LG model 42LG50-UG, new user needs help selecting correct replacement fuse 4 inverter
  • Parachute
    • Apr 2013
    • USofA
    Hello to all! New user here, but a long time lurker that's come here several times seeking knowledge from the many skilled members. I'm hoping that someone can help me finish a repair job that I doubt I could have done without the past help of several members here.
    As noted, I'm working on a LG model 42LG50-UG LED tv, and I have determined, and proven, AND temporarily scabbed in a round fuse (with successful results) to address what seems to be the commonly blowing fuse described in this thread: https://www.badcaps.net/forum/showthread.php?t=10439
    This is the fuse that users rb0746 (post #1 and more), Solipsist (post #87 and more), and other users have encountered and seems to be a common problem with this make/model of tv. A pic of the exact fuse is shown in post #83 and is shown for convenience here (has #15 on it, is black in color, and has .75A/76W on the board next to it):
    ***Note: my fuse id is identical, same location and all but is stamped .75A/63V on the board.
    So now that the problem component is identified, I'm not sure exactly what replacement to buy. Yes, it's 750mA 63V SMT fuse, but is it slow blow, fast blow or super fast blow? And what's with the "melting I^^2t" in the digikey specs, what do I need to know about this and how do I apply the info? As for the mounting of the replacement, I'm really experienced with soldering but given how small this part is IF I were to use another surface mount fuse from digikey (or other?) I'm concerned that even with my 25W pencil iron and awesome, lead saturated, quick flowing and not RoHS compliant solder, that I might degrade/destroy the new fuse. As such and in the name of reliability, I'm considering a fuse with axial leads that will stand above the circuit board a bit and with I can grasp with a needle nose pliers during install, thus protecting it from heat. Something that looks like this: http://www.digikey.com/us/en/ph/Litt...316Series.html Two people so far seem to endorse the idea of an axial lead replacement, first is user budm (post #101, and with very good results) and a buddy of mine who is a EE.
    So after seeing this, how do I pick the correct replacement fuse and are there any brands that I should avoid? I don't wanna just go for it, slap a fuse in, call it a day and have it pop in a few years while watching a movie, I want a reliable, durable and robust repair, one that isn't gonna fail.
    -Bill
  • Parachute
    • Apr 2013
    • USofA
    Re: LG model 42LG50-UG, new user needs help selecting correct replacement fuse 4 inve
    Bump......anyone?
    I was wrong about that fuse size in my last post and in fact, the correct spec is .75A/76V. Along with the earlier replacement problem, what do you do when so far I have found no 76V fuses out there to pick from? Thanks in advance.
    -Bill
      Higher voltage rating is OK, but not lower.
      Do you have the dimension of this fuse? I never measure the one I had repalced with 1A PICO II fuse which an axial leads, you do not have to remove the old one. Fast blow is fine, it is used for powering the PWM IC circuits section.
      This is common failure in CMO Inverter board.
      PDF for SMD fuse attached:
        Are you sure this is an LED TV?
          It is 2008 model, it is not LED backlit TV for sure.
          http://www.lg.com/us/support-product/lg-42LG50-UG
          I think he just made the typo.
          • Parachute
            • Apr 2013
            • USofA
            Physical size is ~ 3/16"L x 3/32"W x 1/16"T. I noticed in an earlier post that a DMM was used that was able to capture max current draw and it was done where this fuse is installed. It was noted that there was not much headroom at startup and that's where I got the question/idea about using a slow blow fuse, that and in the name of ensuring reliability.
            I guess I was sleeping at the wheel when I made my earlier post, you are correct, it's LCD.
            Thanks for the help guys, it's much appreciated.
            -Bill
              That is why I use 1A fuse, the fuse rating was under rated. Fuse should be at least 25% higher than the circuit needed.
              • Parachute
                • Apr 2013
                • USofA
                Awesomeness, thanks!
                This is getting easier by the minute. I had planned on buying from digikey but I did quick check on ebay and viola, problem solved!
                Here we go, http://www.ebay.com/itm/7-pieces-axi...item1e59eedadf
                I truly feel sorry for people buying TV's with their hard earned $$$ and then having some very inexpensive part fail, causing the consumer, who usually has not a clue how to fix it, to face buying the repair and hope for the better or replace the product. Seriously, the last time I remember seeing people have sooooo many problems with TV's is when I was a little kid and they used tubes. If people weren't using the tube testers located in practically every grocery store, there was always a TV repair truck floating around the neighborhood.
                -Bill
                • drykid
                  Matsui 175S microwave fuse replacement
                  by drykid
                  I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                  Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                  12-21-2020, 01:15 PM
                  Surface Mount Fuses Fundamentals Datasheet
                  TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                  TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                  10-07-2024, 06:07 AM
                • whc14765
                  Replacement Fuse - 980TI Gigabyte
                  by whc14765
                  I have a GIGABYTE Windforce 980TI with a blown fuse. I have already found the root cause for the fuse blowing.
                  I need help getting a replacement fuse - I'm fine with waiting some time for some cheap ones from China.
                  The fuse says 10A on it. And I'm not sure what package size it is exactly. Also, how do I know if it is a fast or slow fuse?
                  04-11-2022, 09:01 AM
                • corrize
                  A funny fuse story – Lumix LX100 II
                  by corrize
                  Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                  I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                  The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                  There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                  And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                  10-19-2023, 09:58 AM
                • eidam655
                  GPU 1206 SMD fuse markings & replacement fuses
                  by eidam655
                  I need to replace a fuse on one of the graphics cards I am working on. It is a 1206 SMD fuse, white in color and has a "10" written in a blue rectangle on it.
                  How do I find a suitable replacement? What is the general rule to identifying fuses' parameters? I found something in an eshop near me (see photo) but am very hesitant to use this as a replacement....
                  04-14-2022, 12:46 AM
