No background on the TV. The light on the front flashes red, blue 2X and then stays blue. I took the back off, I had it laying screen down on my coffee table and powered it on. When I did, it made a little static noise and I looked to see if there was any picture (there wasn't) and then I noticed two resistors glowing orange/red on the Zsus (part # 50G2A_Z). Is the board repairable and is the fault within that board or is it caused by something else?
LG 50PQ20 Plasma no pic/no sound
Re: LG 50PQ20 Plasma no pic/no sound
The Z-sus is a common failure on this model.
I think someone has a repair kit but you can buy the board too
http://www.ebay.co.uk/sch/i.html?_tr...at=0&_from=R40Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
It is most likely isolated to that board but some tests can be made. You will need a digital multimeter, do you have one?
As far as repair goes it is probably those two resistors plus associated components like FETs, driver ICs, diodes, etc. If you can locate all the failed parts it can be considerably cheaper than replacing the board but sometimes it is not worth the time because if you miss one component, all your new components can possibly go back up in smoke.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Yes I do have digital multimeter. And let me add that I have tested the power out on the psu board and all the v were correct. While I am awaiting your response I'm going to check if I have any audio now with the Z-sus disconnected.
Side note:
Parents of the world need to raise more people like tom66. A person who is willing to help others learn information he (likely) paid to obtain, is a trait that's exceedingly rare.Last edited by pk7tanner; 04-21-2013, 08:26 PM.Comment
Good luck. I never paid for any of this information though. It's all learned from experience -- over 50 TVs so far and counting. The service manuals in my signature are all sourced from the manufacturers directly, sometimes through other TV technicians.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Well I was should've known what I didn't check would be the problem (US Air Force better not let anymore Murphy's make laws). It's the Y-sus and I am going to attempt to repair the board myself. Any tips?Comment
You haven't yet provided pictures of the layout of the TV, I'm not sure if this TV uses combined energy recovery which sometimes requires both Z-sus and Y-sus to be repaired or replaced at the same time.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Looks like it's independent ERC to me; good, as that usually means failure is constrained to one board or the other.
As far as repairing the Y-sus, look at each component and test for shorts.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
When I took the Y-sus board off and saw the the work that had been done to it, I knew that was where my problem.
I'm having a tough time reading the service manual for this model on my computer. Will it make more sense if I print it out and look at it next to the boards? The reason I'm asking is the previous owner replaced some resistors & I'm not certain they are the correct valuesComment
That would work, maybe. Have you seen this diagram yet?
http://tgohome.com/ServiceManuals/?d...&Search=Submit
I wish I had a diagram of the panel layout -- LG produce nice ones. This is a PDP50G2 panel, I think.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I replaced a few resistors (3 total on the Y-sus: 1 toasted, 1 had broke & 1 looked suspect) on the Y-sus. When I plugged it in with all the boards connected, nothing started smoking. The power LED doesn't flash like it was. I don't have any display, but I do have some faint audio.
What should I try next?Comment
Check if you have Vs coming out from the PSU with boards connected.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Do you mean volts? The TV wouldn't power on if I didn't. Which pin should I check? I cant believe there isn't an onboard diagnostic program on those TV. Do you know what the software for the USB connection is calledLast edited by pk7tanner; 04-27-2013, 06:36 AM.Comment
There's very little diagnostics an LG TV provides.
I mean measure the Vs output on the power supply with everything connected, do you see anything?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
Yesterday, 05:17 PM -
by slimmy182Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
Looking on google I found this:... -
by stecosHi everyone!
For my passion for technology I'm now collecting several... - Loading...
