LG 50PQ20 Plasma no pic/no sound
  • pk7tanner
    • Apr 2013
    • 98
    No background on the TV. The light on the front flashes red, blue 2X and then stays blue. I took the back off, I had it laying screen down on my coffee table and powered it on. When I did, it made a little static noise and I looked to see if there was any picture (there wasn't) and then I noticed two resistors glowing orange/red on the Zsus (part # 50G2A_Z). Is the board repairable and is the fault within that board or is it caused by something else?
    Re: LG 50PQ20 Plasma no pic/no sound
    The Z-sus is a common failure on this model.
    I think someone has a repair kit but you can buy the board too
    http://www.ebay.co.uk/sch/i.html?_tr...at=0&_from=R40
    • pk7tanner
      • Apr 2013
      • 98
      Is the failure (most likely) isolated to this board and what parts would I need to repair the board (just the resistors?)?
        It is most likely isolated to that board but some tests can be made. You will need a digital multimeter, do you have one?
        As far as repair goes it is probably those two resistors plus associated components like FETs, driver ICs, diodes, etc. If you can locate all the failed parts it can be considerably cheaper than replacing the board but sometimes it is not worth the time because if you miss one component, all your new components can possibly go back up in smoke.
        • pk7tanner
          • Apr 2013
          • 98
          Yes I do have digital multimeter. And let me add that I have tested the power out on the psu board and all the v were correct. While I am awaiting your response I'm going to check if I have any audio now with the Z-sus disconnected.
          Side note:
          Parents of the world need to raise more people like tom66. A person who is willing to help others learn information he (likely) paid to obtain, is a trait that's exceedingly rare.
          • pk7tanner
            • Apr 2013
            • 98
            tom66 if Z-sus board is the only issue/if I am able to fix this TV, how should I expect it last? Is there a way to prolong the life of this TV? I'm fairly good customizing/modding
            • pk7tanner
              • Apr 2013
              • 98
              thanks for your help
              • pk7tanner
                • Apr 2013
                • 98
                Found a board on ebay for $14.00 incl. s/h with 30 day warr. So i figured it's worth the risk. I'll let you know how it turns out. thank again
                  Good luck. I never paid for any of this information though. It's all learned from experience -- over 50 TVs so far and counting. The service manuals in my signature are all sourced from the manufacturers directly, sometimes through other TV technicians.
                  • pk7tanner
                    • Apr 2013
                    • 98
                    Well I was should've known what I didn't check would be the problem (US Air Force better not let anymore Murphy's make laws). It's the Y-sus and I am going to attempt to repair the board myself. Any tips?
                      You haven't yet provided pictures of the layout of the TV, I'm not sure if this TV uses combined energy recovery which sometimes requires both Z-sus and Y-sus to be repaired or replaced at the same time.
                      • pk7tanner
                        • Apr 2013
                        • 98
                        Not knowing the the history of the TV proved to be part of the issue, the Y-sus board has obviously been worked on by someone w/o much skill. I didn't know I was expected to provide pics. Sorry
                        pics
                        1 back of tv
                        2 Y-sus
                        3 Z-sus
                        4 Pwr Brd
                          Looks like it's independent ERC to me; good, as that usually means failure is constrained to one board or the other.
                          As far as repairing the Y-sus, look at each component and test for shorts.
                          • pk7tanner
                            • Apr 2013
                            • 98
                            When I took the Y-sus board off and saw the the work that had been done to it, I knew that was where my problem.
                            I'm having a tough time reading the service manual for this model on my computer. Will it make more sense if I print it out and look at it next to the boards? The reason I'm asking is the previous owner replaced some resistors & I'm not certain they are the correct values
                              That would work, maybe. Have you seen this diagram yet?
                              http://tgohome.com/ServiceManuals/?d...&Search=Submit
                              I wish I had a diagram of the panel layout -- LG produce nice ones. This is a PDP50G2 panel, I think.
                              • pk7tanner
                                • Apr 2013
                                • 98
                                Thank you. I wasn't sure which one most closely resembled the unit I have. It's too late to do anything right now, but hopefully that will guide me in the right direction.
                                • pk7tanner
                                  • Apr 2013
                                  • 98
                                  I replaced a few resistors (3 total on the Y-sus: 1 toasted, 1 had broke & 1 looked suspect) on the Y-sus. When I plugged it in with all the boards connected, nothing started smoking. The power LED doesn't flash like it was. I don't have any display, but I do have some faint audio.
                                  What should I try next?
                                    Check if you have Vs coming out from the PSU with boards connected.
                                    • pk7tanner
                                      • Apr 2013
                                      • 98
                                      Do you mean volts? The TV wouldn't power on if I didn't. Which pin should I check? I cant believe there isn't an onboard diagnostic program on those TV. Do you know what the software for the USB connection is called
                                        There's very little diagnostics an LG TV provides.
                                        I mean measure the Vs output on the power supply with everything connected, do you see anything?
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • slimmy182
                                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                          by slimmy182
                                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                          Looking on google I found this:...
                                          01-14-2023, 11:55 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
