no picture on my samsung 50 inch plasma
  • jose6326
    • May 2013
    • 707
    Re: no picture on my samsung 50 inch plasma
    When I get home from work I will take a picture of the jumpered 4pin connector and the disconnected cable
    • jose6326
      • May 2013
      • 707
      Here are the pics
      I jumpered number 3 and 4 on the 4pin connector and disconnected the cable from the main board
        Well, I can't see anything wrong there. I'd consider a control board fault in this instance then.
        • jose6326
          • May 2013
          • 707
          Ok I guess I will order a board
          • jose6326
            • May 2013
            • 707
            Ok I got another logic board and I installed it
            It did not fix the problem
            Still a black screen
            And again I did NOT get any test pattern
            Im going to order the xmain board since the voltage is not correct
            I already bought every other board so buying this board at this point wont matter
            All is left is the main board
              No test pattern available with lit up screen is a fault I have only encountered when the Va voltage or data connections to the panel are missing or the panel is completely dead. But there are 15 drive packs on a 1080p panel like yours and for all of them to fail would be very unlikely.
              I would be surprised if it is the X-main board, unless the control board is sensing a fault and disabling the video output but leaving the Y-main alive, which would be a strange design.
              • jose6326
                • May 2013
                • 707
                So what else do you think it might be?
                  As I said I have not encountered this fault before and can't be sure. There is always a chance your replacement control board has the same fault. I've had an average 25% bad board rate from eBay.
                  • jose6326
                    • May 2013
                    • 707
                    This sucks
                    I wish I could borrow a known working logic board just to rule out this problem
                      The only thing that can diagnose this is an oscilloscope, any chance you have one or can beg/borrow/steal one?
                      • jose6326
                        • May 2013
                        • 707
                        There is one at my job I may be able to borrow
                        But I dont remember how to use it
                          I will be able to help you set it up if you can provide detailed pictures and follow instructions to the letter.
                          • jose6326
                            • May 2013
                            • 707
                            Sounds good
                            • jose6326
                              • May 2013
                              • 707
                              Here is the pic of the o scope
                              The "electronics guy" says it can only measure as high as 5v times 8 divisions and
                              5v peak to peak
                              Hope this makes sense
                                That scope will be fine, did you get an actual scope probe with it (with a tip and ground lead) and does your probe have a 1X/10X setting?
                                • jose6326
                                  • May 2013
                                  • 707
                                  Yes probe has 1x 10x settings
                                    On this board:
                                    https://www.badcaps.net/forum/attach...1&d=1369514611
                                    ...do you think you could take a picture from the left hand side so I can see partly under the heatsink?
                                    • jose6326
                                      • May 2013
                                      • 707
                                      I will take a pic tonite
                                      I have the o scope till Wednesday
                                      Hopefully i have internet connection to post
                                      • jose6326
                                        • May 2013
                                        • 707
                                        Here is a pic of the probes
                                        • jose6326
                                          • May 2013
                                          • 707
                                          Here is the pic if the left side of the y main
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • Cooperr
                                            Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                                            by Cooperr
                                            I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                                            The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                                            10-21-2025, 01:11 PM
                                          • ohren
                                            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                            by ohren
                                            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                            The models launched in 2018 and 2019 respectively....
                                            09-08-2023, 05:24 PM
                                          • alltvrepairs
                                            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                            by alltvrepairs
                                            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                            Any one met this problem in the past?...
                                            10-08-2025, 07:34 AM
