Ilo lct32ha36 dead
  • Beowulf
    • Dec 2012
    • 175
    Ilo lct32ha36 dead
    This tv looks dead, meaning there's no LED on.
    Looking inside none of the output voltages are present.
    Both fuses are OK on the PSU.
    I get 179v on both filter caps.
    On 0565r IC this is what I get:
    Pin
    1-179V
    2-GND
    3-VARIES CONTINUOUSLY FROM 9 TO 14V
    4-VARIES CONTINUOUSLY FROM 0 TO 3V
    5-NC
    6-VARIES CONTINUOUSLY FROM 0 TO 1.7V
    Attached is the datasheet for the 0565r IC.
    I'd appreciate any pointer on what to check next.
    Regards,
  • LDSisHere
    • May 2012
    • 727
    • U.S.A.
    Re: Ilo lct32ha36 dead
    I would advise you to pull the silver cover off of the main board(s) and have a look at the electrolytics there. I had one of these and the main board was covered in bad caps. One had even lost the outer sleeve.
    • cashkennedy
      • Aug 2011
      • 666
      I assume from your original post that you have used a resistor to start the power supply / and checked the voltages at the connectors on the edge of the PSU?
      If that's correct then your on the right track checking the power supply as the power supply should be able to start on its own if you force it to regardless of the main board.
      Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
        It sounds like that standby power supply is trying to start, try heating up those small caps by the IC with hair dryer for 2-3 minutes to see if you can get out put voltage at the filter caps on the secondary side of the transformer.
        • Beowulf
          • Dec 2012
          • 175
          Hey thanks for the pointers, I'll check it out just in case.
          Uh! I think this one is an always-on, also I still should be able to get standby voltages. Thanks for the input.
          Alright I put some little heat on those caps and something weird happened, one smd resistor on the bottom side of the board blew up big time And no, none of the fuses got blown.
          Hell I bought a board for $54 from shop jimmy. I'm not giving up on the repair though. I'll use the good board to help me fix this one and have two. Use one and post the other one for sell on ebay. Give me a few days to get back with an update.
          Thx
            Hmm, that SMD resistor that blew up seems to be connected in parallel with the other 2 large grey through hole resistors. Those resistors seems to be connected in parallel with the two large filter caps (450Vdc caps). Can you verify that?
            • Beowulf
              • Dec 2012
              • 175
              The three resistors are in parallel among them yeah. One side of the resistors connect to the negative of the filter caps and the other goes to a pin of the bridge rectifier labeled as (-) negative.
                That does not make sense at all since the negative of the bridge should be directly connected to the negative legs of those two filter caps. I am trying to trace out the connections but having hard time doing it.
                • Beowulf
                  • Dec 2012
                  • 175
                  Call me crazy but I've checked it like ten times visually and using continuity with the meter. I also found it rather strange. It wouldn't be the first time I get a tv with manufacturing defects. I'm anxious to see how the one I ordered is wired up.
                  Attached is a picture explaining it more.
                    How low is the resistance of those resistors, less than 1 Ohm? It may be using that as fusible resistors.
                    • Beowulf
                      • Dec 2012
                      • 175
                      They're 0.39 Ohms. And they're cracked, probably from that little incident earlier lol.
                        For now, it is OK to leave it as is, I do not really know why it has small 1/8W resistor in parallel with the other two large Wattage resistors, since the circuit is not open, the two caps will be charged up OK. I would like to find out if heating those small caps in the standby power supply make it start running again.
                        • Beowulf
                          • Dec 2012
                          • 175
                          Alright I'll try that tomorrow.
                          • Beowulf
                            • Dec 2012
                            • 175
                            Alright I tried it like this and put some heat on those little caps and it did not do anything.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              From PlainBill, I learned there are 3 likely suspects.
                              1) the startup cap is bad - easy and cheap to replace with a Panasonic FC. I like to keep a stash of 47uF 50V and/or 22uF 50V caps just for these occasions.
                              2) the SMPS IC is bad
                              3) something shorted on the output side dragging down the power supply. something like a shorted diode. It would probably only take you 5 minutes to test all the diodes in circuit. If one reads shorted in circuit, desolder to verify readings.
                              --- begin sig file ---
                              --- end sig file ---
                                I would replace those start up caps, they should be replaced anyway so you do not to replace them in the future, it should be part of the cap replacement kit.
                                • Beowulf
                                  • Dec 2012
                                  • 175
                                  Thanks guys. I'll let you know how it goes when I get down to working on this board again, after I receive the new one.
                                  I'll order some of those caps to keep in stock too.
                                  Regards,
                                  • double_DD
                                    How can I be sure that my EC chip is dead?
                                    by double_DD
                                    As the title suggests, how can I be sure that my EC chip is really dead?
                                    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                    03-12-2025, 07:47 AM
                                  • disorder
                                    ps5 edm-033 dead after hdmi/usb ports destroyed
                                    by disorder
                                    hello guys,
                                    i need help to repair a edm-033 ps2
                                    history : as always hdmi port and usb ports destroyed after unplugged
                                    after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                    so i changed it
                                    now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                    but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                    i don't see any projection of liquid metal on pcb.
                                    01-14-2025, 12:48 PM
                                  • Beton
                                    Finding a dead short component
                                    by Beton
                                    Hi guys!
                                    I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                    So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                    I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                    I have a bench PSU and if I try to inject voltage the voltage...
                                    12-10-2021, 01:05 PM
                                  • zunasthegreat
                                    Chieftec GPS-450-AA with dead 20N60C3
                                    by zunasthegreat
                                    Hello everyone hope all doing well!
                                    I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                    09-01-2024, 07:12 PM
                                  • FiguringITout
                                    MSI Raider GE75 - Not posting, probable dead CPU
                                    by FiguringITout
                                    Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                    Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                    07-25-2024, 07:27 AM
