Tevion LCD32091D Test Patterns???
  • notallbad
    • Oct 2012
    • 1183
    Tevion (Medion)
    Turn the Tv on and all functions appear to work, keyboard panel vol up and down, channel up and down, source, menu but the screen looks like its in test patterns, audio works when a source is connected.
    When Menu is selected a box appears without text but looks like it would be the Menu box.
    Select vol up and down and what appears to be the volume bar appears except theres no volume number just a blank oblong box.
    Select Source and a box in the top left corner appears except theres no text but a bar appears that scrolls up and down and source can be selected and changed.
    The screen looks like test patterns but I think the issue is either with the T-con or possibly SSB i.e Scaler
    PS board: MLT666 Rev 2.8 all voltages ok
    Main A/V board: TV3201-ZC01-02
    Re: Tevion LCD32091D Test Patterns???
    My guess corrupt EEPROM or perhaps bad RAM, both on main board.
    • notallbad
      • Oct 2012
      • 1183
      There are 3 Atmel eeproms
      24c02
      24c04
      24c32
      What are each of these for?
      I have replaced the 24c32 which I assume is for user settings but no change.
      I have a 24c02 so could have a go changing that one.
      Shall get a photo of the board and post it.
        I don't have the slightest clue. The differening digits at the end are the size in kilobits (1 kilobit = 1/8 kilobyte)
        • notallbad
          • Oct 2012
          • 1183
          Main A/V board
          U2 - 24C02
          U4 - 24C04
          U10 - 24C32
          • notallbad
            • Oct 2012
            • 1183
            U14 - 1117 0395 ADC
            Pin 1 - 4.98v
            Pin 2 - 0.93v
            Pin 3 - 0.048v
            Tab - 0.93v
            Could someone tell me if this sounds correct, there are a couple of resistors on pin 3.
              Just to be sure that the pin you call pin 1 is the pin to the right looking at the IC with the big tab up?
              The output should be about 1.25V.
              The correct pin number is (big tab up) left is pin 1 (Ground for fixed regulator or Adjust for the adjustable regulator), middle is pin 2 (output, it is tied internally to the big tab), right pin is pin 3 (input)
              • retiredcaps
                • Apr 2010
                • 9271
                Originally posted by notallbad
                U14 - 1117 0395 ADC
                Pin 1 - 4.98v
                Pin 2 - 0.93v
                Pin 3 - 0.048v
                Tab - 0.93v
                U14 is bad. See the how to test a voltage regulator FAQ as to why.
                --- begin sig file ---
                --- end sig file ---
                • notallbad
                  • Oct 2012
                  • 1183
                  Thanks.
                  Yes pins correctly identified.
                  Looking across the board I have found another 1117 - U30 with the following
                  Pin 1 0.4v
                  Pin 2 and tab 0.65v
                  Pin 3 0.7v
                  Definately suspect, and requires further investigation.
                    Its input voltage is not high enough so it's probably OK for now. But see if you can locate where it is being powered from since when the set is on all regulators will usually have power. If it is in standby those readings may be fine.
                    • notallbad
                      • Oct 2012
                      • 1183
                      Correction for post #6, I did in fact read the pins backwards
                      U14 - 1117 0395 ADC
                      Pin 1 - 0.048v
                      Pin 2 - 0.93v
                      Pin 3 - 4.98v
                      Tab - 0.93v
                      So input is ok but the output is reading too low, as this is an adjustable reg could it be that theres nothing wrong with the reg but in fact due to a fault on the adj gnd causing the output to be pulled down so low?
                        Is the regulator very hot when you touch it? Or is it cool to the touch?
                        • notallbad
                          • Oct 2012
                          • 1183
                          Very cool as if its not doing anything, the TV is on and not in standby.
                          There are a couple of larger regs on the board that when you touch it, 1 2 secs ouch thats long enough!
                            It is an adj type regulator, if the ADJ pin is grounded directly or through resistor network it will not cause the output to be less than the ref. voltage of 1.25V. Minimum output will always be 1.25V.
                            So it may be bad reg, so check to see if it is running hot as Tom suggested, or it is heavily loaded, or bad filter cap at the output.
                            I think it may be just bad regulator.
                            • notallbad
                              • Oct 2012
                              • 1183
                              Not having much luck finding any spare adj regs on the spare boards (plenty of fixed 1.8v and 3.3v) I have and the cost of them for one on fleabay looks extortionate!
                                Too much?
                                http://www.ebay.co.uk/itm/2-x-SMD-SM...item3efd077ad1
                                • notallbad
                                  • Oct 2012
                                  • 1183
                                  Well, I saw some much dearer just for one so perhaps I shall buy buy buy!
                                  Thanks Tom
                                  • notallbad
                                    • Oct 2012
                                    • 1183
                                    Found a couple of bad caps on the PS b/d so replaced them, then found an adj reg on an old PC motherboard, now switches on and displays an image.
                                    I shall bench test to see if any issues arise. One thing I did notice after having my laptop connected to the VGA port is that the 'source' and 'menu' and 'volume' boxes displayed as before but this time the tv still showed the display image. I quickly switched it off in case its the pc input thats the cause of the fault so shall run it through all the other inputs first then try the pc input again later once I'm happy everything else is working.
                                      Glad to hear that it is working.
                                        LCD LED TV Service Menu Codes
                                        ALL LCD LED TV SERVICE MENU CODES
                                        Service Menu Code with Board Name
                                        China Universal Board / Jumper Board Service Menu Code
                                        Changhong Ruba Service Menu Code
                                        Ecostar LED TV Service Menu Code
                                        Orient LED TV Service Menu Code
                                        Haier LED TV Service Menu Code
                                        TCL LED TV Service Menu Code
                                        Samsung LED TV Service Menu Code
                                        LG LED TV Service Menu Code
                                        Videocon LED TV Service Menu Code
                                        Supra LED TV Service Menu Code
                                        Toshiba LED TV Service Menu Code
                                        Symphony LED TV Service Menu Code
                                        Veste/ LED TV Service Menu Code...
                                        10-31-2024, 03:58 AM
                                      • patricksurry
                                        Sony Bravia XBR 55X900E cycling through test patterns: which board(s) to replace?
                                        by patricksurry
                                        We had a power outage but TV seemed to be working fine afterward. This morning it showed a "grainy" picture, and then next time we turned it on it's stuck in a test-pattern loop. None of the resets I've tried have any effect, including unplug/wait/plug in - it immediately goes into this cycling test pattern.
                                        Does this suggest the main board needs replaced? The TV is about 5 years old, picture still looks great (tho limiting to crisp red/green/blue/white lacks some variety ...
                                        04-08-2023, 06:45 AM
                                      • chth96
                                        How Can I test PWM DM0365R?
                                        by chth96
                                        Hello
                                        I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                        So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                        I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                        I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                        06-18-2025, 04:14 PM
                                      • eyuperol
                                        E-Sudio 18 language change problem
                                        by eyuperol
                                        Hello, I have an e-studio 18 printer. This printer was giving a toner error. I turn on the machine by holding down the red (clean / stop) button while the printer is off. It enters service mode. Here I press the up - left - down - right arrow keys in order and enter the setting mode (select the first one in the row) and press the OK button. I come across test mode A. While here, I was bypassing the toner problem by opening the toner cover, pressing the menu button while the cover was open and then closing the cover. Somehow, in this mode, I changed the language of my printer (Chinese, Korean)...
                                        09-26-2024, 03:14 PM
                                      • khelane
                                        test active pfc power with lamp test
                                        by khelane
                                        Hello
                                        I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                        Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                        Is there a way...
                                        06-03-2025, 01:00 AM
