Tab bonds - Sony Bravia KDLS4100
  • tvduude
    • Jul 2012
    • 67
    i am shimming a sony 46" Sony KDL ? 4100? with the TAB BOND detaching problem.
    this is the 2nd repair i have done like this however i find that the sony seems tougher.
    i have had 90% success eliminating the lines but the far top left tab has some issue that resists complete success.
    i can achieve full contact with very firm pinpoint pressure with my fingertip.
    however locating a pinpoint shim on that point seems to just cause the problem to jump over a tiny bit.
    as you may have guessed the broad shim across the whole tab joint does not work either.
    it almost seems that the tab needs to be detached and re-attached..
    is that crazy talk or what?
    edit:
    nevermind , i see now that is a heat bonding process.
  • tvduude
    • Jul 2012
    • 67
    Re: Tab bonds - Sony Bravia KDLS4100
    what is the fire hazzard recall for sony TVs about?
      Failed transformer on the inverter -- completely unrelated.
      • tvduude
        • Jul 2012
        • 67
        panel damage does not cause inverter circuits to fail since the backlight is not
        part of the panel circuitry correct?
          It would be completely unrelated. The backlights themselves are considered part of the panel module (the "LCM" -- liquid crystal module) but they're separate from the LCD (liquid crystal display.)
          • tvduude
            • Jul 2012
            • 67
            and one more nooby question..
            will intermittant tab connections cause heat and do further damage to the tab bonds and connections and speed up failure?
              Yes often.
              • MisterD
                • Oct 2012
                • 668
                Use 3/8" OD latex surgical tubing on tab bond for what you call a shim. You can get it on eBay, works good. It can handle the hot temperature too.
                • truep
                  • Aug 2010
                  • 373
                  I use thermal pads Salvaged from old TCON boards or ordered off ebay. It helps with the heat transfer.
                  • splitcrete
                    • Dec 2012
                    • 387
                    • usa
                    I use a Q-TIP with the ends broken off under the pad for hard to connect problems.
                    The round shape stays put and keeps pressure on the tab. Call me crazy but I have fixed over 15 tab bond problems, and I am always trying new ways to keep them from failing again.
                    • JUCaESAl
                      Sony bravia KD-65AF9
                      by JUCaESAl
                      Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                      Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                      10-20-2025, 04:03 AM
                    • PopsCaps
                      Sony Bravia KDL-40V2500 that will not power on
                      by PopsCaps
                      I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                      I do not hear any sound and I cannot see any backlight.
                      I have tried disconnecting every cable on each board one at a time to see if anything changes.
                      The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                      My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                      03-25-2025, 11:23 AM
                    • alegatorul
                      sony bravia kdl-43w756c, no power, no sound
                      by alegatorul
                      the charger brick has 19,2-19,3 vcc
                      changed the inverter board same result.
                      where should i start?
                      cheers
                      11-15-2025, 10:00 AM
                    • justin35
                      Sony bravia kdl-43w755c - boot loop
                      by justin35
                      i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                      from what i read online it looks to be an emmc issue…
                      i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                      i took out the board and say an samsung 16gb emmc
                      i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                      i could try to put one instead of the 16gb one, but will it work?
                      where do i get the software from?
                      any help will be much appreciated!...
                      03-06-2024, 12:26 PM
                      Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                      Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                      10-16-2024, 05:15 AM
