SCEPTRE X322BV-HD POWER SUPPLY is Burning
  • jerrytav
    • Mar 2013
    • 8
    My LCD didn't turn on and recently started burning inside. So I opened it up and and found out that a piece of the board was burnt off. Every time I turn the tv I could see the electrical current burning the board. How did this happen? and What should I do to get this fix?
    Below is a picture of how it looks and how a new piece looks like.
  • selldoor
    Slow Learner
    • 7870
    Re: SCEPTRE X322BV-HD POWER SUPPLY is Burning
    You will need to take a close up picture of that area from the back of the board.
    Repair will involve cutting out the burnt part and replacing it, probably with
    epoxy and replacing any cut or burnt traces with wire.
    There are very high voltages on this part of the board we have seen it before. Maybe when you rmove the board you can see underneath if it has been shorting on anything.
    • selldoor
      Slow Learner
      • 7870
      New Id seen it before -read this
      https://www.badcaps.net/forum/showth...ighlight=Burnt
      • jerrytav
        • Mar 2013
        • 8
        You are correct selldoor I have the same exact problem.
        • jerrytav
          • Mar 2013
          • 8
          You are right! should I also cut out the burnt piece?
            Yes, once the PCB is carbonized, it will be just like a resistor and conducts especially when 2000V will be around that area, remove all the blackened board and use RTV Silicone to coat the board in that area, the main thing is to make sure to remove ALL the carbonized sections.
            • selldoor
              Slow Learner
              • 7870
              Ok - well I think you have enough info there to fix it - if not- come back and ask
              -let us know how you go on and post a pic of the repair.
              Also while you are in there can you look at U3 and U4 and if you can read the part numbers post them for info in this thread or in the one I linked to.
              • jerrytav
                • Mar 2013
                • 8
                Hey! I was able to apply the fixes and everything seem backs to normal! Thanks to you all. Hoping this is a permanent fix.
                Hey selldoor saw that you need the U4 and U3. Excuse my ignorance, but dont know what part you mean. If you can point it out on a picture of mines than I would be more then happy to get the information you need. Not really a technician, Im a web developer lol but if you point out the piece I could get you that info.
                  U3 and U4 are the 8 pin "bug"-like chips on the board -- can you read off the part #s? They are laser etched onto the devices. If not, can you take a clear photo of the numbers? Glad to hear it is fixed.
                  • multimeter
                    • Jan 2011
                    • 739
                    • united kingdom
                    u4 and u3 will be either a voltage regulator or another chip,just look for the legend next to any of the chips on the silk screen written in black,think selldoor wants the part numbers .
                    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                    • selldoor
                      Slow Learner
                      • 7870
                      Well done - good fix I attach a picture showing U3 & U4
                      • jerrytav
                        • Mar 2013
                        • 8
                        Hope this is helpful!
                        On the U3: MEG003, 1BM, A45H
                        On the U4: AS358A, M E1, 144RE1
                          This will prove very useful. Thanks! Enjoy your fixed TV.
                          • jerrytav
                            • Mar 2013
                            • 8
                            Sure thing!
                            • feengerz
                              • Feb 2014
                              • usa
                              Same problem same solution. Thanks to this post I was able to have the tv back in working order in less than 30 mins. TYVM.
                                by sam_sam_sam
                                03-31-2024, 02:12 PM
                                by sam_sam_sam
                                07-01-2024, 06:34 AM
                              • shamsudeen
                                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                by shamsudeen
                                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                07-19-2025, 07:14 AM
                              • CMCM
                                Russound CA4 Power Supply Repair
                                by CMCM
                                Hello Everybody,
                                Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                The outputs marked 12v and 20v are all measuring only 1v.
                                The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                The capacitors physically look clean (no bludgesor leaks) and...
                                07-03-2025, 01:12 PM
