Polaroid FLM-4034b issues
+ More Options
Posts
  • landyboy
    • Apr 2013
    • 443
    Ok since you guys helped me fix my first set I picked up another one to try. Its a Polaroid FLM-4034b. It will power up to a blue screen with the words no input. I can get the menu to come up but thats it. It does click and pop a little and every so often it will make a loud buzz. The screen also appears to have random lines running through it at times. The screen also goes through different color patterns. I have opened it up and there are no "visual" signs of bad capacitors. Any ideas? thanks
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Polaroid FLM-4034b issues
    I've fixed several Polaroids similar to this one. It's more than likely either bad caps that aren't bulging or a main board going bad. These seem to be the only issues with these sets. Do you have an ESR meter? Can you post pics of your power supply and main board?
    • johnboy1313
      • Nov 2012
      • 1959
      Also, since it looks like you got the other one fixed. It would be nice of you to follow up on that thread and post what the fix was and that it is working. It helps anyone that might be having the same issue with the same set in the future.
      • landyboy
        • Apr 2013
        • 443
        Yes I can get pics. I do not have an esr meter. I am out of town for a couple days I will post pics as soon as I get home. And yes I will update the other post.
        • johnboy1313
          • Nov 2012
          • 1959
          It's possible that you have a bad cap or two in the PSU, but I'm suspecting a bad main. I had a Polaroid FLM-323B with similar problems. The blue screen showed, the menu would show but the input screen wouldn't. It turned out to be a bad main board.
          • landyboy
            • Apr 2013
            • 443
            Here are some pics...
            • landyboy
              • Apr 2013
              • 443
              Did some checking main boards are hard to find for this model. Can the main board be fixed? Should I look for bad caps or is there something else I should look for?
              • landyboy
                • Apr 2013
                • 443
                Should I check for bad Voltage Regs on the main?
                • johnboy1313
                  • Nov 2012
                  • 1959
                  You can check the regulators, I've had four of these style TVs come across my bench in the last couple months. One of them had bad caps. The other three were all main boards. I checked all of the regulators and DC-DC converters and didn't find anything out of whack. If you haven't already, it wouldn't hurt to check the voltages coming from the PSU.
                  • landyboy
                    • Apr 2013
                    • 443
                    Ok I found a what I believe to be an adjustable regulator out of tolerance.
                    1084 PE
                    Pin1 1.356
                    Pin2 2.603
                    Pin3 4.222
                    According to the chart provided on Badcaps pin 1 should be reading 0. Am I correct?
                    • landyboy
                      • Apr 2013
                      • 443
                      I read the chart wrong, I think the reg is good. Pin2 is Pin1 plus 1.25v sorry.
                      • landyboy
                        • Apr 2013
                        • 443
                        Voltages from the PSU are correct.
                        • landyboy
                          • Apr 2013
                          • 443
                          I took some additional pics of the different phases of the screen.
                          • landyboy
                            • Apr 2013
                            • 443
                            Thoughts?
                              Definitely looks like a main board issue to me.
                              The large BGA processor with the heatsink has probably overheated, this is introducing errors into the processing of the video.
                              You can try reflowing the processor, but it would only be a temporary measure, at best.
                              • landyboy
                                • Apr 2013
                                • 443
                                Ok finally got back around to this one. Ordered a replacement main board and now I have this. I'm thinking another bad main board?
                                  That looks like Gamma voltage problem on the T-CON board like this SAMSUNG.
                                  http://s807.photobucket.com/user/bud...?sort=3&page=1
                                  All the connectors are properly seated?
                                  • Dgtech
                                    E. Technician
                                    • Apr 2009
                                    • 1462
                                    • Steeler
                                    Looks more like T-conn board failure to me.
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      Could be T-Con, but could be a bad main as well. What does the menu look like with no signal applied?
                                      https://www.badcaps.net/forum/showthread.php?t=27876
                                      • kevinjo
                                        • Aug 2014
                                        • 49
                                        I also have the solarized video but it is not the tcon as I have tried 2 known working tcons. I think there is a main board issue but unsure where to look. Anyone have any ideas? Thanks. Mine is a FLM-3232.
                                        • jkruns
                                          M1 A2338 screen and touchbar issues after cleaning up liquid damage
                                          by jkruns
                                          This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
                                          My patient is an A2338 Macbook Pro M1 (late 2020).
                                          It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
                                          04-22-2024, 06:45 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • aazjo
                                          A1502 screen only issues
                                          by aazjo
                                          I have a MBP A1502 (early 2015, 820-4924) with a screen that will not turn on. I have swapped screens with a cracked test screen and the computer boots and the cracked screen works for both backlight and image. The black/blank screen appears to do nothing.
                                          I have collected resistant data from the cracked screen connector pins and submitted to OBData server:
                                          1 PPVOUT_SO_LCDBKLT OL
                                          3 I2C_BKLT_SCL 9.97M
                                          4 I2C_BKLT_SDA 9.89M
                                          5 PP3V3_S0_EDP_R 79.10k
                                          6 SMBUS_SMC_0_S0_SCL 321k
                                          7 SMBUS_SMC_0_S0_SDA 323k
                                          8 EDP_BKLT_PWM ...
                                          11-04-2021, 11:46 PM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
