morning..what would cause this? see pic thanks
  • davewilson61
    • 110
    • usa
    LG....32LC7DC
    comes on buttons will not change the picture
    will shut down on its own in 25 seconds then blinks then comes back on by itself....then you must unplug it to get it off...seems to have different pattern
    everytime...screen seams to go white slowly on its own
    t-con board?
    thanks dave
    Re: morning..what would cause this? see pic thanks
    Defective panel, tab bonds or T-con. I'm thinking defective panel myself.
    • davewilson61
      • 110
      • usa
      opened it up found two bad caps on ps board..changing them now...
        I'd be surprised if they caused that, though I have seen graphical glitches caused by bad caps, usually it resolves itself after warming up though.
        • davewilson61
          • 110
          • usa
          ok that got it up...looks good..but only working by remote...if you use the buttons on the side it says key lock...did go into menu turned off key lock ...but still says key lock when you use the side buttons...any factory reset?
          thanks dave
            So it was bad caps? Interesting...
            Hold MENU on TV and MENU on remote for 10 seconds, service menu should appear, then select reset option.
            • davewilson61
              • 110
              • usa
              got in there but cant find any reset options
                Picture of the menu?
                • truep
                  • Aug 2010
                  • 373
                  I has an Astar tv that would have lines all over when powered up. After trying
                  several times it would come up and run fine. It was bad caps.
                    I have seen full screens of lines but not a bar width be bad caps...
                    • davewilson61
                      • 110
                      • usa
                      pics of menu just cant find any reset wonder if i can do a update by usb port?
                      • selldoor
                        Slow Learner
                        • 7870
                        Can you find a label that has the chassis number on -could be LA73E or something similar with 5 digits
                        • davewilson61
                          • 110
                          • usa
                          I will look for that # but read something tom posted to ground out the eprom to get a factory reset?
                            Don't think that works for these LGs.
                            Maybe only way is through RS232.
                            • juergenb
                              Dell 5570 - LA-F115P, Dead
                              by juergenb
                              i am new here and try toy to repair a dead Dell 5570, with i5 and AMD GPU.
                              Before purchasing any Hotair or Microscope equipment i try to repair with my equipment and a handheld lens for stamps/coins...
                              The Board has no sign of life, if 19V is connected i hear a hissing sound.
                              I checked Power Rail at DC in an 19V seems fine so far.
                              I have schematics, Scope, Multimeter, DC Bench Power Supply with Current limiting (HP/Agilent).
                              Schematics is "Dell Inspiron 15 5570 LA-F115P CAL50 DAL10 REV 1.0 (A00)"
                              I think that the...
                              03-21-2021, 04:28 AM
                            • yura8
                              Need BIOS/EFI dump for MacBook Air A1466 2015 EMC 2925 (8gb)
                              by yura8
                              Hi there! I have not so usual situation...
                              I have 2015 MacBook Air A1466 EMC 2925 with 8Gb of RAM. It seams that I've killed it by bad SSD adapter. It starts, cooler works... But no chime, screen is black. SMC reset seams works, NVRAM reset doesnt works...
                              My repair guy has checked all possible. It's all ok with power. The last idea - I could kill EFI firmware... So, I need a firmware of EFI to check it. I have a programmer. But I don't have a similar laptop now to download it and compare
                              P.S. If you have else any ideas about repair, or you had a similar...
                              12-20-2024, 02:31 PM
                            • reessi
                              Huawei D14 - DAH98AMBAD0 Rev.D - Laptop not Charging - Missing 137K on IADPT - Inductance Selection - BQ25713 Charging IC
                              by reessi
                              Hello:
                              On the above laptop which wasn't charging I found only a tiny drop of water damage exactly on a few components by the BQ25713 Charging chip.. Bizarre how only that one 3mm square for it but it did..
                              I looked up the BQ25713 datasheet and replaced the 10K pull up resistor on the CHRG_OK line and now it charges!
                              But on the IADPT line which seams to be a resistor (137K) to tell the chip which Inductor is in use it is corroded also.. (Inductance Detection Through IADPT Pin - from datasheet).
                              So my question is what are the implications of leaving...
                              03-06-2024, 07:33 AM
                            • mrdevil
                              Crest Smart Home Single Power Adaptor SHSPM1 (rebadged Tuya device) - bad cap causing failure, how to repair
                              by mrdevil
                              Wanted to share this as I couldn't find anything on the internet about this problem, so pulled one apart and found the problem myself. Years ago I bought approx 20 or so Crest Smart Home Single Power Adapter smart switches - small 240v Tuya-compatible (rebranded) smart switch devices with power monitoring, which Big W had on sale for half price. Paid $7.50 each for these, and they've been incredibly useful for turning things on and off remotely... and monitoring how much power each device uses.
                              However, after about 12 months, I had a number of these stop working...
                              01-08-2025, 03:19 AM
                            • reessi
                              Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                              by reessi
                              Hello:
                              I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                              I started on the ACER:
                              Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                              All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                              I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                              10-29-2024, 11:31 AM
