philips 42pfp5532d/05
  • sordids999
    • May 2013
    • 2155
    • uk
    When switched on it pulses with white light from each side with a green speckled screen which comes on as it pulses
    control board fault ? or unless someone has fixed this problem before ?
    thanks
    Re: philips 42pfp5532d/05
    What is the panel in it? LG, Samsung, Fujitsu-Hitachi?
    • sordids999
      • May 2013
      • 2155
      • uk
      samsung
        OK then. Follow these steps.
        https://www.badcaps.net/forum/showpo...61&postcount=2
        • sordids999
          • May 2013
          • 2155
          • uk
          ah thanks tom so its a control board fault
            What? I didn't say that? I'm just trying to help you narrow it down. I highly doubt it is a control board fault in fact. I would be more suspicious of Y-main, Y-buffer or power supply.
            • sordids999
              • May 2013
              • 2155
              • uk
              opps my bad sorry tom ill test then get back to you m8
              • SmartPiter
                • Dec 2013
                • 8
                • Ireland
                Hi, I am new to the forum, and have just engineering background, have to find-out some brain activity for myself, I am computer hardware specialist processional, and have some ppl coming to me with flat screen TVs also Now have two Philips Plasma TV : 42PFP5532d/05 with identical symptoms, dark blur screens are pulsing with colour pixels a bit sound ticking is coming out from centre board. there is picture of screen:
                Any advice appreciated, TY in advance
                  Can you provide pictures, clear and in focus, of the boards inside the set?
                  • SmartPiter
                    • Dec 2013
                    • 8
                    • Ireland
                    In addition
                    Here is picture from the other one showing blurry picture about lack of DVB signal
                    • SmartPiter
                      • Dec 2013
                      • 8
                      • Ireland
                      Ok going to take pic be back in a minutes
                      • SmartPiter
                        • Dec 2013
                        • 8
                        • Ireland
                        • SmartPiter
                          • Dec 2013
                          • 8
                          • Ireland
                          Meanwhile I did controll board test according to
                          I got snowy dark picture still pulsing but now even on all screen.
                          • SmartPiter
                            • Dec 2013
                            • 8
                            • Ireland
                            Meanwhile I did test according to:
                            Screen was colour snowy, dark but even this time,
                            BTW: What should be result of this test?
                            • G33RT
                              Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                              by G33RT
                              Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                              It does power up when pressing the power button.
                              I already try the power button while plugin the plug with no result.
                              Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                              Could this be an PSU or eMMC issue ?
                              07-19-2025, 03:43 AM
                            • double_DD
                              Philips curling iron - is this a common AC cable?
                              by double_DD
                              Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                              As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                              Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                              08-18-2025, 10:04 AM
                            • janos6662000
                              Philips 47PFS7509/12 LCD TV problem
                              by janos6662000
                              Hi
                              I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                              When i applied cable signal to check image, i had normal picture, but TV was restarting.
                              I downloaded original firmware and applied the update, but the problem remained.
                              From a colleague i received a "factory package software" which is a lot bigger.
                              I made another firmware update, but still did not solve the problem.
                              Somewhere on the way the error got worse, because at the moment the...
                              08-12-2025, 12:54 PM
                            • aidanmo
                              Philips 43PUS7506/12 - Loud blown out sound
                              by aidanmo
                              I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                              I thought maybe the speakers got damaged, so I replaced them - no dice.
                              • Using the internal speakers, it always happens.
                              • Using the headphone jack, it never happens.
                              • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                              02-28-2025, 03:13 PM
                            • ktmmotocross
                              GB RTX2080 Super - crash on load > second switched 12V instability > what is purpose of this circuit?
                              by ktmmotocross
                              Hello.
                              Have this GB 2080 Super that crash on load. When half load i see instability on one of two switched 12V rails. I dont know its purpose and dont have BV or Schema for this board.
                              Can anybody explain me what is purpose of this two switched 12V lines?...
                              10-03-2024, 12:22 AM
