Wharfedale LTF37K1CB Picture problem
    Re: Wharfedale LTF37K1CB Picture problem
    Originally posted by Smokin House View Post
    Ok tested again. with no power to the TV and with the plug at the power supply to the inverter unplugged. All 5 red pins have no movement on the meter, it stays showing 1__._ (the _ indicates no number)
    great,no shorts then !i would replace the output caps on the power supply and see how we go from there.
    by the way do you have an ESR meter?
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      Sorry no
        Sorry no
        direct replace those caps then
          OK. Thank you for all your help Multimeter (",)
          I will post back once I have got those 2 caps sorted and let you know how it goes
            Well I finally managed to get those 2 Panasonic caps (what a pain that was getting only 2 and cheap - ended up paying £3.78 for the pair, even though I had found them elsewhere for about 50p each) and replaced them today. TV's been on for an hour with no drop out and have turned it on/off/on/off/on/off a few times and starts first time every time and stays on every time (not like before)
            So THANK YOU to EVERYONE that helped me out and I will certainly return for any future help I may need.
            Also if anyone ever needs help with iPhones please PM me
