Dead Olevia 265TFHD-T11
    replied
    Re: Dead Olevia 265TFHD-T11
    From the pictures, it has two identical power supply modules, each module supplies the 24V to 3 inverter boards. So do you get 22.7v on the output of BOTH power supplies?
    replied
    22.7V is low for a 24V line. It may be enough to keep the inverters off. If you disconnect the inverters, does the 22.7V rise closer to 24V?
  • HAHOMETP
    replied
    Please see the attached files.
    replied
    Can we see the pictures of the whole back side of the TV? I would like to see how the two connectors with white wires on the inverter board are connected to, and any labeling on those two connectors.
    Also good clear pictures of the inverter boards.
    replied
    It would appear the inverters do not use those control signals and they may well go through the T-con board.
  • HAHOMETP
    replied
    Originally posted by tom66
    Can you show a detailed look around the 24V connectors going to the inverter? Is there any place for inverters with 24V and VBRI/VBL/VLAMP etc., but it is not used?
    I took some pictures. Please see the attached file.
  • HAHOMETP
    replied
    So per information provided by LBH in the adjacent Olevia thread the lack of any voltage on the three mystery wires Pin 10 (YEL/VBRI), Pin 11 (BLU/VBL) and Pin 12 (WHT/VLAMP) appears to be normal.
    OTOH per information provided by mcross in yet another adjacent Olevia thread Pin 11 (BLU/VBL) shows 2.3v. His is a different TV, so it might be some other pin number on his main board, but his power supply is identical to mine.
    Now I am completely lost.
    replied
    I for one am enjoying the annual 3 days of sunny weather.
  • HAHOMETP
    replied
    Been to London many times but never ventured further North than Stratford-upon-Avon (to see Much Ado About Nothing) in THE place to see it. Whenever I went to the UK the weather always was dry and sunny believe it or not.
    replied
    I have almost finished my first year, just a week left. Nice and sunny in Leeds at present.
    The limit on editing is 90 minutes after posting.
  • HAHOMETP
    replied
    I'll try to take a few pictures Tuesday. Also the more I think about it the more I suspect the Main PCB to be the culprit. Weather.com predicts a nice partly cloudy day with 25°C for Tuesday in Philadelphia. I'll remove the Main PCB (and the T-Con PCB for a good measure), take them outside and shoot a few high resolution pictures.
    Have a great weekend, tom66! Thanks for your help and best of luck to you in your studies. See you here in a couple of days.
    P.S. BTW, is there a statue of limitation of some sort on editing one's own posts? I amended the MainPCB.pdf file and wanted to replace the one a few posts above but the system no longer allows me to do so. I am attaching this amended file to this message. Just didn't want to multiply entities thus creating unnecessary clutter.
    replied
  • HAHOMETP
    replied
    Oh yeah, I vividly remember how in university years I managed to go on for months without getting a good night sleep. Still, I really appreciate you doing this for me.
    Yes indeed this TV set has two identical PSUs. I have attached a file showing both.
    replied
    I am a student; there is no "bed time" in between the golden ages of 18 to 22.
    Can you show me a picture of where the power connectors actually go out to the inverter as well? I am thinking that those lines there are a relic for smaller screen sizes where the control signals are routed through the PSU to the inverter to reduce wiring clutter. Does this TV use one power supply, or multiple? Older Olevia 65" had two power supplies in them.
  • HAHOMETP
    replied
    OK, I will shoot a T-Con picture after the long weekend (it's the Memorial Day weekend here in the States). The TV is at my friend's house. I'll grab the wife's DSLR and crank up the ISO as much as I can - perhaps I'll be able to produce a better picture.
    If the good PCB on another forum were in Stanby mode, then why there's +4.2v present on the PSON pin in the PSU? I have attached a better picture of the PSU with my commentaries.
    Oh, and thank you for bearing with me so far tom66. It's way past midnight in the UK and I am hoping that I am not the reason why you're still up this late.
    replied
    OK, the layout makes more sense to me. Sharp made the panel in this TV. They are quite the leader in massive LCD tech. Anyway, can we have a picture of the T-con? I'm thinking that there may be a fault there.
    As to why the diagram of a good motherboard does not show voltages on those pins, perhaps it was in standby at the time?
  • HAHOMETP
    replied
    I have attached a .pdf file with a picture of my Main PCB with commentaries but like I said, the quality is horrible.
    replied
    Can we see some pictures of your boards?
    Using external pictures is OK, but we prefer to see your own, because there can be minor changes that make a big difference, and sometimes there can be obvious failures that we can spot, but that you would not necessarily have noticed.
  • HAHOMETP
    replied
    Thanks for the reply, tom66. Yes, that is correct. Each of my inverter boards only have 24V in from the PSUs.
    You have reinforced my suspicion that T-Con is somehow involved in turning the inverters on. I read about this before, just never encountered this design in real life.
    Also, yet another mystery lies in the PSUs. All pins in all connectors produce voltages consistent with their silksreen labeling except for the following 3 in the attached picture:
    VLAMP (feedback from the CCFLs?)
    VBL (voltage to the inverters?)
    VBRI (brightness control?)
    They show no voltage whatsoever regardless whether the TV is ON or OFF.
    This TV has two identical PSUs. One has wires connecting the above pins to the CN2 on the Main PCB:
    Pin 10 => YEL - VBRI
    Pin 11 => BLU - VBL
    Pin 12 => WHT - VLAMP
    The second one does not. Neither PSU shows any voltage on either of these three pins regardless whether the TV is ON or OFF. Swapping the PSUs did not change a thing.
    What mystifies me further still is that this picture of a good motherboard also shows that these three pins do not carry any voltage. So why were they put there with such descriptive silkscreen labels in the first place if they do not have any function?
    replied
    Do each of your inverter boards only have 24V in from the main board? No control signals like BLON? Some T-con boards have synchronisation signals which keep the inverter in step with the T-con. The idea is to limit apparent flicker and improve apparent motion response by blinking the backlight between frames.
  • eccerr0r
    inverter H tree driver imbalance in an AC inverter
    by eccerr0r
    My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
    11-16-2025, 12:34 PM
  • x_orange90_x
    by x_orange90_x
    01-29-2025, 09:24 PM
  • Gentian
    APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
    by Gentian
    I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
    It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
    03-06-2023, 07:07 AM
  • valvashon
    Insignia NS-LCD19-09 (PS OK, Inverter problem?)
    by valvashon
    For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
    History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
    01-04-2024, 01:44 PM
  • eccerr0r
    A modified sine wave inverter + a grid tie inverter?
    by eccerr0r
    If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
    Next thing is trying to charge the batteries using solar power, but that's another issue ...
    08-31-2023, 09:14 PM
