Polaroid FLM-4034b issues
  • Clydeuk
    • Jan 2012
    • 193
    Re: Polaroid FLM-4034b issues
    That looks very much like the board you've got is for a different LCD panel so the LVDS mapping is not right for the panel you have, also it doesn't look like it's filling the screen. I have no idea how to access the service menu on this but some sets allow you to change the panel type in that.
    • Clydeuk
      • Jan 2012
      • 193
      Some of the Polaroid branded sets I've encountered here have responded to Beko remote codes on a universal remote, so it may be worth trying the Beko methods for getting into service mode. Others I've seen are made by Vestel, though looking at your boards I would say yours isn't.
      • Shinju
        • Mar 2014
        • 1239
        That image issue looks like a panel type incompatibly issue. I Have had samsung panels that boot like this that all I had to change in the SM was panel type and when I found the right type the picture was perfect.
        I don't know how to access the sm for a Polaroid but I would start there before spending more money on boards.
        • Shinju
          • Mar 2014
          • 1239
          Some examples.
          https://m.youtube.com/watch?v=Q1bg9qP_qic
          https://m.youtube.com/watch?v=c-aXKCTiU6I
          • jkruns
            M1 A2338 screen and touchbar issues after cleaning up liquid damage
            by jkruns
            This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
            My patient is an A2338 Macbook Pro M1 (late 2020).
            It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
            04-22-2024, 06:45 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • aazjo
            A1502 screen only issues
            by aazjo
            I have a MBP A1502 (early 2015, 820-4924) with a screen that will not turn on. I have swapped screens with a cracked test screen and the computer boots and the cracked screen works for both backlight and image. The black/blank screen appears to do nothing.
            I have collected resistant data from the cracked screen connector pins and submitted to OBData server:
            1 PPVOUT_SO_LCDBKLT OL
            3 I2C_BKLT_SCL 9.97M
            4 I2C_BKLT_SDA 9.89M
            5 PP3V3_S0_EDP_R 79.10k
            6 SMBUS_SMC_0_S0_SCL 321k
            7 SMBUS_SMC_0_S0_SDA 323k
            8 EDP_BKLT_PWM ...
            11-04-2021, 11:46 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
