Panasonic TH-46PZ80U
  • Notor
    • Apr 2013
    • 6
    Hello, first post here.
    I've had my Panasonic since 2009. It operated perfectly until about 2 weeks ago, when it wouldn't turn on suddenly and gave me the 10 red blinks issue. I unplugged all inputs, unplugged the TV, and the next morning plugged everything back in and it worked perfectly.
    However, today it won't turn on and is giving me the 2 red blinks error. I have no idea how to fix this issue, and am pretty distressed as I don't have the money to pay someone to fix it, and the TV is only 4 years old. I haven't tried to contact Panasonic but I'm sure the TV is out of warranty.
    Can anyone help me with this 2 red blink issue? It started with 10 but now it's only showing the 2 red blinks. I have some experience with assembling computers but no experience in electronics repair or replacing caps or anything like that (i've tried to scan some threads). I don't really have any tools at my disposal outside of a screwdriver. Any help you guys could offer would be really appreciated, because if I can't fix it myself I don't see how I can get it fixed.
  • capkid
    • Oct 2010
    • 1339
    Re: Panasonic TH-46PZ80U
    My TH-50PZ80U had a similar issue a few years ago. It took me a month of off-and-on testing to drill down to the cause, which coincidentally is shown in this video that includes the repair: http://www.youtube.com/watch?v=LjpGKaBt8hg
    When I did this repair, I did not replace the TEA1611 chip. I just replaced the capacitor. My TV has been working flawlessly for about 2 years. I can't guarantee that this will resolve your issue, but it's likely.
    LG Plasma Mal-Discharge Correction Service
      2 blink and 10 blink are caused by one of the ceramic caps on those boards failing -- but replace both for reliability. SMD electrolytics work good.
      • Notor
        • Apr 2013
        • 6
        Can anyone suggest caps or point me in the right direction? I'm open to fixing the issue but like I said I have 0 experience in electronics/TV repair. A link to a thread or a link to what I need to get would be much appreciated.
        Thanks a lot guys.
          Norcal's video, linked above, will guide you through the repair. Watch it all the way through as he talks about all parts of the repair. It is not necessary to replace the TEA chip in the vast majority of cases, so replace the cap only for now.
          • capkid
            • Oct 2010
            • 1339
            Thanks a lot guys.
            Yeah, I linked to the same video that Tom did in an earlier post. I'm not sure what else to tell you. If you have zero experience, you might have to seek out someone to do the repair for you. The repair isn't too terribly difficult, but you could damage the small module if you're not careful; those modules are hard to find, and they're pricey if you do find one. Do you have any friends with electronics experience that like beer? :-) Maybe a local repair shop can do it cheaply, since we've already pointed you in the suspected right direction.
            • Notor
              • Apr 2013
              • 6
              Anyone have a recommendation as far as what solderer to use? Also, just so I'm clear, I need two TEA1611 chips and 2 ceramic capacitors to make this repair?
              What is the exact capacitor for this repair and where can I find it? Any help would be much appreciated, I've been TV-less for like 5 months now and I really want to play GTA V
              • capkid
                • Oct 2010
                • 1339
                If you've never used a soldering iron, and you're at all hesitant, I'd find someone to do it for you. Again, if you damage one of the MC modules, it's most likely game over and you'll have to buy a replacement PSU.
                http://www.ebay.com/sch/i.html?_saca...t&LH_PrefLoc=1
                I used ceramics once, then I switched to electrolytic caps on the next two Panasonics I worked. The caps are 1uF/50V.
                Did you watch the video to familiarize yourself with the process?
                (1) I use a cheap Xytronic temp-controlled soldering iron with a chisel tip; a Radio Shack iron might be fine for this job
                (2) 60/40 rosin-core solder
                (3) Flux pen
                (4) Solder sucker or some other solder removal tool to remove the MC modules from the board.
                • Notor
                  • Apr 2013
                  • 6
                  Yes, I watched all the video. I did the air can/refrigerant diagnostic, the TV powered up after I used the refrigerant on the TEA1611 chip that is more toward the left side of the PSU. It was giving the 2 blink/10 blink error code beforehand. I used the refrigerant on one chip, attempted power up, and waited 15 minutes and did the other one. The TV only turned on after I used the refrigerant on the chip located more toward the left.
                  I have never soldered before but I feel like this is a good learning experience and I'd prefer to attempt it myself. Any tips would really be appreciated, I feel like I've watched that guy solder 10 times and he makes it look so effortless.
                  • capkid
                    • Oct 2010
                    • 1339
                    Ok, cool. I'd change out both chips and both caps to prevent having to open the TV later. The chips and caps are cheap. Like I mentioned earlier, though, I only replaced the cap on the MC301 module, and my TV's been working fine for over two years.
                    (1) Through-hole solder removal: First, you'll need to remove the MC modules from the board. I'd remove and work on one at a time to avoid confusing them. This is where the solder sucking device or wick comes into play:
                    http://www.youtube.com/watch?v=CuH3dWHipKI
                    http://www.youtube.com/watch?v=hQFpYN2FPN0
                    (2) You're going to be doing strictly surface mount soldering on the MC modules. I used my hot air station to remove the chip, but the method Norcal715 used works great, too. You'll need to make sure the TEA1611T chip is aligned correctly and avoid bridging the pins with solder when you install it. Also, flux is a must: http://www.youtube.com/watch?v=3NN7UGWYmBY. Installing the cap can be a bit tricky - just avoid heating the small cap pads on the module too much, and try to avoid touching components that are close by with the iron.
                    (3) Installing the module on the PSU after completing the chip and cap replacement: http://www.youtube.com/watch?v=4oyJYZRRU8c. I had to put something under the module when I had the board turned over to prop it up so that it wouldn't fall as I was soldering at least the first pin.
                    • Notor
                      • Apr 2013
                      • 6
                      I am going to attempt the fix tomorrow. Is a solder sucker or a wick easier to use for the purpose of removing the modules?
                        Wick - by far.
                        • Notor
                          • Apr 2013
                          • 6
                          Thanks for all your help guys, I completed the repair and my TV is up and running. Fans sound a bit odd though, like a bit of a muffly whining sound, very quiet, any thoughts?
                          TVs been off for so long I don't know if that's normal or not, other than that it's working as intended. Thanks again.
                            Do you smoke cigarettes (around the TV?) I had the same problem until I found that the cigarette gunk had built up in the fans. Cleaned that out and they ran smooth. Now I know why I don't smoke. Awful stuff.
                            • capkid
                              • Oct 2010
                              • 1339
                              Nice job. I'm glad you were able to get it running again.
                              • bluto
                                • Oct 2007
                                • 560
                                Does anyone know the if there are polarity issues when replacing the ceramic SMD caps with electrolytics? Since ceramic are not polarized and 'lytics are... I am sure that it matters which direction you install them. I have never been able to verify this and I really need to replace mine before the TV craps out.
                                • capkid
                                  • Oct 2010
                                  • 1339
                                  Yes, the polarity is specific. Watch the video included in this post to see the correct orientation: https://www.badcaps.net/forum/showpo...25&postcount=2
                                  • Nairolf
                                    Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                    by Nairolf
                                    I have a Samsung DM32D display.
                                    When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                    Here’s what I have tried so far:
                                    1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                    2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                    3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                    From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                    08-24-2025, 03:47 AM
                                  • Taurus12
                                    Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                                    by Taurus12
                                    Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                                    I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                                    i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                                    Any recommendation on what I have to do next? Thanks in advance
                                    06-10-2025, 05:05 PM
                                  • Biruslapio
                                    Panasonic P58V11B 8 and 12 blinks error "fix"
                                    by Biruslapio
                                    Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                    Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                    04-13-2021, 07:13 AM
                                  • Andre Gilbert
                                    by Andre Gilbert
                                    11-20-2024, 08:52 PM
                                  • Ancient1
                                    I'm stuck . Panasonic TH-L32U20M panel's boards issue
                                    by Ancient1
                                    Hi
                                    The TV seem to start ( blinking green) but goes into blinking red. No display and or backlight. Full view photo.
                                    Actions :
                                    1. Disconnected Panel's Right, 2nd, board : TV comes ON (steady green , no blinking red )
                                    1a. You can see in two photos the B/W screen , fading blue "HDMI12" , and the wierd sides of the image, like an old CRT.
                                    Obviously the fault is from or on the Right, secondary board
                                    2. I taped the Flex tracks, ~2 tracks at a time- see Photo. The issue seems to be on the V lines (Assuming Data...
                                    09-03-2023, 03:51 AM
