Vizio VO370M backlight off in 1 sec
  • ChaseB1989
    • Oct 2012
    • 11
    • U.S
    Shows standby , powers on to white back lights come on 1 second and shut off stays powered on with no back light. Cannot see image with flashlight. No vizio logo.
    Mainboard issue???
  • esurpren
    • Jun 2013
    Re: Vizio VO370M backlight off in 1 sec
    Did you ever figure this out, I have a set with the same issue?
    Anyone else ever have/resolve this issue?
    Thanks esurpren......
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • SS454
      vizio e650i-a2 backlight flashes then turns off
      by SS454
      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
      panel: au optronics T650HVN05.4
      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
      https://www.shopjimmy.com/vizio-56-0...-power-supply/
      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
      08-20-2020, 03:57 PM
    • 1crow1
      Vizio E601i-A3 backlight issue
      by 1crow1
      When I turn on the TV the backlights flash on for a second and go out, I get the Vizio logo on screen for that short time. It passes the flashlight test.
      Will a bad backlight cause this shutdown or should I be looking at the power board.
      CN301 CONNECTOR
      Readings as follows
      VLED1-1+ 125 volts then drops to 0
      VLED1-1- 0 volts
      VLED1-2+ 0 volts
      VLED1-2- 109 VOLTS THEN DROPS TOO 0
      VLED2-1+ 105 volts then drops to 0
      VLED2-1- 0 volts
      VLED2-2+ 0 volts
      VLED2-2- 130 volts then drops to 0
      CN201 reading seem...
      03-22-2023, 07:11 AM
    • Riananyaina
      MacBook A1708 820-00840-A backlight issue
      by Riananyaina
      Hello Everyone ,
      today I'm coming to you regarding my issue which is no Backlight .
      I have image on my screen but no light .
      The macbook was one that I bought few month ago that I used with an external screen . Now I started to do some analysis on the MB which my limited knowledge .
      First thing is that it suffered from liquid damage . The fuse was not ok when I openned it the first time . But I already changed it after testing that there is no short to ground on this line .
      Please find below few informations which can help for the analysis...
      04-24-2023, 05:03 AM
    • roman728
      iMAC A1418 Backlight issue
      by roman728
      Hello friends,
      I have this unit with no backlight on screen. After inspection i determined there is a shorted capacitor on BKL_BOOST circuit. I removed the capacitor, short is gone but backlight still not working. I found that Q9702 is not open and R9721 is only around 70kOhms but according to schematics it should be 301k. I removed the resistor and connected the gate of Q9702 directly to GND. Now i have 12v passing by the mosfet to turn on backlight IC LP8561 (U9700) but BKL_BOOST circuit is not working. I can measure only 12V there but it should be around 60V.
      Can you...
      04-10-2025, 11:48 AM
