type[0] - fti[0] - pin8_en[1] - hotel[2] - profile[0] - last_state_standby[1] -child_lock[0]
                                        disable DVD wakeup
                                        Get PM command: 0x30.
                                        MDrv_PM_Init OK
                                        Fast Standby: MDrv_PM_PowerDown ...
                                        • valvelover
                                          • Nov 2017
                                          • 6
                                          #40
                                          hi clydeuk. i have a copy of the mb62_en.bin firmware, tho i have no idea which version ? only just joined this site, so not sure i can send you it on here ? but your welcome to it if you want ? im trying to fix a techwood 32" tv with an mb62 mainboard, it has a flashing led fault from power up? (no standby ) thought at first it would be a power board fault ? but most of the posts say software issue? it never powers up, so cant get to copy the version thats on there to usb, and didnt want to do anything with the version i have ? (would it try to load even if wrong type ? ) tbh id like to be in your position, as i want to use the tv as a pc monitior in my bedroom with a sky box via scart/hdmi..........so tuner not working wouldnt matter to me ? lol.
                                          • Bazilwrc164
                                            Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                                            by Bazilwrc164
                                            I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                                            The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                                            I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                                            If anyone can provide:
                                            • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                                            • Or a compatible EEPROM dump
                                            07-23-2025, 12:15 PM
                                          • massimomax
                                            Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                            by massimomax
                                            Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                            spero che qualcuno può averlo per riprogrammare eprom. grazie
                                            Post in English !!!
                                            I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                            02-28-2025, 07:27 AM
                                          • lberkani
                                            Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
                                            by lberkani
                                            I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
                                            The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
                                            The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
                                            I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
                                            - Toshiba 65UL2163DG
                                            - Vestel 17MB180E mainboard
                                            - Panel VES650QNTX-N2-N42
                                            - Version V1.28.100.0 if available
                                            If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
                                            11-11-2025, 12:37 PM
                                          • anlu
                                            Vestel Firmware - Toshiba 32W133DN
                                            by anlu
                                            Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                                            Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                                            02-04-2023, 12:59 AM
                                          • piernov
                                            Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
                                            by piernov
                                            Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
                                            I suspect corrupt firmware but I haven't been able to find anything for this TV.
                                            TV model: Finlux 65-FUC-8060
                                            Mainboard: Vestel 17MB130S 23473048
                                            Panel: VES650QNTS-2D-U11
                                            At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
                                            06-01-2024, 12:57 PM
