Vizio VO370M backlight off in 1 sec
  • ChaseB1989
    • Oct 2012
    • 11
    • U.S
    Shows standby , powers on to white back lights come on 1 second and shut off stays powered on with no back light. Cannot see image with flashlight. No vizio logo.
    Mainboard issue???
  • esurpren
    • Jun 2013
    Re: Vizio VO370M backlight off in 1 sec
    Did you ever figure this out, I have a set with the same issue?
    Anyone else ever have/resolve this issue?
    Thanks esurpren......
    • SS454
      vizio e650i-a2 backlight flashes then turns off
      by SS454
      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
      panel: au optronics T650HVN05.4
      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
      https://www.shopjimmy.com/vizio-56-0...-power-supply/
      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
      08-20-2020, 03:57 PM
    • 1crow1
      Vizio E601i-A3 backlight issue
      by 1crow1
      When I turn on the TV the backlights flash on for a second and go out, I get the Vizio logo on screen for that short time. It passes the flashlight test.
      Will a bad backlight cause this shutdown or should I be looking at the power board.
      CN301 CONNECTOR
      Readings as follows
      VLED1-1+ 125 volts then drops to 0
      VLED1-1- 0 volts
      VLED1-2+ 0 volts
      VLED1-2- 109 VOLTS THEN DROPS TOO 0
      VLED2-1+ 105 volts then drops to 0
      VLED2-1- 0 volts
      VLED2-2+ 0 volts
      VLED2-2- 130 volts then drops to 0
      CN201 reading seem...
      03-22-2023, 07:11 AM
    • Riananyaina
      MacBook A1708 820-00840-A backlight issue
      by Riananyaina
      Hello Everyone ,
      today I'm coming to you regarding my issue which is no Backlight .
      I have image on my screen but no light .
      The macbook was one that I bought few month ago that I used with an external screen . Now I started to do some analysis on the MB which my limited knowledge .
      First thing is that it suffered from liquid damage . The fuse was not ok when I openned it the first time . But I already changed it after testing that there is no short to ground on this line .
      Please find below few informations which can help for the analysis...
      04-24-2023, 05:03 AM
    • bstewara
      Samsung un65eh6000 backlight issue
      by bstewara
      Hi All,
      I have a Samsung Un65eh6000 with a backlight issue.
      The original issue was backlight current was present but led strips did not light
      I tested the backlights and all tested to be working properly.
      I assumed then that the power supply was not sending current to the led strips.
      Power supply board part number BN44-00560A.
      After checking voltages it appears that current output at connector CNL802 was outputting the correct current 189 VDC on pins 1,2,6, and 8.
      The issue then was there was no ground on the connector...
      02-17-2023, 03:32 PM
