no picture on my samsung 50 inch plasma
  • jose6326
    • May 2013
    • 707
    Re: no picture on my samsung 50 inch plasma
    When I get home from work I will take a picture of the jumpered 4pin connector and the disconnected cable
    • jose6326
      • May 2013
      • 707
      Here are the pics
      I jumpered number 3 and 4 on the 4pin connector and disconnected the cable from the main board
        Well, I can't see anything wrong there. I'd consider a control board fault in this instance then.
        • jose6326
          • May 2013
          • 707
          Ok I guess I will order a board
          • jose6326
            • May 2013
            • 707
            Ok I got another logic board and I installed it
            It did not fix the problem
            Still a black screen
            And again I did NOT get any test pattern
            Im going to order the xmain board since the voltage is not correct
            I already bought every other board so buying this board at this point wont matter
            All is left is the main board
              No test pattern available with lit up screen is a fault I have only encountered when the Va voltage or data connections to the panel are missing or the panel is completely dead. But there are 15 drive packs on a 1080p panel like yours and for all of them to fail would be very unlikely.
              I would be surprised if it is the X-main board, unless the control board is sensing a fault and disabling the video output but leaving the Y-main alive, which would be a strange design.
              • jose6326
                • May 2013
                • 707
                So what else do you think it might be?
                  As I said I have not encountered this fault before and can't be sure. There is always a chance your replacement control board has the same fault. I've had an average 25% bad board rate from eBay.
                  • jose6326
                    • May 2013
                    • 707
                    This sucks
                    I wish I could borrow a known working logic board just to rule out this problem
                      The only thing that can diagnose this is an oscilloscope, any chance you have one or can beg/borrow/steal one?
                      • jose6326
                        • May 2013
                        • 707
                        There is one at my job I may be able to borrow
                        But I dont remember how to use it
                          I will be able to help you set it up if you can provide detailed pictures and follow instructions to the letter.
                          • jose6326
                            • May 2013
                            • 707
                            Sounds good
                            • jose6326
                              • May 2013
                              • 707
                              Here is the pic of the o scope
                              The "electronics guy" says it can only measure as high as 5v times 8 divisions and
                              5v peak to peak
                              Hope this makes sense
                                That scope will be fine, did you get an actual scope probe with it (with a tip and ground lead) and does your probe have a 1X/10X setting?
                                • jose6326
                                  • May 2013
                                  • 707
                                  Yes probe has 1x 10x settings
                                    On this board:
                                    https://www.badcaps.net/forum/attach...1&d=1369514611
                                    ...do you think you could take a picture from the left hand side so I can see partly under the heatsink?
                                    • jose6326
                                      • May 2013
                                      • 707
                                      I will take a pic tonite
                                      I have the o scope till Wednesday
                                      Hopefully i have internet connection to post
                                      • jose6326
                                        • May 2013
                                        • 707
                                        Here is a pic of the probes
                                        • jose6326
                                          • May 2013
                                          • 707
                                          Here is the pic if the left side of the y main
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • ohren
                                            by ohren
                                            09-08-2023, 05:24 PM
                                          • C152Heavy
                                            by C152Heavy
                                            Summary for TL-DR readers:
                                            • VCC pin (18) of PFC...
                                            01-11-2023, 02:53 PM
                                          • alltvrepairs
                                            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                            by alltvrepairs
                                            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                            Any one met this problem in the past?...
                                            Today, 07:34 AM
