Vizio VX37L backlight not coming on
    Re: Vizio VX37L backlight not coming on
    3.11V is too low though for 3.3V regulators. If the main board crashes it may turn off the 24V, but I'm not sure about the 12V. Ideally you would fix the regulators first so a baseline of correct main board operation can be established.
    • aaronwt6
      • Apr 2013
      • 855
      • US
      Sounds good. I'll get these ordered and go from there.
      Update to come!
        Are you now getting 3.33V on regulators?
        I thought you had 3.11V but you've edited the post?
        Because 3.33V is fine, we would need to look elsewhere...
        • aaronwt6
          • Apr 2013
          • 855
          • US
          U16 seems to be the only low one. That's why I said check the edit. Sorry again about that.
            U16 is fine; -25 = 2.5V output.
            • aaronwt6
              • Apr 2013
              • 855
              • US
              #26
              Ah, ok. I've got to go pick up dinner for the family but I'll move on to the next step in a bit. Not sure if you saw above in the thread but I unhooked the control board completely yesterday and still could not get the voltages on the supply to hold steady when I power it up.
              I did that by putting a jumper from the STBY to PSON. Not sure if that's the correct way to go about it but it seemed to work.
              • aaronwt6
                • Apr 2013
                • 855
                • US
                #27
                It's funny Tom. Electrical engineering degree and I swear I never knew what those numbers on the regulators stood for.
                • aaronwt6
                  • Apr 2013
                  • 855
                  • US
                  #28
                  Just a note I had mentioned U1 earlier which is a 7805 on the control board. Pretty sure it's part of the 12v circuit which explains why I have nothing on that one at all.
                    12v and 24v are generated by the same power transformer. So if you use 1k resistor between the PS_ON and the 5V STBY pin, then you should see the 12v and the 24v come on.
                    • aaronwt6
                      • Apr 2013
                      • 855
                      • US
                      #30
                      Thanks budm. I'll give this a try tonight after work.
                      • aaronwt6
                        • Apr 2013
                        • 855
                        • US
                        #31
                        Ok. Tried that and the 12V is still missing and the 24V acts the same as before. Starts our around 14V and drops to 1-2V quickly. I'll have to get back to this one sometime next week.
                        • aaronwt6
                          • Apr 2013
                          • 855
                          • US
                          #32
                          Got this one going. Just swapped the whole supply. $25 for it on Ebay shipped. I may look at the old one later.
                          Thanks as always for the help everyone!
                            Glad to hear it's going now.
                            • aaronwt6
                              • Apr 2013
                              • 855
                              • US
                              #34
                              Definitely need to get down to the component level repair. This hobby is highly addictive.
                                You betcha. I just keep looking everywhere for discarded faulty TVs to fix.
                                • aaronwt6
                                  • Apr 2013
                                  • 855
                                  • US
                                  #36
                                  No doubt. I find myself scouring craigslist every day now. I'm buying things I don't need to to fix em.
                                    I have recently decided to keep a lot of the good ones for myself. Two Panasonic plasmas and other TVs too.
                                    • aaronwt6
                                      • Apr 2013
                                      • 855
                                      • US
                                      #38
                                      Yes sir. Same here. I keep 'upgrading' us in the house. 50" LG Plasma 1080P is our living room unit.
                                      • aaronwt6
                                        • Apr 2013
                                        • 855
                                        • US
                                        #39
                                        Can't understand alot of people's fear of Plasmas. You can't beat the picture and color on a good 600Hz 1080P Plasma.
                                          Probably based in the old IPM-based LGs... but modern plasmas are a lot easier to repair.
