About LCD technology...
  • Ahakim
    • Apr 2013
    • 64
    I'm not sure if this post should be in this section!
    I want to understand (in depth) how digital video signals are oriented to the right cells/pixels in LCD TVs to produce the color image. I read Jestine Yong's books on the matter but I still have many (unsolved) questions about active-matrix (TFT technology) inside theTV panel. For instance: does each cell in the pixel work in a digital way 0-1 or does it receive (via TFT switching) a controlled amount of voltage to make the cell crystal twist only enough to let white light pass through..(depending on the color wanted to give the right image)?
    ANY other books on the matter? THANKS.
    Re: About LCD technology...
    Each cell is a thin film transistor which controls the orientation of the LC (liquid crystal.) The LC rotates the polarised light to allow varying levels of light through the front polariser.
    Each TFT has three external terminals. You have the SOURCE, GATE and DRAIN. It's just a NFET (or PFET? Not sure.)
    The drain (backplane) is tied to the VCOM for the LCD panel, which is placed at approximately half AVDD. AVDD is the maximum swing of the source output. This allows for easy AC inversion of pixels (more on this later.)
    The gate driver is found alongside the rows of the panel and controls which row receives data from the source drivers. The gate driver uses the VON and VOFF voltages (multiple names: TFT_ON, TFT_OFF, VGH, VGL, etc.) VON is around 20V, which turns on each of the TFTs in the appropriate row. VOFF is around -8V, which turns off all of the TFTs in that row. Each gate driver has multiple outputs, there might be four on a 720p panel giving 180 channels per IC. Each driver is usually a shift register as that's typically the easiest method for selecting rows one at a time. Selecting each row one at a time through the shift-register gate driver allows data to be loaded into the panel, through the source drivers, which allows for an image to be stored on the panel. However, unlike a plasma panel, once the data is loaded it need not be sustained. It simply appears once light shines through.
    The source driver is what controls the intensity of each pixel. Each source driver has many DACs across many outputs. Typically, for a 720p panel using 6 drivers, each source driver will have 360 output channels. Each output channel has a 4-bit DAC plus 4-bit mux with a range from 0V to AVDD. The mux selects between gamma levels, and the DAC interpolates between two levels that the gamma IC produces. DAC implementations vary. Cheapest is charge-pump using time and capacitor, however, it is generally quite inaccurate. Common type is a common resistor ladder, with each DAC being a 16 way mux (so there are two muxes.) Typically 16 gamma levels are used, giving a total of 256 levels (16 DAC levels * 16 gamma levels.)
    The output from the gamma IC is a nonlinear curve which allows translation from the nonlinear response curve of the TFT and LC to a more linear response which closely matches that of the human eye and the defined gamma properties of the LCD.
    If you charge a pixel with a constant brightness then after some time it will permanently take this state; this is known as burn in and can occur on LCDs which do not use a VCOM inversion circuit. The VCOM set at mid AVDD allows the LCD drivers to alternately drive a pixel negative and positive, with the same apparent brightness level in each state, giving an average zero DC level, minimising chance of burn in. If VCOM were not used, then each driver would need twice as many output levels and a bipolar swing, much more expensive.
    That's about all I know from a bit of research on the subject.
      Read more about it here:
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Holy cow, I know this was not my thread but I finally (kind of) understand how an LCD works. Thank you!
        • Ahakim
          • Apr 2013
          • 64
          Many thanks for the explanation & the time you gave(veterans)...As well as for the very helpful/useful Sanyo manual. It really helps.
          • osrex
            LED DRIVER KEEPS DYING
            by osrex
            Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
            i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
            i have no datasheet at all for the LED lights, all i have is its length.
            long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
            as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
            05-05-2025, 03:36 PM
          • howardc64
            Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
            by howardc64
            Problem
            Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
            Model & Board Pics
            Conflicting Spec
            Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
            https://www.shopjimmy.com/vizio-gj-2k1...
            10-10-2024, 01:16 PM
          • charif
            Audio Driver for Thomson P14C4BK128
            by charif
            Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
            I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
            The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
            Here are the details:
            • Model: Thomson P14C4BK128
            • Operating System: Windows 10 64-bit
            If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
            Thanks in advance for your help!
            04-30-2025, 05:41 PM
          • bohaboha
            how to install gl usb2.0 uvc camera device driver on windows 10
            by bohaboha
            Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
            but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
            any help?
            01-26-2025, 08:33 PM
          • Daveleone
            UN55D6900 BN44-00428B partial led driver circuit failure
            by Daveleone
            Hello TV experts! I have a UN55D6900. The successfully TV turns on, and the backlights light up, and I get a picture, but there is a section that is dim. I took it apart and 1 out of 4 segments of backlight LEDs are not lighting on both sides of the TV (in other words, the same segment is out on both LED strips).
            I tested the LED strips with my LED tester and all of the LEDs light properly, so I believe the problem is with the PSU/LED driver board (BN44-00428B). The voltages at CNM810 (between PSU and main board) look ok to me. The voltages at CNL801A and CNL801B look off for one...
            07-23-2021, 06:31 PM
