LG 50PQ20 Plasma no pic/no sound
  • tw2005
    • Oct 2011
    • 6458
    Re: LG 50PQ20 Plasma no pic/no sound
    If nothing has been adjusted on the ysus board or psu you should not have worry about voltages but I'd check them once it's running.
    But if it was me I'd go right over the ysus and check every FET,diode, resistor on the board and see if there's anything unusual like shorted FEts or burnt out resistors etc.
    Maybe the training manual will help some although it's not the exact model the principles should be able to be applied.
    Maybe check the voltage inputs to gnd at the connector and see if any short to gnd or low resistance? Likewise the Zsus feed at the Ysus?
    That's all I can come up with for you I'm afraid.
    • pk7tanner
      • Apr 2013
      • 98
      There's nothing visually wrong. How do you check mosfet or fets? I've just been checking the ohm and seeing if it matches similar ones, but I guess I should probably just enter the numbers in google huh? Does it matter what direction a metal oxide film resistor is soldered in? It doesn't seem like it should cause the ohm load is the same either way
      • tw2005
        • Oct 2011
        • 6458
        Oh, I see. resistors have no polarity, any direction.
        I'd simply use diode mode and check there is no continuous beep to indicate short between any of the 3 pins. Or see if you can follow the training as the results shown are all in cct.
        I youtubed to find out about testing FETs. there's some good videos arouund, Tom has some linked in a sticky very educational.
        • pk7tanner
          • Apr 2013
          • 98
          So after some basic visual checks and the looking for shorts in mosfet/fet's I threw caution to the wind and hooked everything up. Still nothing, but a different nothing.
          Now when I turn it on the front LED goes blue, flashes red and then it shuts off. I'm not smoking the resistors on the zsus (they're not even getting warm).
          Now what?
          • pk7tanner
            • Apr 2013
            • 98
            I disconnected just the Zsus and now I get sound, but I still don't have any picture.
              That's quite unusual, it makes me suspect the Y-sustain or buffers are bad too
              • pk7tanner
                • Apr 2013
                • 98
                That's what I'm thinking too. Is there a way to check the ysus board & what part on it do you think likely failed?
                  You need an oscilloscope unfortunately, especially with these new "combined ERC" plasmas.
                  • pk7tanner
                    • Apr 2013
                    • 98
                    It's a 2009 so it's not that new. What's ERC stand for?
                      Energy ReCovery, or, Energy Recovery Circuit.
                      New as in new technology. Only been around since 2008~2009.
                      • pk7tanner
                        • Apr 2013
                        • 98
                        I wish there was some way of making the screen at light up. It's basically doing the same thing it was doing before, except now that I replaced the faulty buffer board, it just shut off instead of frying the two zsus resistors.
                        What's a reasonable amount of money to invest in a set like this? If this was something one of you picked up, what would be your cutoff point? As it looks now, I'm probably going to need the stand or a bracket, zsus, ysus & likely the other buffer (though it looks fine to me). The boards aren't available on shopjimmy either so I'm stuck using ebay.
                        • pk7tanner
                          • Apr 2013
                          • 98
                          I have made a small bit of progress. Now everything (xsus, ysus & buffers) can be connected w/o anything smoking or getting hot, but there's still no picture. This may sound like a dumb question, but is there any sort of picture if there's no signal (eg static/white noise)?
                          I also rechecked the vs to the xsus and it's at 184.9 the +5 is at 5, which according to the sticker, is .1 under for each. Should that be adjusted?
                            A slight glow on the screen accompanied by the input notification OSD.
                            • pk7tanner
                              • Apr 2013
                              • 98
                              What about the vs & m5? Also if there's nothing being displayed (no glow or OSD) at this point, what's your guess as to what might be next: replace the other buffer board, ysus, or do you think the panel is bad?
                              • pk7tanner
                                • Apr 2013
                                • 98
                                Ever since I watched tom66's video on testing ysus buffers, I've been waiting for an opportunity to say "dodgy" and whenever time I find a problem on a board I say "oh that's not good, is it" in my best British accent.
                                • pk7tanner
                                  • Apr 2013
                                  • 98
                                  I can't believe it! I removed the one buffer board that I didn't replace & I was finally able to get the screen to display something. Unfortunately it's only a bunch of pixels twinkling like stars & there's a 7.5 cm wide blank strip that runs vertically on side.
                                  • pk7tanner
                                    • Apr 2013
                                    • 98
                                    If I have one buffer board connected I get a little bit of a pic, but mostly the pixels/stars, but if I have both connected, I get nothing. I'm confused tom66, help! Also I discovered that my main board had the s-video/rca input section just sitting there. I'm not sure what prompted the previous owner to remove it, but it's not necessary for it to be connected, is it?
                                      These sets chain buffer signals. With one buffer connected you will either get half a picture (could call it a "master" buffer) or nothing/noise (call it a "slave" buffer.)
                                      • pk7tanner
                                        • Apr 2013
                                        • 98
                                        Right but why am I getting a bit of a display when only one is connected (either one), nut if I connect both of them, I get nothing. And what about the rca input
                                        • pk7tanner
                                          • Apr 2013
                                          • 98
                                          So I tested the buffer boards and the one I did not replace is bad (I believe it's the first IC cause it's the contacts that go to FL 101, which I have no intentions of fixing). I was wondering, after reading the thread with jose6326, if the reason I began to get a bit of a picture is due to my adjusting the VS up a little? Sorry for asking so many question. I get obsessive about things once I start trying to fix them and have a hard time letting up until it's fixed (hence the hours I have spent reading every LG plasma thread remotely close to mine).
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • slimmy182
                                            [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                            by slimmy182
                                            Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                            I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                            Looking on google I found this:...
                                            01-14-2023, 11:55 AM
                                          • Cooperr
                                            Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                                            by Cooperr
                                            I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                                            The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                                            10-21-2025, 01:11 PM
