Vizio P50HDTV10A plasma vertical line and red dot question
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    Hi everyone. So I got a P50HDTV10A that I just fixed 9 caps to turn the screen on and when the screen turns on it has red dots for the first couple of minutes then goes away. Also it has a 2 pixel wide vertical line down the middle of the screen. It's not solid and looks like its multi colored. One of the 2 rows doesn't go all the way down the screen just half to 3/4 the way down. Is this a bad tab connection or the actual screen going bad. Also any help with the red dots would be appreciated.
    Re: Vizio P50HDTV10A plasma vertical line and red dot question
    2 pixel line is bad plasma panel.
    Sparklies == LG panel? Samsung panel?
    • audiofreak19
      • Apr 2013
      • 556
      • usa
      Yea it is a Samsung panel. I figured the lines were probably gonna be the panel but wasnt sure about the dots. I heard from somewhere online you can adjust the voltage regulator down 10v and it might take the dots away. I haven't tried it yet
        You can adjust the Yrr and Yfr to remove the dots, but you will have to live with the line.
        • audiofreak19
          • Apr 2013
          • 556
          • usa
          Yea I figured. I will try it. The lines are kinda faint when certain colors are on you can barely see it.
          • howardc64
            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
            by howardc64
            Failure Symptom
            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
            Where is the short?
            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
            05-27-2025, 02:56 PM
          • tmhobadcap
            VIZIO M60-C3 Can the vertical line be fixed?
            by tmhobadcap
            I am trying to help my friend to fix his Vizio tv with a vertical line on the screen. The line is on the right side. It is blue/purple on the right side starting from the top. But it only goes to about 3/4 of the screen height (not to the bottom of the screen). It is very obvious when the screen is dark and it is hard to be seen when the screen is bright. Please help....
            02-05-2023, 03:37 AM
          • Gootch46
            Vizio E60-c3 blue vertical line (dead center)
            by Gootch46
            My Father called me he has a Vizio E60-c3 that's probably 3-4-5 years old but it has a thin blue line running down the center of the screen (photo) I tried a couple things but I'm sure one of you all have seen this already. Been a while since I've been here hope all is well. Thank you in advance....
            05-26-2023, 05:42 PM
          • TrueSword88
            Kogan - KALED65XU9220STB - Blue Vertical Line
            by TrueSword88
            Hi all.
            I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
            The line just happens to coincide with the end of COF and start of the next COF (attached).
            The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
            Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
            Hoping to fix...
            05-05-2023, 04:28 PM
          • almarhum
            To fix laptop screen vertical line by working on its EDP cable
            by almarhum
            Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
            As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
            05-07-2024, 02:12 PM
