I have a magnavox 42mf531d/37 lcd . 4 caps were popped on power supply. It would not do nothing. Replaced the three 1500uf 35v caps and the 2200uf 25v and now it sounds like its coming on but still doesnt light back light. I have 24v at the plugs going to each side of the inverter boards but its like somethings not telling them to come on. I can slightly unplug the left board and the backlights begin to flash but wont stay on its like its jumping the voltage to another pin. What direction now.
Recapped Magnavox 42mf531d/37 still no inverter lights
Tags: None
Re: Recapped Magnavox 42mf531d/37 still no inverter lights
Check BLON, DIM on connector. You have 24V and GND wires, then two wires for the BLON and DIM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Also check the caps in both inverter boards, all fuses, especially if it has small black fuse with '15' or '20' on the top. Also inspect the IC and the MOSFETs of both boards.
Chassis number of this TV?Never stop learning
Alright on powersupply voltage on plugs to backlights
Left backlight right backlight
0v von 0v g
0v vdim 0v g
0v g 0v g
0v g 0v g
0v g 0v g
0v g 24v v
0v g 24v v
24v v 24v v
24v v 24v v
24v v 24v v
24v v
24v vComment
OK, it is not getting either BL_ON (Von), or the Dimming signal (Vdim) from the main board.
Time for more pictures of the boards.Never stop learning
Here are the pics i did find a smoked place on the cover over the main board it was directly over the black square thing in the bottom middle of picture 5.Attached Filesif you find these attachements useful please consider making a small donation to the site
So far I cannot find the service manual for this model, we will need that to troubleshoot the main board. Is there chassis number on the model number sticker tag? Something like Model number xxxxx TPE1.0U-LANever stop learning
No additional
information was on tag
just the 42mf number.Comment
Can we see the tag? Very strange if that is the case.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
One other thing, those axial lead Nichicon are not low esr so not suitable for the PSU. Not going to be a problem yet (24V is good) but may be a problem when under load or after the caps have aged.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Where is the tag located you want to see.Comment
The tag which you state only has the model. It may be in a different encoding.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I have the service data if needed it 's large file I'll be glad to upload or send
also have the panel info just need the information on sticker in set there's about 4 panel versionLast edited by RON_CET; 05-11-2013, 09:39 AM.Ron Driver,BSEE,CET,ISCET,NESDAComment
Here's the service data from your picture for the panel,also attached is a service bulletin,check make sure your serial number falls within the scope of this bulletin,hope this information helpsAttached Filesif you find these attachements useful please consider making a small donation to the site
Not that familiar with surface soldering, repalcing these things fix the signal power to the inverter boards.Comment
I have just noticed this repair is for a 42mf231d/37 and i have a 531d so this
would not apply to my unit.Comment
I have checked diodes on power supply none were shorted except one that was setting the meter off both ways , i took it out of the board and it tested normal i guess its in a parallell or something. Anyway diodes seem to be ok.Comment
Well, you have 24V, problem is not on PSU...
VON is your problem, so mainboard has to be considered.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Well i know that the main board had a couple of smoked spots so i may have to try another board. thanksComment
by eccerr0rMy cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...Today, 12:34 PM
by x_orange90_xI just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
I don't know how exactly to test the inverter itself. Is it... -
by lostoneHello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...-
by GentianI have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...03-06-2023, 07:07 AM -
by tonybig10Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...-
Channel: Schematics and Boardviews
03-07-2025, 01:03 PM -
- Loading...
