LN46A650 problem
  • truep
    • Aug 2010
    • 373
    LN46A650 problem
    The problem is as follows:
    ran for 8 hours with the back off. All caps look fine but I have ordered replacements for the power supply. All voltages are stable.
    Today I put the back on. It ran for 3 hours then the screen went black. Backlights are on and sound is fine. I turned it off and imediately turned it on again and it came up fine.
    Sound like a tcon heat problem?
    Re: LN46A650 problem
    Get a can of freeze spray or a can of air duster using it up side down to cool the T-CON board, at the same time monitor the voltage on the SMD fuse on the T-CON to see if the voltage goes away.
    • truep
      • Aug 2010
      • 373
      The problem will be the shield around the TCON. It's used as a heat sink so I don't want to run it with the shield off. I'll try it tomorrow with the sheield on. The tcon does get very hot. I'll try heating the main board too just in case.
        You could rip heatsinks off old motherboards and leave the shield off. They will work better anyway.
          Does the shield actually make contact with the ICs, or has any heat transfer pads?
            I have worked on the LE40A656 twice which is the same TV, but UK version, and the frame is used as a heatsink. I have had once case of overheating chip on the T-con.
            • truep
              • Aug 2010
              • 373
              There is a heat transfer pad. The set runs fine with the back off (10 hours) so it's a heat problem.
              The only thing on the set that gets hotter than warm is the TCON.
              • netgearnetgear
                TCL 43S423 TCON OR PANEL FAULTY???
                by netgearnetgear
                Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                08-20-2025, 06:04 PM
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • THXFX
                samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                by THXFX
                Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                I check capacitors and diodes and didn't find any short IN MAINBOARD.
                Measured all power supply...
                03-20-2024, 03:21 AM
              • Zeonalbasta
                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                by Zeonalbasta
                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                09-13-2024, 01:17 PM
              • Hakuu
                by Hakuu
                Hi There,
                More Details
                TV Model - LG OLED77G1PUA
                07-12-2023, 02:37 PM
