Horizontal colored line on screen of SONY 32" LCD TVC
  • Ahakim
    • Apr 2013
    • 64
    I fell yesterday on a 32" LCD Sony with the following "anomaly":
    Just after turning on: very good nice clear image except for a "bothering" horizontal colored line exactly 6.5cm from top of screen all the way from left to right..
    Sound normal.
    But after 10 mn, many many interfering(moving up & down) horizontal lines start to appear only on lower half of screen forming a "net" over the image, with much less contrast on this lower half (the first bothering line on top is still there..) Image stays that way untill TV is turned off.
    Later on, I will give more details (model of this SONY...)
    What could be the origin of the problem? SPMS seems good (all sources)
    Re: Horizontal colored line on screen of SONY 32" LCD TVC
    Probably the tab bonds at the top of the display panel.
    • Ahakim
      • Apr 2013
      • 64
      Thanks for the reply. Seems I have to change the whole panel!! Or can the tap bonds on top of screen be repaired... fixed? Here are some more details about the TV (information on back cover):
      SONY
      Model No: KLV-32BX300
      LCD color TV
      110-240VAC 50/60Hz 109W
      One more thing: the "moving lines" lines start in fact from the line I indicated before all the way down, not from middle of screen...
        Whether or not it is repairable depends on the failure. In some cases you can apply a "shim" to the tab to help it make better contact.
        https://www.youtube.com/watch?v=purk_SyiT44
        • Ahakim
          • Apr 2013
          • 64
          Interesting good short term solution (tab bonds are very fragile as you know). It might work for a long time though.. Nice video.. Thanks anyway. I'm going to try it.
          • Ahakim
            • Apr 2013
            • 64
            After verification, I found:
            - Tab bonds both 100% OK on top of display panel.
            - Broken edge of LCD panel glass of about 2mm in far right lower corner.It wouldn't be the cause of the problem, would it?
            - Why does the video signal of the MENU of a demo appear fine on screen? Only when image (and sound) are released from a TV chanel such as CNN for example that the anomaly occurs? After this observation, I start now to suspect the motherboard. Any ideas??
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              The crack in the LCD shouldn't be the cause if you say the menus are not corrupted. As you suspect, this is likely a main board issue.
              A working TV? How boring!
                A cracked LCD can and will cause vertical line defects.
                • Kiberge
                  Samsung LH82QENELGC/EN Help needed - Static line on screen
                  by Kiberge
                  HI guys!
                  I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                  I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                  the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                  This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                  04-22-2024, 11:28 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • Ihandyrepair
                  Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                  by Ihandyrepair
                  Hi guys
                  I just started fixing 4k TV few months ago. so I am still learning a lot
                  I got this tv from friend complaint is ghosting or horizontal lines on image.
                  never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                  then it started to show the ghosting white image.
                  I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                  it has 3 thin small boards at the bottom of the...
                  12-05-2022, 04:18 PM
                • almarhum
                  To fix laptop screen vertical line by working on its EDP cable
                  by almarhum
                  Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                  As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                  05-07-2024, 02:12 PM
                • cubytus
                  Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                  by cubytus
                  Hi to all,
                  I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                  I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                  Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                  01-10-2024, 01:26 AM
