Panasonic Th 50PX70B 12 Blinks
  • onpiopah
    • Apr 2013
    • 22
    Re: Panasonic Th 50PX70B 12 Blinks
    I have been doing a bit of research and I am advised that if I am working on a power supply I should be using an isolation transformer - but I am having problems finding exactly what I should be using.
    Can anyone advise on what type and where to get one from?
      It's not vital if you are careful not to touch any part of the HOT side of the P board. The HOT side is surrounded by a white border and has "HOT" or "LIVE CIRCUIT" in it in places.
      • onpiopah
        • Apr 2013
        • 22
        Still trying to fix my Plasma. Could someone please tell me what these components are and what they do. The schematic is from the powerboard of the above Plasma and I am interested in L601 and L602
        thanks.
          They are the EMI filters for the input power -- they limit the noise the power supply kicks back into the mains. If your TV has power, they are not the fault.
          • onpiopah
            • Apr 2013
            • 22
            I am struggling to understand what this component does. It is on the power board of the above Plasma and is designated
            L608
            thanks if you can help me out, as I cannot find it on the schematic
            • onpiopah
              • Apr 2013
              • 22
              #26
              thanks Tom, I made a mistake reading the schematic, i know about the EMI filters its the L608 I really needed to know about. Sorry for the mistake.
                It's a ferrite bead -- again limiting the noise the power supply produces. It should appear as a short circuit on your ohmmeter, it is basically a piece of wire with magnetic material around it.
                • onpiopah
                  • Apr 2013
                  • 22
                  #28
                  cheers Tom.
                  • onpiopah
                    • Apr 2013
                    • 22
                    #29
                    Can someone please advise me of why the lines on this schematic are traced in orange. I know it is probably fairly intuitive and simple but your help would be appreciated.
                      It means they are the major buses carrying power. Blue indicates a different voltage, etc.
                      • onpiopah
                        • Apr 2013
                        • 22
                        #31
                        I am a bit confused, if that was the case why are the lines in and out of the bridge not Orange also, as surely that is a major power carrying line. I am not disagreeing with what you state, just trying to understand in more detail.
                          They only use them on the secondary outputs (isolated from primary), typically on the digital boards, to ease tracing through the fault. You won't see them so often on the power boards because those are easier to follow through, but some of the digital boards can be hard to trace otherwise.
                          • onpiopah
                            • Apr 2013
                            • 22
                            #33
                            thanks thats good information to know and really helps me out.
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                            • m1ch43lzm
                              by m1ch43lzm
                              05-12-2025, 08:37 PM
                              After all of...
                              07-13-2024, 08:14 PM
                            • canadaboy25
                              Panasonic TC-P54VT25 No image. A or D board?
                              by canadaboy25
                              I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                              I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                              01-17-2021, 01:06 AM
                            • Biruslapio
                              Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
                              by Biruslapio
                              Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
                              It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
                              It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
                              02-16-2021, 09:44 PM
