Vizio VW42L FHDTV10A
  • ngoodnight01
    • Apr 2013
    • 6
    Hello
    I acquired this LCD for free and I am trying to fix it. I have found that one of the inverter boards had a fried IC so I replaced the pair as per instructions on this forum. Now I have a picture when plugged into an hdmi source on my laptop but it flickers very fast and makes a very rapid clicking sound. I have looked for bulged caps but have not found them. Thanks for the help
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Vizio VW42L FHDTV10A
    Check on the forum for testing voltage regulators - vizio seems plagued with bad ones
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...7&d=1280167246
    https://www.badcaps.net/forum/attach...6&d=1280167246
    https://www.badcaps.net/forum/attach...4&d=1280167246
    • johnboy1313
      • Nov 2012
      • 1959
      Check U7 and U33 on the main board. Well, check them all but I had similar issues on a Vizio GV42 something or other and replacing those 2 VR's fixed it.
      • ngoodnight01
        • Apr 2013
        • 6
        I am trying to upload pics but the attachment clip is not allowing me to what am I doing wrong
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Keep them less than 2mb and try and upload one at a time
          • ngoodnight01
            • Apr 2013
            • 6
            Here is the pics
            http://sdrv.ms/ZmK6Qz
            • cashkennedy
              • Aug 2011
              • 668
              Your pics are probably too big in their current form to be posted with the manage attachments function. I know my 6 megapixel camera from 10 years ago works, but your probably using something in the 12 range.
              Not many people are gonna want to "trust" a link like that , but i clicked it and its skydrive which is fine.
              As far as your actual problem, you cant visually see that a regulator is bad, so if thats the problem pics arent going to really help... Have you tested the regulators on the main board with a multimeter to see if they are giving the right voltages while the set is plugged in / and on if possible.
              I never like trying to diagnose sets via pictures, i prefer to go about it in a logical process > is power supply board outputing the right DC voltages > then check regulators so on.
              There is a very good flowchart in the service manual for this generation of vizio sets and explains exactly what voltage each regulator should be outputing.
              Based on your actual symptom though , if your just getting flickering in the backlight, and not in the actual picture, then you might have a bad bulb or bad transformers on the inverter board that are skipping some windings (shorting) very rapidly and inconsistently. There are also sometimes caps on the inverter boards that can go bad.
              You didnt post any picture of the inverters and thats probably the only thing that might help if your problem is only with flickering backlights.
              Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
              • ngoodnight01
                • Apr 2013
                • 6
                I have them uploaded to my album on this forum how do I link it to my post?
                • cashkennedy
                  • Aug 2011
                  • 668
                  If your sure its a flickering backlight issue, you could take the set all the way down to the light box (requires careful handling of the LCD as you carefully slide / lift it off the light box) and watch the bulbs while the set is on. If only some of the bulbs are flickering the problem is related to the inverter / bulbs , if all of them are flickering more likely an issue with the power supply or the mainboards control of the brightness.
                  I dont know how to link pics from your album on the site, but unless youve taken some new pics of the inverters it probably isnt necessary.
                  • johnboy1313
                    • Nov 2012
                    • 1959
                    You may not need to lift the LCD screen off. On all of the LCD's I've worked on, when the back cover is off, you can tell from the back when the backlights come on. There are several screw holes that go through the metal case of the panel that allow light through. There is a white plastic sheet inside the case so you don't see the actual bulbs, but you can still tell when the light comes on. If the bulbs are flickering, you should be able to see it.
                    • ngoodnight01
                      • Apr 2013
                      • 6
                      I am getting the correct voltages out of the 24 volt and the 12 volt side to the main board. When I probe the two outlets of u13 ( which is under the heat sink0 I get 1.3volts and 1.1 volts steady. I can see through the holes in the back of the tv especially where the inverter boards plug in that both sides of the LCD are flashing very rapidly. This is doing this with just the TV on and no input to it. If I put an input it shows the input but is flashing very rapidly still.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        did you replace the two capacitors on each inverter board?
                        Do you have the 8.5 Kohm at the FET transistors?
                        • ngoodnight01
                          • Apr 2013
                          • 6
                          I replaced both inverter boards with the updated versions which I have not modified. Which FETs are you referring to?
                          • tibimakai
                            • Jan 2012
                            • 3680
                            I thought that you have replaced the chips from those boards.
                            It could be a bad tube in the screen.
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                            • nbnb
                              Vizio VO47L FDHTV30A Picture but no speaker audio, clicking sound
                              by nbnb
                              I have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
                              Any idea what is causing the clicking sound? Any easy way to...
                              11-23-2019, 12:03 PM
                            • SS454
                              vizio e650i-a2 backlight flashes then turns off
                              by SS454
                              vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                              panel: au optronics T650HVN05.4
                              72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                              link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                              Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                              https://www.shopjimmy.com/vizio-56-0...-power-supply/
                              Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                              08-20-2020, 03:57 PM
                            • Sisko
                              Onkyo-593 No power and now clicking sound
                              by Sisko
                              Hi all!!
                              Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                              10-03-2025, 02:18 PM
                            • mrtek
                              Vizio M65-C1
                              by mrtek
                              Hi.
                              picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                              When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                              This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                              07-14-2025, 07:28 PM
