NEC 42" problem plasmasync 42mp1
  • henrysin44
    • Apr 2013
    • 109
    I have a nec px-42vm1a that has no picture, when I turned it on there was a red bar across the screen and then it turned off as I heard a pop, tv has worked before.
    I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
    Service Menu/Factory Reset Codes for TVs
  • henrysin44
    • Apr 2013
    • 109
    Re: NEC 42" problem plasmasync 42mp1
    kinda urgent
      Sounds like a Y-buffer issue. Did the bar go from top to bottom or left to right?
      • henrysin44
        • Apr 2013
        • 109
        Left to right, I too collect flat screens from the dump but this one is my grand dads
          Can we see a picture?
          That extra message below "_________" is part of my signature, automatically added to the first post of mine on each page.
          • henrysin44
            • Apr 2013
            • 109
            What do you want a picture of
              The fault.
              • henrysin44
                • Apr 2013
                • 109
                Well theres no picture on the screen (black) and no visible faults on any of the boards, all I currently have as a iPad with no camera.
                  There was a red bar though? Is that gone now?
                  • henrysin44
                    • Apr 2013
                    • 109
                    Yes, I turned the nec on and a red bar went across the screen, I then heard a pop noise. The set will turn on, the fans will spin up with a green indicator light then the fans spin down and the light turns red. With no picture on screen.
                      The symptoms don't match up. It's pretty much impossible to have a left to right horizontal bar; due to how the pixels are arranged. There's a small chance it's the main board, but it's more likely a sustain board and buffer failure, which would lead to top to bottom vertical bar(s).
                      • henrysin44
                        • Apr 2013
                        • 109
                        Oh there was also a top to bottom one too, forgot to mention that.
                          You really need to mention all of the symptoms but it still doesn't make sense. Pixels are arranged "RGB", left to right. You can get all "R" stuck on in one vertical bar, more than possible. You can't really have all "R" in a horizontal bar stuck unless the main board is at fault (you might get all RGB, i.e. white, but not just red), but this doesn't really correlate with the "pop" you heard. So I don't know what to say.
                          • henrysin44
                            • Apr 2013
                            • 109
                            Well it happened, oh well.
                            • perzyk23
                              Lenovo T580 - LCD Panel problem - error 0288
                              by perzyk23
                              Good morning,
                              I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                              10-25-2024, 12:42 AM
                            • SDNarcia
                              Dell 15R-5521 keyboard problem (KBC?)
                              by SDNarcia
                              Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                              As additional information,...
                              07-20-2024, 10:47 PM
                            • funyy
                              LG OLED55B8PLA problem
                              by funyy
                              Hey there,
                              So I got a problem with my LG OLED TV (OLED55B8PLA).
                              the problem is that the tv won‘t power on some times, the led stays red and won‘t even blink, just solid red when I try to turn it on. USB devices connected won‘t light up. 1/4 of the screen (left side) shows some green „clouds“ that are getting brighter everytime I turn the tv on and after some tries the tv finally turns on. Sometimes it takes 10 tries and some times 100 or even more tries.
                              When the tv is on, everything works fine, hdmi outputs, usb inputs, wifi, bluetooth, etc is working...
                              04-30-2022, 07:51 AM
                            • s_specialist
                              Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
                              by s_specialist
                              Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
                              07-07-2025, 11:47 AM
                            • falcontech
                              MOTU TRAVELER MK3 AUDIO PROBLEM
                              by falcontech
                              Good Afternoon
                              I have a problem with this MOTU audio card, a traveler MK3, the connection to the computer is via firewire, the card is recognized by the computer (both mac and win) but I have no audio output, on the front there are a series of LEDs including the clock (44.1, 48, etc.) and that LED at the time of connection usually remains fixed telling me the clock frequency set on the computer, now at every start the LED in question remains flashing in most cases, sometimes it becomes fixed, other times it disappears, without any sign of operation, I exclude problems with the firewire chip,...
                              01-24-2025, 08:47 AM
