Oevia 252fhd-t11 DPS-408AP B power supply
    Re: Oevia 252fhd-t11 DPS-408AP B power supply
    So, with new meter, you have solid 24V going to inverters? Exactly what do you read?
    • mcross
      • Sep 2011
      • 201
      Sorry for the late reply been busy. I am getting 24.4v to the inverters , VBL>4.7 ,VBRI> 3.5 and its stable, VLAMP is not used and theres no reading there.
      mike
        VBL = BL_ON (Backlights ON)
        VBRI = Dim (Backlights dimming control)
        So Inverters need to be checked.
        • mcross
          • Sep 2011
          • 201
          Will check the inverters, what should i look for?
          Also on the main board , It has a @ U7 is a 1084 reg, it reads pin1=1.35
          pin2=2.60
          pin3=5.02
          is this good or bad?
          Mike
            Can you post a picture of the inverter(s)?
            • mcross
              • Sep 2011
              • 201
              Will do in a few mins
              • mcross
                • Sep 2011
                • 201
                heres the invert pic's
                  There's usually a fuse on these marked "1A/76V", do you see one?
                  • mcross
                    • Sep 2011
                    • 201
                    yes , tested good, all are good on all 4 boards
                    • mcross
                      • Sep 2011
                      • 201
                      Sorry, made a bad reading on the master inverter fuse, was looking at the bigger white ones. on the master with meter set to 200k, get a slow climbing reading, the others on the slave boards read good no resistance
                      Mike
                        Great! The fuse is blown. It is a common fault. Replace it and it should work.
                        • mcross
                          • Sep 2011
                          • 201
                          will do and let you know
                          mike
                          • mcross
                            • Sep 2011
                            • 201
                            That did it Tom!
                            Thanks for the help, I have learned alot with this one. I have done about 20 tvs so far. I have a few to get to, may be back for you guys help. Thanks again
                            mike
                              Nice one. Thanks for the feedback too.
                                Glad it was an easy fix, very common failure for CMO inverter board
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                  03-31-2024, 02:12 PM
                                  07-01-2024, 06:34 AM
                                • JimBanville
                                  Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                  by JimBanville
                                  The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                  I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                  09-13-2023, 07:21 AM
                                • CMCM
                                  Russound CA4 Power Supply Repair
                                  by CMCM
                                  Hello Everybody,
                                  Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                  Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                  The outputs marked 12v and 20v are all measuring only 1v.
                                  The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                  The capacitors physically look clean (no bludgesor leaks) and...
                                  07-03-2025, 01:12 PM
